nrf52832 OTA over ESB based on SDK17.1.0
Hi everyone:    I developed an application based on ESB wireless communication protocol ofr the nRF52832, and I would like to perform an OTA DFU with it.    Do you know any example of some over the air FW upgrade of nRF52832 chip via ESB protocol.
    SDK is 17.1.0.
Lurn.
  • Hi Edvin,
    For my application, How could I modify the address? I don't know where the softdevice end address is.
    The ble bootloader debug address is here.
    and the application address is here.
    and if I use ble bootloader do i still need to program the mbr.hex?
    Lurn
    The bootloader address settings you can leave as is, but you need to adjust the flash (IROM1) address and size for your application.
    Assuming you are still using SDK17.1.0, and a BLE bootloader, I assume you are using s132_nrf52_7.2.0_softdevice.hex. Just look at any of the samples using the same softdevice, such as the ble_app_hrs\pca10040\s132\ and open the project settings. You should see that it uses start address 0x26000, and size 0x5A000.
    Strictly speaking, we don't have a size of 5A000, because the bootloader takes up address 0x71000 to 0x80000, so you can set start address 0x26000 and size 0x4B000
    But it wouldn't be an issue unless your application is so big that it starts growing into your bootloader.
    The IRAM1 settings (RAM settings) you can leave as is. The softdevice requires 8 bytes (the same as MBR) if you do not enable it in your application.
    No, if you program the softdevice, you don't need to program the mbr.hex. The MBR is merged into the softdevice.
    Edvin
  • Hi Edvin,
    I use the bootloader_ble_s132_pca10040_debug to build the bootloader.
    Then I use this cmd to program it.
    nrfutil settings generate --family NRF52 --application app.hex --application-version 0 --bootloader-version 0 --bl-settings-version 2 settings.hex
    nrfjprog --eraseall -f NRF52
    nrfjprog --program s132_nrf52_7.2.0_softdevice.hex --verify -f NRF52
    nrfjprog --program bootloader.hex --verify -f NRF52
    nrfjprog --program app.hex --verify -f NRF52
    nrfjprog --program settings.hex --verify -f NRF52
    nrfjprog --reset -f NRF52
    I set the application start address to 0x26000 adn size is 0x4B000, Since I'm not using bluetooth just ESB in my application, no other modifications about the RAM/ROM.
    To enter the DFU mode, I use the NRF_POWER_GPREGRET register.
    #define BOOTLOADER_DFU_GPREGRET_MASK                 (0xF8)      /**< Mask for GPGPREGRET bits used for the magic pattern written to GPREGRET register to signal between main app and DFU. */
    #define BOOTLOADER_DFU_GPREGRET                      (0xB0)      /**< Magic pattern written to GPREGRET register to signal between main app and DFU. The 3 lower bits are assumed to be used for signalling purposes.*/
    #define BOOTLOADER_DFU_START_BIT_MASK                (0x01)      /**< Bit mask to signal from main application to enter DFU mode using a buttonless service. */
    #define BOOTLOADER_DFU_START    (BOOTLOADER_DFU_GPREGRET | BOOTLOADER_DFU_START_BIT_MASK)      /**< Magic number to signal that bootloader should enter DFU mode because of signal from Buttonless DFU in main app.*/
    static void enter_dfu_mode(void)
        uint8_t old_gpregret = nrf_power_gpregret_get();
        UART_PRINTF("get the old_gpregret = %d", old_gpregret);
        uint8_t temp = 0;
        nrf_power_gpregret_set(BOOTLOADER_DFU_START);
        while((temp & BOOTLOADER_DFU_START) != BOOTLOADER_DFU_START)
            temp = nrf_power_gpregret_get();
            UART_PRINTF("temp = %d", temp);
        UART_PRINTF("nrf_pwr_mgmt_shutdown NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU and system reset.");
        nrf_delay_ms(10);
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
        NVIC_SystemReset();
    I get the log over RTT shows "nrf_pwr_mgmt_shutdown NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU and system reset", then I reconnect the RTT it shows
    00> In nrf_bootloader_init
    00> Calling nrf_dfu_settings_init()...
    00> Initializing nrf_fstorage_nvmc backend.
    00> Using settings page.
    00> Copying forbidden parts from backup page.
    00> Destination settings are identical to source, write not needed. Skipping.
    00> Backing up settings page to address 0x7E000.
    00> Enter nrf_bootloader_fw_activate
    00> No firmware to activate.
    00> CRC check of app failed. Return 1
    00> App is valid
    00> DFU mode requested via GPREGRET.
    00> WDT is not enabled
    00> in weak nrf_dfu_init_user
    00> timer_stop (0x20005980)
    00> timer_activate (0x20005980)
    00> Entering DFU mode.
    00> Initializing transports (found: 1)
    00> Initializing BLE DFU transport
    00> Setting up vector table: 0x00071000
    00> Enabling SoftDevice.
    00> State request: 0x00000000
    00> Notify observer 0x0007C9E8 => ready
    00> State change: 0x00000000
    but I can't find the ble name via nrf_connect on my phone. I didn't change the name, so the name should be "DfuTarg"
    #ifndef NRF_DFU_BLE_ADV_NAME
    #define NRF_DFU_BLE_ADV_NAME "DfuTarg"
    Can you please tell me where I am wrong?
    Lurn
  • Hello Lurn,
    NRF_DFU_BLE_REQUIRES_BONDS is set to 0 in your bootloader's sdk_config.h file, right?
    If it is not set to 0, try to set it to 0. If it is set to 0, please try to debug ble_dfu_transport_init() in nrf_dfu_ble.c.
    Does the line:
    if (nrf_dfu_settings_adv_name_is_valid())
    return true? (you can simply add a log line using NRF_LOG_INFO(); and it will pop up in the log that you pasted)).
    Also check if the line:
        if ((m_flags & DFU_BLE_FLAG_USE_ADV_NAME) != 0)
    in gap_params_init() returns true. If it does, it will use a different advertising name.
    Let us start with those, and take it from there, depending on what you see.
    Edvin
  • Hello Edvin,
    I'm so sorry for finding out that I've entered a misunderstanding.
    Originally I was saying that I need to upgrade via UART, and yes it worked, but But after I finished testing, my colleague told me that we are using ARM architecture, so I can't update my nrf-device by use nrfutil, Because the source code has some libraries that cannot be ported to the host device.
    So I wanted to use the bluetooth update and ask you a lot of questions about it, but when I finished work yesterday and asked my colleague about bluetooth related things ready to debug the bluetooth upgrade, he told me that our host device does not have bluetooth enabled (I Know that our host device has bluetooth, but I don't know it won't be used).
    Sorry for taking up so much of your time with these wrong questions.
    Let me sort out the current situation.
    1. I can enter the DFU mode normally.
    2. I can update success via UART on PC.
    3. I can't port the ntfutil to host device, because it use ARM.
    4. Since 3 is not established, I can't upgrade nrf-device on the host device.
    So I think the question should be how to update nrf-device without ntfutil.
    And I think there is a method like this:
    I can receive the update file and save it to bank1, then enter the DFU mode, it will check and update itself.
    But I don't know how to receive the file and save it to bank1.
    I found an example made by Vidar, but it also used nrfutil.
    Apologies again for the previous question.
    Lurn
