nRF5340 Firmware Update from external NOR QSPI flash
Hi
I have gone through the following link and I have working firmware OTA update with BLE SMP.
https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu#http_dfu_ext_flash
But my device design also has a cloud connection via nRF9160. Following is the complete connection diagram.
Cloud<==HTTPS==> nRF9160 <== UART ==> nRF5340 <== QSPI ==> NOR flash
My requirement is to receive the firmware update file via HTTPS to nRF9160 and it will be transmitted to nRF5340 and eventually will be written in NOR flash.
external_flash:
  address: 0x0
  end_address: 0x200000
  region: external_flash
mcuboot_secondary:
  address: 0x00000
  device: mx25r16
  end_address: 0xf4000
littlefs_storage:
  address: 0x100000
  device: mx25r16
My understanding is I will need to enable the QSPI flash access in Mcuboot by adding following lines to the file "/child_image/mcuboot/prj.conf"
# SPI Flash
CONFIG_SPI=y
CONFIG_NORDIC_QSPI_NOR=y
Then write the firmware update file "app_update.bin" in the external NOR flash partition "mcuboot_secondary". File packets will be received over UART and then written via flash write operation. Once file write is complete I will need to restart the SOC.
Is my understanding correct? Also, will I need to update any other flag or message to start firmware update on reboot?
Many Thanks
  • I tried to compile the sample https://github.com/simon-iversen/sdk-zephyr/tree/serial_dfu_ext_flash_hello_world/samples/hello_world  provided reference in devzone.nordicsemi.com/.../ncs-dfu
    I modified it to use it with secure boot "CONFIG_SECURE_BOOT=y" and external flash. Also the compile with ncs V2.2.0. Issue is still there. I am getting a compilation error as described above.
    error: 'PM_MCUBOOT_PRIMARY_1_ADDRESS' undeclared
  • Adding changes as per suggested in above links. The issue related to PM_MCUBOOT_PRIMARY_1_ADDRESS is resolved. But now I am facing following error.
    C:/Users/Dilawar_Ali/ncs/v2.2.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c: In function 'boot_read_image_header_hook':
    C:\Users\Dilawar_Ali\ncs\v2.2.0\nrf\modules\mcuboot\hooks\nrf53_hooks.c:29:41: error: 'PM_CPUNET_APP_SIZE' undeclared (first use in this function)
       29 |                 img_head->ih_img_size = PM_CPUNET_APP_SIZE;
    C:\Users\Dilawar_Ali\ncs\v2.2.0\nrf\modules\mcuboot\hooks\nrf53_hooks.c:29:41: note: each undeclared identifier is reported only once for each function it appears in
    C:/Users/Dilawar_Ali/ncs/v2.2.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c: In function 'network_core_update':
    C:\Users\Dilawar_Ali\ncs\v2.2.0\nrf\modules\mcuboot\hooks\nrf53_hooks.c:98:34: error: 'PM_CPUNET_B0N_ADDRESS' undeclared (first use in this function)
       98 |                 if (reset_addr > PM_CPUNET_B0N_ADDRESS) {
    [165/283] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [166/283] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [167/283] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    I am trying to compile the Hello World example https://github.com/simon-iversen/sdk-zephyr/tree/serial_dfu_ext_flash_hello_world/samples/hello_world to make the secure boot work with external flash.
    This is the prj.conf
    # nothing here
    # Enable mcumgr.
    CONFIG_MCUMGR=y
    # Enable most core commands.
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Enable the serial mcumgr transport.
    CONFIG_MCUMGR_SMP_UART=y
    # Disable UART Console and enable the RTT console
    CONFIG_UART_CONSOLE=n
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    # Some command handlers require a large stack.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
    This is cihild_image/mcuboot/prj.conf
    # MCUboot requires a large stack size, otherwise an MPU fault will occur
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # Enable flash operations
    CONFIG_FLASH=y
    # This must be increased to accommodate the bigger images.
    CONFIG_BOOT_MAX_IMG_SECTORS=256
    CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
    # The following configurations are required to support simultaneous multi image update
    CONFIG_PCD_APP=n
    CONFIG_UPDATEABLE_IMAGE_NUMBER=2
    CONFIG_FLASH_SIMULATOR=y
    CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
    CONFIG_FLASH_SIMULATOR_STATS=n
    CONFIG_BOOT_UPGRADE_ONLY=y
    This is pm_static.yml
    external_flash:
      address: 0x0
    mcuboot_secondary:
      address: 0x00000
      device: mx25r16
      end_address: 0xFFFFF
    mcuboot_primary_1:
      address: 0x0
      device: flash_ctrl
      region: ram_flash
    mcuboot_secondary_1:
      address: 0x100000
      device: mx25r16
    pcd_sram:
      address: 0x20000000
      region: sram_primary
    After build (ended with error) following build/partitions.yml was generated
    EMPTY_0:
      address: 0x18200
      end_address: 0x1c000
      placement:
        before:
        - s1_pad
      region: flash_primary
    EMPTY_1:
      address: 0x2c200
      end_address: 0x30000
      placement:
        before:
        - mcuboot_pad
    app:
      address: 0x30200
      end_address: 0x100000
    app_image:
      address: 0x30200
      orig_span: &id001
      - app
      span: *id001
    b0:
      address: 0x0
      end_address: 0x8000
      placement:
        after:
        - start
    b0_container:
      address: 0x0
      end_address: 0x8000
      orig_span: &id002
      - b0
      span: *id002
    external_flash:
      address: 0x0
    mcuboot:
      address: 0x8200
      end_address: 0x18200
      placement:
        before:
        - mcuboot_primary
      sharers: 0x1
    mcuboot_pad:
      address: 0x30000
      end_address: 0x30200
      placement:
        align:
          start: 0x4000
        before:
        - mcuboot_primary_app
      sharers: 0x2
    mcuboot_primary:
      address: 0x30000
      orig_span: &id003
      - app
      - mcuboot_pad
      span: *id003
    mcuboot_primary_1:
      address: 0x0
      device: flash_ctrl
      end_address: 0x40000
      region: ram_flash
    mcuboot_primary_app:
      address: 0x30200
      orig_span: &id004
      - app
      span: *id004
    mcuboot_secondary:
      address: 0x0
      device: mx25r16
      address: 0x100000
      device: mx25r16
      end_address: 0x140000
    otp:
      address: 0xff8380
      end_address: 0xff83fc
      region: otp
    pcd_sram:
      address: 0x20000000
      end_address: 0x20002000
    provision:
      address: 0xff8100
      end_address: 0xff8380
      region: otp
    ram_flash:
      address: 0x40000
      region: ram_flash
    s0:
      address: 0x8000
      orig_span: &id005
      - s0_pad
      - mcuboot
      span: *id005
    s0_image:
      address: 0x8200
      orig_span: &id006
      - mcuboot
      span: *id006
    s0_pad:
      address: 0x8000
      end_address: 0x8200
      placement:
        after:
        - b0_container
        align:
          start: 0x4000
      share_size:
      - mcuboot_pad
    s1:
      address: 0x1c000
      end_address: 0x2c200
      orig_span: &id007
      - s1_pad
      - s1_image
      span: *id007
    s1_image:
      address: 0x1c200
      placement:
        after:
        - s1_pad
        - s0
      share_size:
      - mcuboot
    s1_pad:
      address: 0x1c000
      end_address: 0x1c200
      placement:
        after:
        - s0
        align:
          start: 0x4000
      share_size:
      - mcuboot_pad
    sram_primary:
      address: 0x20002000
      end_address: 0x20080000
    Try setting
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    Also the discussions in this post here seems relevant for your use-case:
  • setting CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y did not resolve the issue. Still facing the error "error: 'PM_CPUNET_APP_SIZE' undeclared"
    But Setting the CONFIG_BOOT_IMAGE_ACCESS_HOOKS=n and removed the primary_1 and secondary_1 partition. This way I am able to do DFU update for app core from external flash and secure boot enabled.
    I still need assistance to enable netcore image update as well.
