I want to use timer0 to get exact time delay (without soft device used).
Timer0 configuration is as
void timer0_initialization(void)
NRF_TIMER0->MODE = TIMER_MODE_MODE_Timer;
NRF_TIMER0->PRESCALER = 0;
NRF_TIMER0->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
NRF_TIMER0->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
NRF_TIMER0->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;
NRF_TIMER0->TASKS_STOP = 1;
the test main function is as
uint32_t i;
uint32_t time_capture[10];
/* UART and RTC0 initialization */
printf ("---------------------------------- Start ---------------------------------- \r\n");
timer0_initialization( );
NRF_TIMER0->CC[0] = 1000 * 16;
NRF_TIMER0->TASKS_START = 1;
for (i=0; i<10; i++)
NRF_TIMER0->EVENTS_COMPARE[0] = 0;
time_capture[i] = NRF_RTC0->COUNTER;
while (NRF_TIMER0->EVENTS_COMPARE[0] == 0)
/* delay 1ms */
for (i=1; i<10; i++)
printf("i = %ld, time delay = %ld, \r\n", i, time_capture[i] - time_capture[i - 1]);
while(1);
Since RTC0's frequency is 32K, so the output of "printf" time delay should be about 30 (1000/32.768), moreover, each time delay should be the same. However, the first time delay is much difference than others. the output of above code is like
---------------------------------- Start ---------------------------------------
i = 1, time delay = 8,
i = 2, time delay = 34,
i = 3, time delay = 34,
i = 4, time delay = 34,
i = 5, time delay = 34,
i = 6, time delay = 34,
i = 7, time delay = 34,
i = 8, time delay = 34,
i = 9, time delay = 34,
If add some time daly right after timer0 started like
/* add some time delay */
nrf_delay_ms(10);
The program output is like
i = 1, time delay = 0,
The first time delay is 0, means no any time delay.
For "nrf_delay_ms(100);", "nrf_delay_ms(1000);", "nrf_delay_ms(2000);", the output are like following:
i = 1, time delay = 2,
i = 1, time delay = 27,
i = 2, time delay = 32,
i = 3, time delay = 33,
i = 4, time delay = 32,
i = 5, time delay = 33,
i = 6, time delay = 32,
i = 7, time delay = 33,
i = 8, time delay = 32,
i = 9, time delay = 33,
i = 1, time delay = 21,
i = 2, time delay = 33,
i = 3, time delay = 32,
i = 4, time delay = 33,
i = 5, time delay = 32,
i = 6, time delay = 33,
i = 7, time delay = 32,
i = 8, time delay = 33,
i = 9, time delay = 32,
It seems the first time delay is a random number. These result is obtained from nRF52832 preview DK board, the similar result is obtain with nRF51822 board.
How to understand this results of timer0? is there any bug in my code?
Thanks a lot!
