He recently purchased thingy 53 and trying to explore basic examples.
I am able to program sample blinky code to thingy53 through jtag programmer (jtag mini edu ) but I am not able to see any led blinking.
Any hardware like 3.3v enable is required?
Which example project did you build, and how did you build it? Then, how did you flash it?
I am not familiar with "jtag mini edu", but perhaps you mean J-Link EDU Mini? Regardless, any Segger debugger should work with our tools, but with other debuggers things will typically not work out of the box.
The Thingy:53 has a rechargeable battery, so as long as that is not depleted you don't need any supply. If it is depleted, plug in the USB-C connector and connect to PC to power the Thingy and charge the battery.
