Hello. We have a designed nRF52832 products which needs regulatory tests in US and Korea.
Apparently, significant test files are required for BLE certifications, and this is new to me.
1) A developer told me that these project files are located in the Nordic SDK, or are available through the DevZone.
Below is a description of the test modes needed. It seems to me that this is covered by some standard and BLE example projects that I need to locate. I've found examples/DTM in the SDK, but no documentation that explains how this would be configured for the tests below.
Any help that you can give on this would be helpful
TM1: CONTINUOUS TX MODE CH 0 (2402 MHz)
TM2: CONTINUOUS TX MODE CH 59 (2441 MHz)
TM3: CONTINUOUS TX MODE CH 39 (2480 MHz)
TM4: TX MODE no modulation (CW) CH 59 (2441 MHz)
TM5: RX MODE CH 0 (2402 MHz)
TM6: RX MODE CH 59 (2441 MHz)
TM7: RX MODE CH 39 (2480 MHz)
Additional modes for testing in Korea
KOREA TM1: CONTINUOUS HOPPING MODE
NOTES:
1. “Continuous TX mode” means the transmitter is transmitting a repeating data
transmission with a high duty cycle (preferably around 97% duty cycle)
2. For EU “Receiver Blocking” test the lab must have a transmit and a receive
sample with some method of monitoring the wireless data link (BER or PER).
3. TM4: TX mode with no modulation is required for testing in China, Japan, and
South Korea only.
