nRF5340 IO pin injection current
I have an nRF5340 design that uses the ADC to monitor an external voltage.  In some operating scenarios the external voltage may be present prior to VDD at the nRF5340.  The monitored voltage is divided down using two 100K resistors before it is connected to the nRF5340 (refer to attached image).  The monitored voltage has a maximum value of 4.2V at the input to the resistor divider.
Is there a maximum current that can be safely injected into an IO pin of the nRF5340 and does it vary by IO pin type?
Are there other potential faults that could occur if current is injected to an IO pin prior to application of VDD such as a corrupted boot sequence or lockup of the SOC?
Thank you for your support.
Sincerely,
Doug Young
