nRF52840 dongle, NRF_ERROR_SD_RPC_SEND issue
hi
I am trying to verify BLE between a PC and a development product using the nRF52840 dongle.
After installing pc-ble-driver-py, I checked the basic operation of the dongle by using nrf-ble-driver's "heart_rate_monitor_sd_api_v6.exe".
Now, I ran the code below to check communication with the development product.
def main(selected_serial_port):
    print("Serial port used: {}".format(selected_serial_port))
    driver = BLEDriver(
        serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
    adapter = BLEAdapter(driver)
    collector = EOPatchTester(adapter)
    collector.open()
    conn = collector.connect_and_discover()
    if conn is not None:
        for i in range(1, total_test_case + 1):
            if collector.run_test_case(i) is not None :
                break
    collector.test_report()
    collector.close()
But the sacn fails with the error message below.
What did I do wrong?
help. thank you
