"Unhandled data received from nRF Cloud"
Hello Nordic and fellow developers!
After migrating to NCS 2.2.0, I got some new and exciting error messages in my application. They are related to nRFCloud usage.
Whenever I receive data from the cloud, I get these errors. The seemingly do not affect anything, as everything still works as it should. But I fear I might be doing something wrong, or that the libraries are doing something wrong.
The following log snippet is from connecting to the cloud and requesting agps data:
[00:00:13.422,729] [<inf> voqdr: NRF_MODEM_GNSS_EVT_AGPS_REQ
[00:00:13.428,741] [<inf> voqdr: Assistance data needed, ephe 0xffffffff, alm 0xffffffff, flags 0x3b
[00:00:13.438,537] [<inf> voqdr: Connecting to LTE network
[00:00:13.444,885] [<inf> voqdr: reg_status: 1
[00:00:13.449,645] [<inf> voqdr: The device is already registered with an LTE network
[00:00:13.457,824] [<inf> voqdr: Connecting to nRF Cloud
[00:00:13.464,599] [<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
[00:00:15.985,870] [<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED
[00:00:16.572,906] [<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_RX_DATA_SHADOW
[00:00:16.580,780] [<dbg> voqdr: cloud_event_handler: 287 bytes received from cloud
[00:00:16.588,867] [1;31m<err> voqdr: json_from_cloud: {"desired":{"pairing":{"state":"paired","topics":{"d2c":"prod/xx/m/d/dev-imei/d2c","c2d":"prod/xx/m/d/dev-imei/+/r"}},"nrfcloud_mqtt_topic_prefix":"prod/xx/"}}
[00:00:16.635,559] <dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED
[00:00:17.173,706] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.
[00:00:17.181,854] <inf> nrf_cloud_codec: Ensure device firmware is up to date.
[00:00:17.189,605] <inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.
[00:00:17.199,279] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2
[00:00:17.207,489] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 8, type: 3
[00:00:17.214,996] [1;31m<err> nrf_cloud_transport: nct_input: failed -2
[00:00:17.293,792] <dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_READY
[00:00:17.301,574] <inf> voqdr: Connected to nRF Cloud
[00:00:17.308,624] <inf> voqdr: Shadow updated
[00:00:17.347,229] [1;31m<err> nrf_cloud_agps:  nrf_cloud_agps_request finished
[00:00:17.822,723] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.
[00:00:17.830,871] <inf> nrf_cloud_codec: Ensure device firmware is up to date.
[00:00:17.838,623] <inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.
[00:00:17.848,297] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2
[00:00:17.856,536] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 9, type: 3
[00:00:17.864,013] [1;31m<err> nrf_cloud_transport: nct_input: failed -2
I get cloud association as I should, and I receive the agps data as expected (verified only by how quickly it found several sats. As a digression, I allow myself to request some sort of verification of it through your libraries. After 2.2.0, this became a lot more "black box".)
The first part of the message stems from nrf_cloud_decode_requested_state() in nrf_cloud_codec.c, the last is from the handler in nrf_cloud_fsm.
I cant see any actual problems associated with these messages. Can anyone help in getting rid of these?
Please let me know what other information I can supply to help figuring this out.
Thanks!
Torje
    Could you try to enable CONFIG_NRF_CLOUD_GPS_LOG_LEVEL_DBG and CONFIG_NRF_CLOUD_LOG_LEVEL_DBG?
    The first one should let you see more details about the AGPS usage, while the other one hopefully will help us identify the unhandled data received from the cloud.
    Didrik
  • Hey Didrik,
    And thanks for your patience.
    Below is the full logs of the relevant parts:
    00:00:12.782,165] [0m<inf> voqdr: NRF_MODEM_GNSS_EVT_AGPS_REQ
    00:00:12.788,208] [0m<inf> voqdr: Assistance data needed, ephe 0xffffffff, alm 0xffffffff, flags 0x3b
    00:00:12.798,767] [0m<inf> voqdr: Connecting to LTE network
    00:00:12.809,295] [0m<inf> voqdr: reg_status: 1
    00:00:12.814,056] [0m<inf> voqdr: The device is already registered with an LTE network
    00:00:12.822,265] [0m<inf> voqdr: Connecting to nRF Cloud
    00:00:12.829,437] [0m<dbg> nrf_cloud_transport: nct_client_id_set: client_id = voqdr-352000000000000
    00:00:12.839,202] [0m<dbg> nrf_cloud_transport: nct_topics_populate: accepted_topic: voqdr-352000000000000/shadow/get/accepted
    00:00:12.850,891] [0m<dbg> nrf_cloud_transport: nct_topics_populate: rejected_topic: $aws/things/voqdr-352000000000000/shadow/get/rejected
    00:00:12.863,647] [0m<dbg> nrf_cloud_transport: nct_topics_populate: update_delta_topic: $aws/things/voqdr-352000000000000/shadow/update/delta
    00:00:12.876,770] [0m<dbg> nrf_cloud_transport: nct_topics_populate: update_topic: $aws/things/voqdr-352000000000000/shadow/update
    00:00:12.888,824] [0m<dbg> nrf_cloud_transport: nct_topics_populate: shadow_get_topic: $aws/things/voqdr-352000000000000/shadow/get
    00:00:12.901,000] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 1
    00:00:12.908,782] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 1
    00:00:12.916,534] [0m<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
    00:00:13.113,677] [0m<dbg> nrf_cloud_transport: nct_connect: IPv4 address: 44.208.213.126
    00:00:13.122,100] [0m<dbg> nrf_cloud_transport: nct_mqtt_connect: MQTT clean session flag: 1
    00:00:14.853,485] [0m<dbg> nrf_cloud: nrf_cloud_run: Cloud connection request sent
    00:00:15.251,861] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0
    00:00:15.260,894] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 2
    00:00:15.268,676] [0m<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED
    00:00:15.277,038] [0m<dbg> nrf_cloud_transport: nct_cc_connect: nct_cc_connect
    00:00:15.285,614] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 3
    00:00:15.571,868] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 100 result = 0
    00:00:15.581,787] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 4
    00:00:15.589,538] [0m<dbg> nrf_cloud_transport: nct_cc_send: mqtt_publish: id = 200 opcode = 0 len = 0
    00:00:15.599,792] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 5
    00:00:15.849,609] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 200 result = 0
    00:00:15.859,497] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 5
    00:00:15.913,543] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 13739 len = 287, topic = voqdr-352000000000000/shadow/get/accepted
    00:00:15.929,321] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 5
    00:00:15.937,042] [0m<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_RX_DATA_SHADOW
    00:00:15.944,976] [0m<dbg> voqdr: cloud_event_handler: 287 bytes received from cloud
    00:00:15.953,063] [1;31m<err> voqdr: json_from_cloud: {"desired":{"pairing":{"state":"paired","topics":{"d2c":"prod/c1b68dd7-xx-xx-xx-xx/m/d/voqdr-352000000000000/d2c","c2d":"prod/c1b68dd7-xx-xx-xx-xx/m/d/voqdr-352000000000000/+/r"}},"nrfcloud_mqtt_topic_prefix":"prod/c1b68dd7-xx-xx-xx-xx/"}}
    00:00:15.996,246] [0m<dbg> nrf_cloud_transport: nct_dc_endpoint_set: nct_dc_endpoint_set
    00:00:16.005,004] [0m<dbg> nrf_cloud_transport: nct_dc_endpoint_get: nct_dc_endpoint_get
    00:00:16.014,556] [0m<dbg> nrf_cloud_transport: nct_cc_send: mqtt_publish: id = 301 opcode = 1 len = 365
    00:00:16.026,031] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 7
    00:00:16.033,752] [0m<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED
    00:00:16.852,111] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 301 result = 0
    00:00:16.862,030] [0m<dbg> nrf_cloud_transport: nct_dc_connect: nct_dc_connect
    00:00:16.870,452] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 8
    00:00:16.878,417] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 1 len = 160, topic = $aws/things/voqdr-352000000000000/shadow/update/delta
    00:00:16.895,172] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.
    00:00:16.903,320] [0m<inf> nrf_cloud_codec: Ensure device firmware is up to date.
    00:00:16.911,102] [0m<inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.
    00:00:16.920,806] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2
    00:00:16.929,046] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 8, type: 3
    00:00:16.936,553] [1;31m<err> nrf_cloud_transport: nct_input: failed -2
    00:00:17.191,101] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 101 result = 0
    00:00:17.201,690] [0m<dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 9
    00:00:17.209,411] [0m<dbg> voqdr: cloud_event_handler: NRF_CLOUD_EVT_READY
    00:00:17.217,102] [0m<inf> voqdr: Connected to nRF Cloud
    00:00:17.223,083] [0m<dbg> nrf_cloud_transport: nct_cc_send: mqtt_publish: id = 1000 opcode = 1 len = 91
    00:00:17.233,947] [0m<inf> voqdr: Shadow updated
    00:00:17.271,545] [0m<dbg> nrf_cloud_codec: json_send_to_cloud: Created request: {"appId":"AGPS","messageType":"DATA","data":{"mcc":242,"mnc":1,"tac":31801,"eci":17925635,"rsrp":-140,"types":[1,2,3,4,6,7,8,9]}}
    00:00:17.291,778] [0m<dbg> nrf_cloud_codec: json_send_to_cloud: Request sent to cloud
    00:00:17.813,781] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1000 result = 0
    00:00:17.824,005] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1001 result = 0
    00:00:17.835,235] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 1 len = 160, topic = $aws/things/voqdr-352000000000000/shadow/update/delta
    00:00:17.851,989] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.
    00:00:17.860,137] [0m<inf> nrf_cloud_codec: Ensure device firmware is up to date.
    00:00:17.867,919] [0m<inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.
    00:00:17.877,593] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2
    00:00:17.885,864] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 9, type: 3
    00:00:17.893,371] [1;31m<err> nrf_cloud_transport: nct_input: failed -2
    00:00:18.033,386] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 2 len = 1945, topic = prod/c1b68dd7-xx-xx-xx-xx/m/d/voqdr-352000000000000/agps/r
    00:00:18.051,177] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Received AGPS data. Schema version: 1, length: 1945
    00:00:18.062,133] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: A-GPS_injection_active LOCKED
    00:00:18.071,228] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 20
    00:00:18.079,010] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOWs copied, bitmask: 0x00000000
    00:00:18.088,348] [0m<dbg> nrf_cloud_agps: copy_time_and_tow: SW TOW mask is zero, not copying TOW array
    00:00:18.098,175] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_GPS_SYSTEM_CLOCK
    00:00:18.108,764] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 85
    00:00:18.116,516] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 1
    00:00:18.129,547] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 147
    00:00:18.137,359] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 2
    00:00:18.150,573] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 209
    00:00:18.158,386] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 3
    00:00:18.171,600] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 271
    00:00:18.179,412] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 4
    00:00:18.192,535] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 333
    00:00:18.200,378] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 5
    00:00:18.213,562] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 395
    00:00:18.221,405] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 6
    00:00:18.239,868] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 457
    00:00:18.247,711] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 7
    00:00:18.266,174] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 519
    00:00:18.274,017] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 8
    00:00:18.292,480] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 581
    00:00:18.300,323] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 9
    00:00:18.318,786] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 643
    00:00:18.326,599] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 10
    00:00:18.339,019] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 705
    00:00:18.346,832] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 11
    00:00:18.359,344] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 767
    00:00:18.367,156] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 12
    00:00:18.380,065] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 829
    00:00:18.387,878] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 13
    00:00:18.401,000] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 891
    00:00:18.408,843] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 14
    00:00:18.421,997] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 953
    00:00:18.429,840] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 15
    00:00:18.442,962] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1015
    00:00:18.450,897] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 16
    00:00:18.463,989] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1077
    00:00:18.471,893] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 17
    00:00:18.485,046] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1139
    00:00:18.492,950] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 18
    00:00:18.506,042] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1201
    00:00:18.513,946] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 19
    00:00:18.528,503] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1263
    00:00:18.536,437] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 20
    00:00:18.550,964] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1325
    00:00:18.558,898] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 21
    00:00:18.573,425] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1387
    00:00:18.581,359] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 23
    00:00:18.595,886] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1449
    00:00:18.603,820] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 24
    00:00:18.618,347] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1511
    00:00:18.626,281] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 25
    00:00:18.638,641] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1573
    00:00:18.646,575] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 26
    00:00:18.661,102] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1635
    00:00:18.669,036] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 27
    00:00:18.683,563] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1697
    00:00:18.691,497] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 28
    00:00:18.706,054] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1759
    00:00:18.713,958] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 29
    00:00:18.726,470] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1821
    00:00:18.734,375] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 30
    00:00:18.746,856] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1883
    00:00:18.754,760] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 31
    00:00:18.767,761] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1945
    00:00:18.775,665] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_EPHEMERIDES 32
    00:00:18.788,848] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: A-GPS_inject_active UNLOCKED
    00:00:18.797,790] [0m<dbg> nrf_cloud_fsm: agps_process: A-GPS data processed
    00:00:18.805,328] [0m<dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 3 len = 1183, topic = prod/c1b68dd7-xx-xx-xx-xx/m/d/voqdr-352000000000000/agps/r
    00:00:18.829,406] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Received AGPS data. Schema version: 1, length: 1183
    00:00:18.840,393] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: A-GPS_injection_active LOCKED
    00:00:18.849,456] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 20
    00:00:18.857,238] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOWs copied, bitmask: 0x00000000
    00:00:18.866,607] [0m<dbg> nrf_cloud_agps: copy_time_and_tow: SW TOW mask is zero, not copying TOW array
    00:00:18.876,403] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_GPS_SYSTEM_CLOCK
    00:00:18.893,218] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 54
    00:00:18.900,939] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 1
    00:00:18.914,520] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 85
    00:00:18.922,271] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 2
    00:00:18.933,044] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 116
    00:00:18.940,856] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 3
    00:00:18.951,721] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 147
    00:00:18.959,533] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 4
    00:00:18.970,947] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 178
    00:00:18.978,759] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 5
    00:00:18.989,990] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 209
    00:00:18.997,833] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 6
    00:00:19.008,880] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 240
    00:00:19.016,693] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 7
    00:00:19.027,923] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 271
    00:00:19.035,736] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 8
    00:00:19.046,966] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 302
    00:00:19.054,779] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 9
    00:00:19.065,948] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 333
    00:00:19.073,791] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 10
    00:00:19.084,777] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 364
    00:00:19.092,590] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 11
    00:00:19.103,912] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 395
    00:00:19.111,755] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 12
    00:00:19.122,894] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 426
    00:00:19.130,706] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 13
    00:00:19.141,998] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 457
    00:00:19.149,810] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 14
    00:00:19.160,888] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 488
    00:00:19.168,701] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 15
    00:00:19.179,992] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 519
    00:00:19.187,805] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 16
    00:00:19.204,803] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 550
    00:00:19.212,646] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 17
    00:00:19.229,675] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 581
    00:00:19.237,487] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 18
    00:00:19.254,516] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 612
    00:00:19.262,329] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 19
    00:00:19.279,388] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 643
    00:00:19.287,200] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 20
    00:00:19.304,229] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 674
    00:00:19.312,042] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 21
    00:00:19.329,101] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 705
    00:00:19.336,944] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 23
    00:00:19.353,973] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 736
    00:00:19.361,785] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 24
    00:00:19.372,650] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 767
    00:00:19.380,493] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 25
    00:00:19.391,357] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 798
    00:00:19.399,169] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 26
    00:00:19.410,552] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 829
    00:00:19.418,365] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 27
    00:00:19.429,687] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 860
    00:00:19.437,500] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 28
    00:00:19.448,730] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 891
    00:00:19.456,573] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 29
    00:00:19.473,632] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 922
    00:00:19.481,445] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 30
    00:00:19.492,279] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 953
    00:00:19.500,122] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 31
    00:00:19.513,519] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 984
    00:00:19.521,362] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_ALMANAC 32
    00:00:19.534,851] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 991
    00:00:19.542,663] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 0 copied
    00:00:19.550,262] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 995
    00:00:19.558,105] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 1 copied
    00:00:19.565,704] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 999
    00:00:19.573,577] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 2 copied
    00:00:19.581,176] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1003
    00:00:19.589,111] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 3 copied
    00:00:19.596,710] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1007
    00:00:19.604,675] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 4 copied
    00:00:19.612,274] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1011
    00:00:19.620,208] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 5 copied
    00:00:19.627,807] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1015
    00:00:19.635,742] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 6 copied
    00:00:19.643,341] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1019
    00:00:19.651,306] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 7 copied
    00:00:19.658,905] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1023
    00:00:19.666,839] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 8 copied
    00:00:19.674,438] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1027
    00:00:19.682,373] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 9 copied
    00:00:19.689,971] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1031
    00:00:19.697,937] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 10 copied
    00:00:19.705,627] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1035
    00:00:19.713,562] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 11 copied
    00:00:19.721,252] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1039
    00:00:19.729,217] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 12 copied
    00:00:19.736,877] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1043
    00:00:19.744,842] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 13 copied
    00:00:19.752,532] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1047
    00:00:19.760,467] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 14 copied
    00:00:19.768,157] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1051
    00:00:19.776,092] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 15 copied
    00:00:19.783,782] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1055
    00:00:19.791,748] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 16 copied
    00:00:19.799,438] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1059
    00:00:19.807,403] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 17 copied
    00:00:19.815,093] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1063
    00:00:19.823,028] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 18 copied
    00:00:19.830,718] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1067
    00:00:19.838,684] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 19 copied
    00:00:19.846,374] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1071
    00:00:19.854,339] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 20 copied
    00:00:19.862,030] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1075
    00:00:19.869,964] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 22 copied
    00:00:19.877,655] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1079
    00:00:19.885,620] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 23 copied
    00:00:19.893,310] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1083
    00:00:19.901,275] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 24 copied
    00:00:19.908,966] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1087
    00:00:19.916,900] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 25 copied
    00:00:19.924,591] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1091
    00:00:19.932,556] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 26 copied
    00:00:19.940,246] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1095
    00:00:19.948,181] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 27 copied
    00:00:19.955,902] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1099
    00:00:19.963,836] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 28 copied
    00:00:19.971,527] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1103
    00:00:19.979,492] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 29 copied
    00:00:19.987,182] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1107
    00:00:19.995,147] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 30 copied
    00:00:20.002,838] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1111
    00:00:20.010,772] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOW 31 copied
    00:00:20.018,463] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1130
    00:00:20.026,397] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: TOWs copied, bitmask: 0xffdfffff
    00:00:20.035,766] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_GPS_SYSTEM_CLOCK
    00:00:20.046,539] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1148
    00:00:20.054,443] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_LOCATION
    00:00:20.064,117] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1165
    00:00:20.072,052] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_UTC_PARAMETERS
    00:00:20.082,427] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1176
    00:00:20.090,362] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_KLOBUCHAR_CORRECTION
    00:00:20.107,238] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: Parsed_len: 1183
    00:00:20.115,142] [0m<dbg> nrf_cloud_agps: agps_send_to_modem: A-GPS type: NRF_CLOUD_AGPS_INTEGRITY
    00:00:20.131,164] [0m<dbg> nrf_cloud_agps: nrf_cloud_agps_process: A-GPS_inject_active UNLOCKED
    00:00:20.140,106] [0m<dbg> nrf_cloud_fsm: agps_process: A-GPS data processed[0m
    I can't see any immidiate errors, but what do your elf eyes see? (yes, I dropped a LoTR reference)
    Thanks!
    Torje
  • What data (and data format) is written to the shadow here:
    I tried to look for your device in AWS, but it appears to be gone.
    It is possible that the codec needs to be updated to be less strict about shadow updates.
  • Hello Justin,
    I'm updating the shadow as such:
    void update_shadow(void)
    	int err;
    	struct nrf_cloud_svc_info_fota fota_info = {
    		.application = IS_ENABLED(CONFIG_NRF_CLOUD_FOTA) && IS_ENABLED(CONFIG_BOOTLOADER_MCUBOOT),
    		.bootloader = IS_ENABLED(CONFIG_NRF_CLOUD_FOTA) && IS_ENABLED(CONFIG_BOOTLOADER_MCUBOOT) && IS_ENABLED(CONFIG_BUILD_S1_VARIANT) && IS_ENABLED(CONFIG_SECURE_BOOT),
    		.modem = IS_ENABLED(CONFIG_NRF_CLOUD_FOTA) && IS_ENABLED(CONFIG_BOOTLOADER_MCUBOOT)};
    	struct nrf_cloud_svc_info_ui ui_info = {
    		.gnss = true,
    		.temperature = false,
    	struct nrf_cloud_svc_info service_info = {
    		.fota = &fota_info,
    		.ui = &ui_info};
    	struct nrf_cloud_device_status device_status = {
    		.modem = NULL,
    		.svc = &service_info};
    	err = nrf_cloud_shadow_device_status_update(&device_status);
    	if (err)
    		LOG_ERR("Failed to update device shadow, error: %d", err);
    This is plucked from a sample. The shadow is updated only once, on the first connection
    I'm not sure how you would find the device, as I've hidden device ID and other info in the logs? The particular ID is Voqdr-352656101081837. Its location data is stored in nRFCloud, as expected.
  • ah, i didn't realize you modified the device id in your logs... thanks for the real device id.
    the desired section has a "desiredConnections" json object which is producing a shadow delta event.
    that should not be a problem, but it seems the codec does not like it.
    if you don't need this object, i can remove it for you and that should get rid of your error.
    regardless, it looks like the codec needs updated to handle such things.
