[MATTER] Commissioning failed at Google home
Hi Nordic team
- ncs 2.2.0 light bulb/light switch/door lock/window covering samples at application core.
  multiprotocol_rpmsg at network core.
- NRF52840 DK and NRF5340 DK
- Google Net hub 2 ()
- WiFi AP
- Latest Google home apps (2.63.1.12)  at smartphone (Samsung A52s, Android 13)
No matter which DK and which sample, commissioning always failed. Below was log information.
I: Factory Reset Triggered. Release button within 3000ms to cancel.
I: 235726 [TS]Pending Last Known Good Time: 2023-01-09T13:39:51
I: 235732 [TS]Previous Last Known Good Time: 2023-01-09T13:39:51
I: 235737 [TS]Reverted Last Known Good Time to previous value
D: 235743 [ZCL]Emitting ShutDown event
D: 235747 [EVL]LogEvent event number: 0x0000000000000002 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0028 event id: 0x1 Sys timestamp: 0x00000000000398E2
D: 235761 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
I: 235766 [DL]Performing factory reset
I: 235777 [DL]Erasing Thread persistent info...
uart:~$ I: nRF5 802154 radio initialized
I: 4 Sectors of 4096 bytes
I: alloc wra: 0, ab0
I: data wra: 0, 304
*** Booting Zephyr OS build v3.2.99-ncs1 ***
I: Init CHIP stack
I: 168 [DL]BLE address: D4:08:53:4D:E3:C4
I: 191 [DL]OpenThread started: OK
I: 194 [DL]Setting OpenThread device type to ROUTER
I: 198 [SVR]Server initializing...
D: 202 [FP]Initializing FabricTable from persistent storage
I: 207 [TS]Last Known Good Time: [unknown]
I: 211 [TS]Setting Last Known Good Time to firmware build time 2023-01-09T13:39:51
I: 219 [DMG]AccessControl: initializing
I: 223 [DMG]Examples::AccessControlDelegate::Init
I: 227 [DMG]AccessControl: setting
I: 230 [DMG]DefaultAclStorage: initializing
I: 234 [DMG]DefaultAclStorage: 0 entries loaded
D: 238 [IN]UDP::Init bind&listen port=5540
E: 242 [IN]SO_REUSEPORT failed: 109
D: 246 [IN]UDP::Init bound to port=5540
D: 249 [IN]BLEBase::Init - setting/overriding transport
D: 254 [IN]TransportMgr initialized
D: 260 [DL]Using Thread extended MAC for hostname.
I: 266 [ZCL]Using ZAP configuration...
D: 270 [DMG]Failed to read stored attribute (0, 0x0000_0028, 0x0000_0005: a0
D: 278 [DMG]Failed to read stored attribute (1, 0x0000_0006, 0x0000_0000: a0
D: 285 [DMG]Failed to read stored attribute (1, 0x0000_0006, 0x0000_4003: a0
D: 292 [DMG]Failed to read stored attribute (1, 0x0000_0008, 0x0000_0000: a0
D: 299 [DMG]Failed to read stored attribute (1, 0x0000_0008, 0x0000_4000: a0
I: 306 [DMG]AccessControlCluster: initializing
D: 310 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to f46f1c39
D: 316 [DL]Boot reason: 6
D: 319 [ZCL]GeneralDiagnostics: OnDeviceReboot
D: 323 [DMG]Endpoint 0, Cluster 0x0000_0033 update version to 837c9987
D: 330 [EVL]LogEvent event number: 0x0000000000000000 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0033 event id: 0x3 Sys timestamp: 0x0000000000000149
I: 343 [ZCL]Initiating Admin Commissioning cluster.
D: 348 [DMG]Endpoint 1, Cluster 0x0000_0003 update version to 4219a493
D: 354 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to db367b43
D: 361 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to db367b44
I: 367 [ZCL]On/Off set value: 1 0
I: 370 [ZCL]On/off already set to new value
D: 375 [DMG]Endpoint 1, Cluster 0x0000_0008 update version to 6edd45fa
I: 381 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
D: 387 [ZCL]LED is off. Try to use move-to-level-with-on-off instead of move-to-level
D: 396 [IN]SecureSession[0x20004450]: Allocated Type:1 LSID:62705
D: 402 [SC]Assigned local session key ID 62705
D: 406 [SC]Waiting for PBKDF param request
D: 410 [DL]CHIPoBLE advertising set to on
I: 414 [DIS]Updating services using commissioning mode 1
D: 419 [DL]Using Thread extended MAC for hostname.
D: 424 [DL]Using Thread extended MAC for hostname.
I: 429 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 438 [DIS]Failed to advertise commissionable node: 3
E: 442 [DIS]Failed to finalize service update: 1c
I: 447 [DIS]Updating services using commissioning mode 1
D: 452 [DL]Using Thread extended MAC for hostname.
D: 457 [DL]Using Thread extended MAC for hostname.
I: 462 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 471 [DIS]Failed to advertise commissionable node: 3
E: 476 [DIS]Failed to finalize service update: 1c
I: 480 [DIS]Delaying proxy of operational discovery: missing delegate
I: 486 [IN]CASE Server enabling CASE session setups
D: 491 [IN]SecureSession[0x20004508]: Allocated Type:2 LSID:62706
D: 497 [SC]Allocated SecureSession (0x20004508) - waiting for Sigma1 msg
I: 503 [SVR]Joining Multicast groups
D: 507 [ZCL]Emitting StartUp event
D: 510 [EVL]LogEvent event number: 0x0000000000000001 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0028 event id: 0x0 Sys timestamp: 0x00000000000001FE
I: 524 [SVR]Server Listening...
I: 527 [DL]Device Configuration:
I: 530 [DL]  Serial Number: 11223344556677889900
I: 534 [DL]  Vendor Id: 65521 (0xFFF1)
I: 538 [DL]  Product Id: 32773 (0x8005)
I: 541 [DL]  Hardware Version: 0
I: 545 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 550 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 557 [DL]  Manufacturing Date: (not set)
I: 561 [DL]  Device Type: 65535 (0xFFFF)
I: 565 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 569 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 575 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 584 [SVR]Manual pairing code: [34970112332]
I: 589 [DL]CHIP task running
I: 596 [DL]CHIPoBLE advertising started
D: 600 [DMG]Endpoint 1, Cluster 0x0000_0006 update version to 6d9d0caf
I: 607 [ZCL]Cluster OnOff: attribute OnOff set to 0
D: 612 [DMG]Endpoint 1, Cluster 0x0000_0008 update version to 6edd45fb
I: 618 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
D: 624 [ZCL]LED is off. Try to use move-to-level-with-on-off instead of move-to-level
I: 632 [DL]NFC Tag emulation started
I: 30599 [DL]CHIPoBLE advertising mode changed to slow
I: 139286 [DL]BLE connection established (ConnId: 0x00)
I: 139292 [DL]Current number of connections: 1/2
I: 139296 [DL]CHIPoBLE advertising stopped
I: 139300 [DL]NFC Tag emulation stopped
D: 139743 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 139750 [BLE]local and remote recv window sizes = 5
I: 139755 [BLE]selected BTP version 4
I: 139758 [BLE]using BTP fragment sizes rx 128 / tx 128.
D: 139863 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 139867 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 139875 [IN]BLE EndPoint 0x20012d78 Connection Complete
I: 139880 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 131)
D: 139922 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 139931 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 139938 [EM]>>> [E:15520r M:54056484] (U) Msg RX from 0:C507A80039312A2A [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
D: 139950 [EM]Handling via exchange: 15520r, Delegate: 0x20006634
D: 139955 [SC]Received PBKDF param request
D: 139959 [SC]Peer assigned session ID 62938
D: 139963 [SC]Found MRP parameters in the message
D: 139968 [SC]Including MRP parameters in PBKDF param response
I: 139974 [EM]<<< [E:15520r M:27434965] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 139986 [IN](U) Sending msg 27434965 to IP address 'BLE'
D: 139991 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 139999 [SC]Sent PBKDF param response
D: 140043 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 140050 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 14)
D: 140102 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 140111 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 140118 [EM]>>> [E:15520r M:54056485] (U) Msg RX from 0:C507A80039312A2A [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
D: 140129 [EM]Found matching exchange: 15520r, Delegate: 0x20006634
D: 140135 [SC]Received spake2p msg1
I: 141687 [EM]<<< [E:15520r M:27434966] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 141698 [IN](U) Sending msg 27434966 to IP address 'BLE'
D: 141703 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 141711 [SC]Sent spake2p msg2
E: 141714 [DL]Long dispatch time: 1603 ms, for event type 16388
D: 141782 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 141790 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 141842 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 141851 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 141858 [EM]>>> [E:15520r M:54056486] (U) Msg RX from 0:C507A80039312A2A [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
D: 141869 [EM]Found matching exchange: 15520r, Delegate: 0x20006634
D: 141875 [SC]Received spake2p msg3
D: 141879 [SC]Sending status report. Protocol code 0, exchange 15520
I: 141885 [EM]<<< [E:15520r M:27434967] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 141896 [IN](U) Sending msg 27434967 to IP address 'BLE'
D: 141901 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 141910 [SC]SecureSession[0x20004450]: Moving from state 'kEstablishing' --> 'kActive'
D: 141918 [IN]SecureSession[0x20004450]: Activated - Type:1 LSID:62705
D: 141924 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:62705 PSID:62938!
I: 141933 [SVR]Commissioning completed session establishment step
I: 141939 [DIS]Updating services using commissioning mode 0
D: 141944 [DL]Using Thread extended MAC for hostname.
D: 141949 [DL]Using Thread extended MAC for hostname.
I: 141954 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 141964 [DIS]Failed to advertise extended commissionable node: 3
D: 141970 [DIS]Scheduling extended discovery timeout in 900s
E: 141975 [DIS]Failed to finalize service update: 1c
D: 141980 [DL]CHIPoBLE advertising set to off
I: 141984 [SVR]Device completed Rendezvous process
E: 141988 [DL]Long dispatch time: 137 ms, for event type 16388
D: 141994 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142002 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142010 [EM]>>> [E:15521r M:181230691] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142020 [EM]Handling via exchange: 15521r, Delegate: 0x20010744
D: 142026 [IM]Received Read request
D: 142030 [DMG]IM RH moving to [GeneratingReports]
D: 142034 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142043 [DMG]<RE:Run> Cluster 28, Attribute 2 is dirty
D: 142048 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 142057 [DMG]<RE> Sending report (payload has 37 bytes)...
I: 142063 [EM]<<< [E:15521r M:50775145] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142073 [IN](S) Sending msg 50775145 on secure session with LSID: 62705
D: 142080 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 142087 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142092 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142099 [DMG]IM RH moving to [AwaitingDestruction]
D: 142104 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142142 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142151 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142159 [EM]>>> [E:15522r M:181230692] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142169 [EM]Handling via exchange: 15522r, Delegate: 0x20010744
D: 142174 [IM]Received Read request
D: 142178 [DMG]IM RH moving to [GeneratingReports]
D: 142183 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142191 [DMG]<RE:Run> Cluster 28, Attribute 4 is dirty
D: 142197 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0004 (expanded=0)
D: 142206 [DMG]<RE> Sending report (payload has 37 bytes)...
I: 142212 [EM]<<< [E:15522r M:50775146] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142222 [IN](S) Sending msg 50775146 on secure session with LSID: 62705
D: 142228 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 142236 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142240 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142248 [DMG]IM RH moving to [AwaitingDestruction]
D: 142252 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142292 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142301 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142309 [EM]>>> [E:15523r M:181230693] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142319 [EM]Handling via exchange: 15523r, Delegate: 0x20010744
D: 142325 [IM]Received Read request
D: 142328 [DMG]IM RH moving to [GeneratingReports]
D: 142333 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142342 [DMG]<RE:Run> Cluster 3e, Attribute 2 is dirty
D: 142347 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 142356 [DMG]<RE> Sending report (payload has 36 bytes)...
I: 142362 [EM]<<< [E:15523r M:50775147] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142372 [IN](S) Sending msg 50775147 on secure session with LSID: 62705
D: 142378 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 142386 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142390 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142398 [DMG]IM RH moving to [AwaitingDestruction]
D: 142402 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142442 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142451 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142459 [EM]>>> [E:15524r M:181230694] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142469 [EM]Handling via exchange: 15524r, Delegate: 0x20010744
D: 142474 [IM]Received Read request
D: 142478 [DMG]IM RH moving to [GeneratingReports]
D: 142483 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142491 [DMG]<RE:Run> Cluster 3e, Attribute 3 is dirty
D: 142497 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0003 (expanded=0)
D: 142506 [DMG]<RE> Sending report (payload has 36 bytes)...
I: 142512 [EM]<<< [E:15524r M:50775148] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142522 [IN](S) Sending msg 50775148 on secure session with LSID: 62705
D: 142528 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 142536 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142540 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142548 [DMG]IM RH moving to [AwaitingDestruction]
D: 142552 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142592 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142601 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142609 [EM]>>> [E:15525r M:181230695] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142619 [EM]Handling via exchange: 15525r, Delegate: 0x20010744
D: 142625 [IM]Received Read request
D: 142628 [DMG]IM RH moving to [GeneratingReports]
D: 142633 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142642 [DMG]<RE:Run> Cluster 3e, Attribute 1 is dirty
D: 142647 [DMG]Reading attribute: Cluster=0x0000_003E Endpoint=0 AttributeId=0x0000_0001 (expanded=0)
D: 142656 [DMG]<RE> Sending report (payload has 36 bytes)...
I: 142662 [EM]<<< [E:15525r M:50775149] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142672 [IN](S) Sending msg 50775149 on secure session with LSID: 62705
D: 142678 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 142686 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142690 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142698 [DMG]IM RH moving to [AwaitingDestruction]
D: 142702 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142742 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142751 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 142759 [EM]>>> [E:15526r M:181230696] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 142769 [EM]Handling via exchange: 15526r, Delegate: 0x20010744
D: 142774 [IM]Received Read request
D: 142778 [DMG]IM RH moving to [GeneratingReports]
D: 142783 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 142791 [DMG]<RE:Run> Cluster 1d, Attribute 1 is dirty
D: 142797 [DMG]Reading attribute: Cluster=0x0000_001D Endpoint=0 AttributeId=0x0000_0001 (expanded=0)
D: 142806 [DMG]<RE> Sending report (payload has 400 bytes)...
I: 142814 [EM]<<< [E:15526r M:50775150] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 142824 [IN](S) Sending msg 50775150 on secure session with LSID: 62705
D: 142831 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 142838 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 142843 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 142850 [DMG]IM RH moving to [AwaitingDestruction]
D: 142855 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 142893 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142900 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 142953 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 142960 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 143013 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 143020 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 57)
D: 143073 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 143081 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 143133 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 143141 [EM]>>> [E:15527r M:181230697] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 143151 [EM]Handling via exchange: 15527r, Delegate: 0x20010744
D: 143157 [IM]Received Read request
D: 143161 [DMG]IM RH moving to [GeneratingReports]
D: 143165 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 143174 [DMG]<RE:Run> Cluster 31, Attribute fffc is dirty
D: 143179 [DMG]Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_FFFC (expanded=0)
D: 143188 [DMG]<RE> Sending report (payload has 37 bytes)...
I: 143194 [EM]<<< [E:15527r M:50775151] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 143204 [IN](S) Sending msg 50775151 on secure session with LSID: 62705
D: 143211 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
D: 143218 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 143223 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 143230 [DMG]IM RH moving to [AwaitingDestruction]
D: 143235 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 143253 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144243 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 144251 [EM]>>> [E:15528r M:181230698] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest)
D: 144261 [EM]Handling via exchange: 15528r, Delegate: 0x20010744
D: 144267 [DMG]Got Timed Request with timeout 10000: handler 0x20010b40 exchange 15528r
I: 144275 [EM]<<< [E:15528r M:50775152] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:01 (IM:StatusResponse)
I: 144285 [IN](S) Sending msg 50775152 on secure session with LSID: 62705
D: 144292 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 144300 [DMG]Timed Request time limit 0x0000000000025ABC: handler 0x20010b40 exchange 15528r
D: 144392 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144400 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 144408 [EM]>>> [E:15528r M:181230699] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 144419 [EM]Found matching exchange: 15528r, Delegate: 0x20010b40
D: 144425 [DMG]Timed following action arrived at 0x0000000000023429: handler 0x20010b40 exchange 15528r
D: 144434 [DMG]Handing timed invoke to IM engine: handler 0x20010b40 exchange 15528r
D: 144442 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
I: 144450 [FS]GeneralCommissioning: Received ArmFailSafe (120s)
D: 144456 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to f46f1c3a
D: 144462 [DMG]Command handler moving to [ Preparing]
D: 144467 [DMG]Command handler moving to [AddingComm]
D: 144472 [DMG]Command handler moving to [AddedComma]
D: 144477 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 144484 [EM]<<< [E:15528r M:50775153] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 144495 [IN](S) Sending msg 50775153 on secure session with LSID: 62705
D: 144501 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 144509 [DMG]Command handler moving to [CommandSen]
D: 144514 [DMG]Command handler moving to [AwaitingDe]
E: 144519 [DL]Long dispatch time: 118 ms, for event type 16388
D: 144543 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144551 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 144559 [EM]>>> [E:15529r M:181230700] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 144569 [EM]Handling via exchange: 15529r, Delegate: 0x20010744
D: 144575 [IM]Received Read request
D: 144579 [DMG]IM RH moving to [GeneratingReports]
D: 144583 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 144592 [DMG]<RE:Run> Cluster 30, Attribute 3 is dirty
D: 144597 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0003 (expanded=0)
D: 144606 [DMG]<RE> Sending report (payload has 36 bytes)...
I: 144612 [EM]<<< [E:15529r M:50775154] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 144622 [IN](S) Sending msg 50775154 on secure session with LSID: 62705
D: 144628 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 144636 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 144641 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 144648 [DMG]IM RH moving to [AwaitingDestruction]
D: 144653 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 144722 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144731 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 144738 [EM]>>> [E:15530r M:181230701] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest)
D: 144749 [EM]Handling via exchange: 15530r, Delegate: 0x20010744
D: 144755 [DMG]Got Timed Request with timeout 10000: handler 0x20010b40 exchange 15530r
I: 144763 [EM]<<< [E:15530r M:50775155] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:01 (IM:StatusResponse)
I: 144773 [IN](S) Sending msg 50775155 on secure session with LSID: 62705
D: 144780 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
D: 144787 [DMG]Timed Request time limit 0x0000000000025CA3: handler 0x20010b40 exchange 15530r
D: 144857 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 144866 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 144874 [EM]>>> [E:15530r M:181230702] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 144885 [EM]Found matching exchange: 15530r, Delegate: 0x20010b40
D: 144891 [DMG]Timed following action arrived at 0x00000000000235FB: handler 0x20010b40 exchange 15530r
D: 144900 [DMG]Handing timed invoke to IM engine: handler 0x20010b40 exchange 15530r
D: 144908 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002
D: 144918 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to f46f1c3b
D: 144924 [DMG]Command handler moving to [ Preparing]
D: 144929 [DMG]Command handler moving to [AddingComm]
D: 144934 [DMG]Command handler moving to [AddedComma]
D: 144939 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 144946 [EM]<<< [E:15530r M:50775156] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 144957 [IN](S) Sending msg 50775156 on secure session with LSID: 62705
D: 144964 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 144971 [DMG]Command handler moving to [CommandSen]
D: 144976 [DMG]Command handler moving to [AwaitingDe]
E: 144981 [DL]Long dispatch time: 115 ms, for event type 16388
D: 145037 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145046 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 145054 [EM]>>> [E:15531r M:181230703] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 145065 [EM]Handling via exchange: 15531r, Delegate: 0x20010744
D: 145071 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 145079 [ZCL]OpCreds: Certificate Chain request received for DAC
D: 145084 [DMG]Command handler moving to [ Preparing]
D: 145089 [DMG]Command handler moving to [AddingComm]
D: 145094 [DMG]Command handler moving to [AddedComma]
D: 145099 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 145108 [EM]<<< [E:15531r M:50775157] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 145119 [IN](S) Sending msg 50775157 on secure session with LSID: 62705
D: 145126 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145134 [DMG]Command handler moving to [CommandSen]
D: 145138 [DMG]Command handler moving to [AwaitingDe]
D: 145218 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145225 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145308 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145315 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145398 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145405 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145488 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145496 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 145503 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 57)
D: 145577 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145586 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 145594 [EM]>>> [E:15532r M:181230704] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 145605 [EM]Handling via exchange: 15532r, Delegate: 0x20010744
D: 145611 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 145618 [ZCL]OpCreds: Certificate Chain request received for PAI
D: 145624 [DMG]Command handler moving to [ Preparing]
D: 145629 [DMG]Command handler moving to [AddingComm]
D: 145634 [DMG]Command handler moving to [AddedComma]
D: 145639 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 145648 [EM]<<< [E:15532r M:50775158] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 145659 [IN](S) Sending msg 50775158 on secure session with LSID: 62705
D: 145666 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145673 [DMG]Command handler moving to [CommandSen]
D: 145678 [DMG]Command handler moving to [AwaitingDe]
D: 145758 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145765 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145848 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145855 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 145982 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 145990 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146073 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146081 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 146088 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 28)
D: 146207 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146216 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 146224 [EM]>>> [E:15533r M:181230705] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 146235 [EM]Handling via exchange: 15533r, Delegate: 0x20010744
D: 146241 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0000
I: 146249 [ZCL]OpCreds: Received an AttestationRequest command
I: 146283 [ZCL]OpCreds: AttestationRequest successful.
D: 146288 [DMG]Command handler moving to [ Preparing]
D: 146293 [DMG]Command handler moving to [AddingComm]
D: 146298 [DMG]Command handler moving to [AddedComma]
D: 146303 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 146313 [EM]<<< [E:15533r M:50775159] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 146324 [IN](S) Sending msg 50775159 on secure session with LSID: 62705
D: 146331 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146338 [DMG]Command handler moving to [CommandSen]
D: 146343 [DMG]Command handler moving to [AwaitingDe]
E: 146348 [DL]Long dispatch time: 132 ms, for event type 16388
D: 146388 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146395 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146478 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146485 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146568 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146575 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146658 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146666 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 146673 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 146748 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146755 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 90)
D: 146837 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 146846 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 146854 [EM]>>> [E:15534r M:181230706] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 146865 [EM]Handling via exchange: 15534r, Delegate: 0x20010744
D: 146871 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0004
I: 146879 [ZCL]OpCreds: Received a CSRRequest command
D: 146884 [ZCL]OpCreds: Finding fabric with fabricIndex 0x0
I: 147048 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 147083 [ZCL]OpCreds: CSRRequest successful.
D: 147087 [DMG]Command handler moving to [ Preparing]
D: 147092 [DMG]Command handler moving to [AddingComm]
D: 147097 [DMG]Command handler moving to [AddedComma]
D: 147102 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 147110 [EM]<<< [E:15534r M:50775160] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 147121 [IN](S) Sending msg 50775160 on secure session with LSID: 62705
D: 147128 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 147135 [DMG]Command handler moving to [CommandSen]
D: 147140 [DMG]Command handler moving to [AwaitingDe]
E: 147145 [DL]Long dispatch time: 299 ms, for event type 16388
D: 147198 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147205 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 147288 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147295 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
D: 147378 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
I: 148952 [DL]BLE GAP connection terminated (reason 0x13)
D: 148958 [IN]Clearing BLE pending packets.
I: 148962 [DL]Current number of connections: 0/2
Jeff
  • I've queried the developers once again to see if they have heard anything since last time and to ask if they have any thoughts about why their test (with the parameters I mentioned) worked, while yours does not work.
    Jeffery said:
    At nrf Connect SDK documentation, Nordic likes to use Raspberry-Pi with CHIP-TOOL as a Matter controller and board router.
    However, for me or for most users, it took time to install software and familiar with CHIP-TOOL.
    Since Nordic solution was only for Matter device but not hub or gateway, why not to test commercial hub (like Google/Apple hubs) directly?
    One of the reasons for why the Rasoberry-Pi OpenThread Boarder-Router and CHIP-TOOL is the solution we're using is due to the amount of control we have over the router while we're testing. Using other proprietary, commercial solutions are limited w.r.t. debugging and having control over the features you want to implement which in turn will lead to restrictions for how far we're able to go w.r.t. give support to developers.
    Jeffery said:
    How about your comment? Or, at mass production stage or QA testing, we can deploy CHIP-TOOL router as testing tool?
    Yes, you should be able to use a RPI OpenThread Boarder Router while testing if this is what you were asking.
    Andreas
    Some more information from the developers:
    Recently we saw similar behavior as described in point no. 1. As a workaround we re-enabled BLE on our Android Phone and that issue was gone. We don't have any more details about that, as we haven't seen the issue again after that. In addition the answers in the google tickets are currently the best answers we have at this point in time.
    In addition to the workaround mentioned above, we also suggest you to attempt to test this with another phone to check if the issue still exists. If it works with Samsung SmartThings (using the same phone) it means that there may be still something wrong with GHA and not with our SoC.
    Unfortunately we don't think this is a Nordic related issue, so we would like to recommend you to fill in the issue on the public issue tracker as well: https://developers.home.google.com/matter/support
    Andreas
  • Hi AHaug
    I used another Android phone (Google Pixel4). The issue was same.
    Home apps terminated BLE connection during commissioning process.
    If you was informed some information about Google, please kindly let me know.
    Jeff
  • Noted, I will communicate that the issue is present with different phones as well.
    Did the workaround fix anything for you?
    I will inform you if we get any information about the Google related issue as soon as I get it
    Andreas
  • Hi AHaug
    Google home apps was updated from 2.63.1.12 to 2.65.1.6.
    I have tried new version if solving the commissioning issue.
    New version can find Matter device and start commissioning.
    It still terminate BLE connection but telling me the reason.
    The reason was the device was not Matter qualified (No authorized DAC).
    It was different to Samsung SmartThings. SmartThings allowed non Matter qualified device.
    Did Nordic or Matter provide developer with test purposed DAC/PAI/...?
    Thanks.
    Jeff
