5340 protect programs from theft
Hello
NCS2.0.2, nRF5340, VScode
when download hex to 5340.
how to read out it?
and how to prohibit read out?
protect programs from theft.
Best regards
  • Hi
    in CmakeLists.txt  add:
    zephyr_compile_definitions_ifdef(CONFIG_NRF_APPROTECT_LOCK
    ENABLE_APPROTECT)
    zephyr_compile_definitions_ifdef(CONFIG_NRF_APPROTECT_USER_HANDLING
    ENABLE_APPROTECT_USER_HANDLING)
    zephyr_compile_definitions_ifdef(CONFIG_NRF_SECURE_APPROTECT_LOCK
    ENABLE_SECURE_APPROTECT)
    zephyr_compile_definitions_ifdef(CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING
    ENABLE_SECURE_APPROTECT_USER_HANDLING)
    zephyr_library_compile_definitions_ifdef(CONFIG_NRF_TRACE_PORT
    ENABLE_TRACE)
    int prj.conf add:
    CONFIG_NRF_APPROTECT_LOCK=y
    in main top call  nrf_debug_port_disable()
    void nrf_nvmc_write_word(uint32_t address, uint32_t value)
    	// Enable flash write access and wait until the NVMC is ready
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy) {;}
        // Write to the register and wait until the NVMC is ready
        *(uint32_t*)address = value;
    	// Disable flash write access and wait until the NVMC is ready
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
    void nrf_debug_port_disable(void)
    	if(NRF_UICR->APPROTECT&0x000000ff)
    		printk("\nAccess Port Protection is not enabled --> Enable Access Port Protection now\n");
    		/* Enable Access Port Protection
    		 * Access through debugger to CPU registers, mapped-memory and RAM will be disabled
    		 * To disable protection ERASEALL command must be applied. */
    		nrf_nvmc_write_word((uint32_t)&NRF_UICR->APPROTECT, NRF_UICR->APPROTECT&0xffffff00);
    		printk("Access Port Protection is now enabled --> Reboot to apply the config...\n");
    		// Sleep is only necessary to show the logs before reboot for debug purposes
    		k_msleep(2000);
    		//NVIC_SystemReset();
    		sys_reboot(SYS_REBOOT_COLD);
    		printk("\nAccess Port Protection is already enabled\n");
    Could you please confirm my understanding?
    Best regards
  • Hi
    ok, now
    nrf5340dk_nrf5340_cpuapp
    i only add tow line to prj.conf
    CONFIG_NRF_SECURE_APPROTECT_LOCK=y
    Best regards
    Have you tried it and does this solve your issue?
    -Priyanka
  • Hi
    test it on nRF5340-DK
    when no call  nrf_debug_port_disable()
    when call   nrf_debug_port_disable()  (even no
    CONFIG_NRF_APPROTECT_LOCK=y in prj.conf  and
    ENABLE_APPROTECT  in CMakeLists.txt
    Best regards
