I am struggling with something that should be super easy - but my mediocre programming skills are failing me so I beg for your help!
I am connecting a W5500 wiznet chip to the NRF52. I am using Segger. The SPI device seems fairly standard. Using the standard Nordic SPI library using an array I can write to the registers and read from registers directly, no problem here. However........... the provided SPI driver library that I need to use requires separate and individual control of the chip select (CS) lines and needs to send or receive 1 byte at a time. This is where I am hitting major road blocks.
For the purposes of testing, I am not trying to use the W5500 library, I am just trying to set the IP address of the device on the NRF52840 sending 1 byte at a time. Again note that I have no issues doing this if I follow the standard SPI examples and send multiple bytes in an array format (unfortunately, the library is not written like this so I can not do it) .
- Setting chip select line as not used so I can control it through my code and the SPI Nordic driver does not do this function
#define SPI_SS_PIN NRF_DRV_SPI_PIN_NOT_USED
Then I do the following
- Put chip select low
- Send 1st byte of data
- Send second byte of data
- Put chip select high
#define W5500_CS 22 uint8_t TX_DATA[7] = {0,15,4,10,0,0,80}; nrf_gpio_pin_clear(W5500_CS); //sets CS pin to logic 0 low to initiate SPI transfer w5500_test_write_reg(TX_DATA[0]); w5500_test_write_reg(TX_DATA[1]); w5500_test_write_reg(TX_DATA[2]); w5500_test_write_reg(TX_DATA[3]); w5500_test_write_reg(TX_DATA[4]); w5500_test_write_reg(TX_DATA[5]); w5500_test_write_reg(TX_DATA[6]); nrf_gpio_pin_set(W5500_CS); //sets CS pin to logic 1 high to stop SPI transfer
The function used to write the byte is also fairly standard
void w5500_test_write_reg(uint8_t tx_data) { NRF_LOG_INFO("Write = %d", tx_data); //**** TX transmition parameters uint8_t tx_len = 1; // TX number of bytes spi_xfer_done = false; //**** Set the transfer flag to false APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_data, tx_len, NULL, 0)); while(spi_xfer_done == false){}; }
I get an error when the firmware tries to write the 2nd byte
<info> app: Write = 0 <info> app: Write = 15 <error> app: Fatal error <warning> app: System reset
In Arduino this is a beyond simple piece of code.......
digitalWrite (CS, LOW); SPI.beginTransaction(xx); Byte_1 = SPI.transfer(xx); Byte_2 = SPI.transfer(xx); Byte_3 = SPI.transfer(xx); Byte_4 = SPI.transfer(xx); SPI.endTransaction(); digitalWrite (CS, HIGH);
