1: In TX mode, according to the example input instruction, set +4dbm, the test to the peak power is -19dbm, according to the example input instruction, set +19dbm, the test to the peak power is -15dbm?
2: In TX mode, according to the instructions in the example, there are only channels 11 and 14. Can other 2.4GHZ channels and 5G channels be tested?
3: connected with VSG, input the instructions of the example, what is the meaning of the data captured by RX in the example? Whether the software needs to be set to open the output print log to see
4: Now the instructions given on the official website are still relatively few, can you output an instruction set file or do a type of Bluetooth DTM debugging tool?
use nrf7002DK
