Hello, I have been working on a project, the project is in the testing phase.
I have deployed two network.
HOME NETWORK:
In this network I have 10 Nodes (Server Nodes) which Publish Messages at a regular interval of 3 seconds.
As you can see below the node location and its TTL values:
Nodes that are marked with green boxes have the relay feature enable and nodes marked with oranges boxes have relay feature disabled.
The reason to make some nodes relay and some not is because I need to minimized the traffic accros the mesh network.
In this mesh network packet success rate is 95% to reach at the gateway location and works perfectly fine.
Where as the other Mesh Network deployed at another place have a very worst performance.
As you can see below:
This network have 38 nodes (Server nodes), configuration for both Mesh network is the same. Nodes marked with green circles have relay featured enabled where as nodes marked with light blue circles have relay featured disabled.
TTL values are set accordingly.
In this network the packets reception is uncertain and have a very poor performance.
What could be the possible reason for this?
Please let me know, I am struggling very hard but no luck so far to identify the problem.
Gateway Location is marked with (G).
If you need further info let me know...
Thanks.
HOME Mesh Network details:
