Hello:
Does the nrf52 radio peripheral EasyDMA write to PACKETPTR on byte boundaries or does it write "bits"? Suppose I have the ADDRESS_BCSTART shortcut enabled and the radio is all set up to receive. Lets say I have the BCC set to 4 (4 bits). Upon receiving 4 bits I should get the BCMATCH event. At this point, can I read the first byte of the RAM where PACKETPTR is pointing or do I need to wait until a whole byte is received? I presume I can read the RAM where PACKETPTR is pointing during reception of a frame.
One other question: assume I have started BCSTART (shortcut ADDRESS_BCSTART was set) and the radio is receiving a packet. Assume that when the reception started the bit counter was programmed to some large value (say 2048 bits). After receiving 100 bits I go ahead and set BCC to 48. Will this generate the BCMATCH event immediately or not at all? Asssume that the packet length is much greater than 100 bits (in case that matters).
Thanks!
