nrf52832 / nrf52840 NUS
Hi All,
I have been trying to implement NUS on my nrf52832/nrf52840. I have that application working on both of them. Recently I wanted to implement the same functionality (NUS) on another application. I have ported the code from my old application to the new also taking care of all the dependencies. The application runs but it is not able to advertise. I play with Placement Macros (RAM and Flash) size which atleast doesn't give me ud memory fail.
if (nrf_sdh_ble_enable(&ram_start) != NRF_SUCCESS)
        printf("ud memory fail\n");
But still I am not able to receive advertisement. I believe I am not setting the RAM and Flash parameters correctly. Here is the current configuration.
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x20003d18
RAM_SIZE=0xe2e8
Also is it possible to use s132 with nrf52840?
I have gone through this link but couldn't use it properly. Any help much will be much appreciated.
Thanks
Regards
    Try to turn on logging, and monitor the logs from inside nrf_sdh_ble_enable(). It should say what you need to adjust your RAM settings to. I can't tell from your description, but it will calculate it for you, and display it in the log.
    Edvin
  • So I tried to printed out the RAM start address using the following but it doesn't even cross
    The following function initializes my stack:
    void ble_ud_stack_init(void)
        uint32_t err_code;
        uint32_t ram_start = 0;
        printf("--------------------here1\n");
        if (nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start) != NRF_SUCCESS)
            printf("ud fail\n");
        printf("BLE Application RAM start address = %x\n", ram_start);
        NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_ud_stack_evt_handler, NULL);
    I am able to compile but when I run I get following error:
    ERROR 8 [NRF_ERROR_INVALID_STATE]
    Currently I have the following macros for nrf52840:
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x27000
    FLASH_SIZE=0xd9000
    RAM_START=0x20003460
    RAM_SIZE=0x3dd00
    What function returns this? nrf_sdh_enable_request() or nrf_sdh_ble_enable()?
    Either way, I suggest you replace line 8 -> 15 with nrf_sdh_ble_enable() from nrf_sdh_ble.c. This will print in the log what you need to change your RAM settings to. Again, I don't know without having your entire application.
    BR,
    Edvin
  • err_code = nrf_sdh_enable_request();
    Return the error
  • Yes, it will return that.
    But what did the log say?
    Do you see the log output at all? If not, please let me know.
    BR,
    Edvin
