Failing to biuld the thingy53 sample zigbee_weather_station, CMake error
Hi, could someone help me with this issue i have when i try to build the zigbee_weather_station for thingy53?
Building zigbee_weather_station(1.0.0)
west build --build-dir c:\progetti\nexter\VS\esempi\zigbee_weather_station(1.0.0)\build c:\progetti\nexter\VS\esempi\zigbee_weather_station(1.0.0) --pristine --board thingy53_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/ncs/v2.1.1/nrf/boards/arm;c:/progetti/nexter/VS/esempi/coap_client;c:/progetti/nexter/VS/esempi/coap_server_multiprotocol;c:/progetti/nexter/VS/esempi/mqtt_publisher" -DCONF_FILE:STRING="c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/prj.conf" -DDTC_OVERLAY_FILE:STRING="c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/app.overlay"
-- Application: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)
-- Found Python3: C:/ncs/toolchains/v2.1.1/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.1.1/zephyr/.cache
-- Zephyr version: 3.1.99 (C:/ncs/v2.1.1/zephyr)
-- Board: thingy53_nrf5340_cpuapp
-- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.1/opt/zephyr-sdk)
-- Found dtc: C:/ncs/toolchains/v2.1.1/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.1/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.1.1/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp.dts
-- Found devicetree overlay: c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/app.overlay
-- Generated zephyr.dts: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/dts.cmake
Parsing C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/Kconfig
Loaded configuration 'C:/ncs/v2.1.1/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/prj.conf'
Configuration saved to 'C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/.config'
Kconfig header saved to 'C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: C:/ncs/toolchains/v2.1.1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
=== child image 802154_rpmsg - CPUNET begin ===
loading initial cache file C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/child_image_preload.cmake
-- Application: C:/ncs/v2.1.1/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg
-- Board: thingy53_nrf5340_cpunet
-- Found BOARD.dts: C:/ncs/v2.1.1/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/dts.cmake
Parsing C:/ncs/v2.1.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.1.1/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpunet_defconfig'
Merged configuration 'C:/ncs/v2.1.1/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg/prj.conf'
Merged configuration 'C:/ncs/v2.1.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/.config'
Kconfig header saved to 'C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/zephyr/include/generated/autoconf.h'
-- libmetal version: 1.2.0 (C:/ncs/v2.1.1/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg)
-- Build type:
-- Host:    Windows/AMD64
-- Target:  Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.2.0 (C:/ncs/v2.1.1/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg
=== child image 802154_rpmsg - CPUNET end ===
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:4:
  Syntax Warning in cmake code at column 143
  Argument not separated from preceding token by whitespace.
  C:/ncs/v2.1.1/nrf/cmake/multi_image.cmake:416 (include)
  C:/ncs/v2.1.1/nrf/cmake/multi_image.cmake:150 (add_child_image_from_source)
  C:/ncs/v2.1.1/nrf/samples/CMakeLists.txt:151 (add_child_image)
This warning is for project developers.  Use -Wno-dev to suppress it.
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:6:
  Syntax Warning in cmake code at column 142
  Syntax Warning in cmake code at column 238
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:7:
  Syntax Warning in cmake code at column 140
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:8:
  Syntax Warning in cmake code at column 137
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:9:
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:11:
  Syntax Warning in cmake code at column 131
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:12:
  Syntax Warning in cmake code at column 136
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:13:
  Syntax Warning in cmake code at column 130
CMake Warning (dev) at C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/802154_rpmsg/shared_vars.cmake:14:
  Syntax Warning in cmake code at column 148
-- libmetal version: 1.2.0 (C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0))
-- Build type:
-- Machine: arm
-- Machine: arm
CMake Error at C:/ncs/v2.1.1/zephyr/cmake/modules/extensions.cmake:1414 (file):
  file STRINGS file "C:/progetti/nexter/VS/esempi/zigbee_weather_station"
  cannot be read.
  C:/ncs/v2.1.1/nrf/cmake/partition_manager.cmake:486 (import_kconfig)
  C:/ncs/v2.1.1/zephyr/cmake/modules/kernel.cmake:244 (include)
  C:/ncs/v2.1.1/zephyr/cmake/modules/zephyr_default.cmake:130 (include)
  C:/ncs/v2.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/ncs/v2.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:22 (find_package)
  File "C:/ncs/v2.1.1/nrf/scripts/partition_manager_output.py", line 234, in <module>
    main()
  File "C:/ncs/v2.1.1/nrf/scripts/partition_manager_output.py", line 212, in main
    with open(partition, 'r') as f:
FileNotFoundError: [Errno 2] No such file or directory: 'C:/progetti/nexter/VS/esempi/zigbee_weather_station'
CMake Error at C:/ncs/v2.1.1/nrf/cmake/partition_manager.cmake:613 (message):
  Partition Manager GLOBAL output generation failed,
      aborting. Command: C:/ncs/toolchains/v2.1.1/opt/bin/python.exe;C:/ncs/v2.1.1/nrf/scripts/partition_manager_output.py;--input-partitions;C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/partitions.yml;C:/progetti/nexter/VS/esempi/zigbee_weather_station;(;1.0.0;);/build/802154_rpmsg/partitions_CPUNET.yml;--input-regions;C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/regions.yml;C:/progetti/nexter/VS/esempi/zigbee_weather_station;(;1.0.0;);/build/802154_rpmsg/regions_CPUNET.yml;--header-files;C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/zephyr/include/generated/pm_config.h;C:/progetti/nexter/VS/esempi/zigbee_weather_station;(;1.0.0;);/build/802154_rpmsg/zephyr/include/generated/pm_config.h;--images;:app;CPUNET:802154_rpmsg
See also "C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/CMakeFiles/CMakeOutput.log".
See also "C:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.1\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.1.1\opt\bin\python.exe' '-Bc:\progetti\nexter\VS\esempi\zigbee_weather_station(1.0.0)\build' -GNinja -DBOARD=thingy53_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=c:/ncs/v2.1.1/nrf/boards/arm;c:/progetti/nexter/VS/esempi/coap_client;c:/progetti/nexter/VS/esempi/coap_server_multiprotocol;c:/progetti/nexter/VS/esempi/mqtt_publisher' '-DCONF_FILE:STRING=c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/prj.conf' '-DDTC_OVERLAY_FILE:STRING=c:/progetti/nexter/VS/esempi/zigbee_weather_station(1.0.0)/configuration/thingy53_nrf5340_cpuapp/app.overlay' '-Sc:\progetti\nexter\VS\esempi\zigbee_weather_station(1.0.0)'
this is what prints out VS code
