nrf5340dk as sensor client in a mesh network gives two errors
Hello, I am new to configuring these boards and I am trying to use the nrf5340dk board (PCA100095) as a mesh sensor observer or client using the sample mesh sensor observer given in nRF samples. I know that the sample is tested in nRF52 DK, nRF52840 DK, and nRF21540 DK. What should I change in order to get rid of the following errors:
- bt_mesh_pb_adv: Failed enabling advertiser
- bt_mesh_pb_gatt: Failed enabling advertiser
Thank you in advance.
  • Hi.
    See this previous answer on how to configure a sample that doesn't support nRF5340.
     nRF5340-DK and Bluetooth mesh chat example.
    Br,
    Joakim
  • Hi, I added and set CONFIG_BT_LL_SW_SPLIT=y in prj.conf file and then I tried to build again but I have an error that I pasted below:
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\v2.2.99-dev3\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/ncs/AppSensorClient1302/sensor_client/build_1/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/bluetooth/mesh/libsubsys__bluetooth__mesh.a zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/hwinfo/libdrivers__hwinfo.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/mbox/libdrivers__mbox.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bluetooth/mesh/lib..__nrf__subsys__bluetooth__mesh.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/v2.2.99-dev3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v8-m.main/nofp" -LC:/ncs/AppSensorClient1302/sensor_client/build_1/zephyr -lgcc zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D C:\ncs\AppSensorClient1302\sensor_client\build_1\zephyr && C:\ncs\toolchains\v2.2.99-dev3\opt\bin\cmake.exe -E echo ""
    c:/ncs/toolchains/v2.2.99-dev3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `text' will not fit in region `FLASH'
    c:/ncs/toolchains/v2.2.99-dev3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 98216 bytes
    collect2.exe: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.99-dev3\opt\bin\cmake.EXE' --build 'c:\ncs\AppSensorClient1302\sensor_client\build_1
    Joakim is out of office, so I'm answering you.
    From your screenshot, it looks like you are building for the nRF5340 network core.
    You should instead build it for the app core, i.e. board nrf5340dk_nrf5340_cpuapp or nrf5340dk_nrf5340_cpuapp_ns instead.
