Advertiser not trigger BT_HCI_EVT_LE_SCAN_REQ_RECEIVED event
Hi Sir,
Advertiser modified NCS 2.2.0 multiple_adv_sets on nRF52840-DK.
Set advertisement data and scan response data as below.
static const struct bt_data ad_sync[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR),
	BT_DATA(BT_DATA_NAME_COMPLETE, "ADV_IND", (sizeof("ADV_IND") - 1))
static const struct bt_data sd_sync[] = {
	BT_DATA(BT_DATA_NAME_COMPLETE, "SCAN_RSP", (sizeof("SCAN_RSP") - 1))
static struct bt_le_ext_adv *adv_ext;
static void adv_scanned_cb(struct bt_le_ext_adv *adv,
			     struct bt_le_ext_adv_scanned_info *info)
	bt_addr_le_to_str(info->addr, addr, sizeof(addr));
	printk("scanned[%s]\n",addr);
static const struct bt_le_ext_adv_cb advmy_cb = {
	.scanned = adv_scanned_cb
void main(void)
	int err;
	int blink_status = 0;
	printk("Starting Bluetooth multiple advertising sets example\n");
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	err = bt_le_ext_adv_create(BT_LE_ADV_CONN, &advmy_cb, &adv_ext);
	if (err) {
		printk("Failed to create advertising set\n");
		return ;
	err = bt_le_ext_adv_set_data(adv_ext, ad_sync, ARRAY_SIZE(ad_sync), sd_sync, ARRAY_SIZE(sd_sync));
	if (err) {
		printk("Failed to start advertising set data. Err: %d\n", err);
		return;
	err = bt_le_ext_adv_start(adv_ext, BT_LE_EXT_ADV_START_DEFAULT);
	if (err) {
		printk("Failed to start advertising set. Err: %d\n", err);
		return;
	printk("Connectable advertising started\n");
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
Scanner can receive ADV_IND and SCAN_RSP.
But advertiser doesn't trigger BT_HCI_EVT_LE_SCAN_REQ_RECEIVED event to application.
Please help us to fix it, thank you.
Scanner log is normal.
HL [00:00:02.435,607] <inf> cis_headset: sync_scan_start: sync scanning successfully started
HL [00:00:02.446,807] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:02.447,509] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:02.862,365] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:02.863,067] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:03.296,722] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:03.297,424] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:03.819,122] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:03.819,824] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:04.126,647] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:04.127,349] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:04.439,758] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:04.440,460] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:04.964,324] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:04.965,057] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
HL [00:00:05.276,123] <dbg> cis_headset: device_found: Device found 0 9 7 ADV_IND
HL [00:00:05.276,824] <dbg> cis_headset: device_found: Device found 4 9 8 SCAN_RSP
