Adding DFU MESH to existing application?
Is there a tutorial to add DFU MESH to an existing application?
Potentially integrating this DFU example into a project:
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.meshsdk.v5.0.0/md_examples_dfu_README.html
  • Using - https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.meshsdk.v5.0.0/md_doc_user_guide_modules_dfu_configuring_performing.html
    Flashing Blinky works just fine, as I would like to add DFU to an existing application, I first decided to replace the Blinky binary with the DFU binary. So when I do a software update it'll reflash the DFU and I could test the reflashing.
    I am able to recreate the zip using:
    nrfutil dfu genpkg --application dfu_nrf52832_xxAA_s132_7.2.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file private_key.txt --sd-req 0x00CB --mesh dfu_test.zip
    and reflash it the regular way sending the zip over. However the response I get it this:
    Terminal:
    Flushing com-port...
    Opened com-port
    Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 205300
    Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    1: PC -> target: 0502aabbccdd
    target -> PC: 0582aabbccdd
    Got echo response
    Sending DFU init packet
    Sending ready packet
    1: PC -> target: 1378fdff040f6320bf4659000000010002000000
    target -> PC: 16a6045900000001000200000059000000010001000000
    target -> PC: 1378fdff04000000000059000000010002000000
    target -> PC: 03847800
    target -> PC: 1378fdff040f6320bf4659000000010002000000
    Sending start packet
    1: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    target -> PC: 0ea30104590000000100020000000c
    target -> PC: 1178feff0101010159000000010001000000
    target -> PC: 03847884
    2: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    target -> PC: 03847887
    3: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    4: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    5: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    6: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    7: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    8: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    9: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    10: PC -> target: 1478fcff00006320bf46ffffffff7dc8000040000c
    Failed to upgrade target. Error is: Device returned status code ERROR_INVALID_DATA (135) on a DFU data packet.
    Possible causes:
    - bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
    - baud rate or flow control is not the same as in the target bootloader.
    - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
    - if the error is ERROR_BUSY at the beginning of the DFU process,increase the value of PAGE_ERASE_TIME_MAX by few milliseconds.
    Closing serial port...
    RTT:
    00> <t:          5>, main.c,  227, ----- Bluetooth Mesh DFU Example -----
    00> <t:       8857>, nrf_mesh_dfu.c,  753, Version info: BL(ver, id): 0x01 0x01 SD: 0x0101
    00> <t:       8864>, nrf_mesh_dfu.c,  755, Version info: APP company: 0x00000059 id: 0x0001 version: 0x00000001
    00> <t:       8888>, serial_handler_prov.c,  267, Generating encryption keypair...
    00> <t:      15059>, main.c,  233, Initialization complete!
    00> <t:      21130>, main.c,  254, Enabling serial interface...
    00> <t:      21136>, mesh_app_utils.c,   66, Device UUID (raw): 54A6E2A0FB5B4439B0587E2237798165
    00> <t:      21142>, mesh_app_utils.c,   67, Device UUID : 54A6E2A0-FB5B-4439-B058-7E2237798165
    00> <t:      21162>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:      21171>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
    00> <t:      21185>, main.c,  262, DFU example started!
    00> <t:     286030>, nrf_mesh_dfu.c,  418,   New firmware!
    00> <t:     286035>, main.c,   79, DFU type Application
    00> <t:     286040>, main.c,  123, Requesting DFU transfer with bank at 0x00059000
    00> <t:     286046>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD
    00> <t:     286054>, nrf_mesh_dfu.c,  565, Killing a TX slot prematurely (repeats done: 1).
    00> <t:     286061>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65533)
    00> <t:     352308>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 3, interval: periodic, handle: FFFD
    00> <t:     352316>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65533)
    00> <t:     418519>, nrf_mesh_dfu.c,  411,   Abort event. Reason: 0xC
    00> <t:     418528>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:     418537>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
    00> <t:     418544>, nrf_mesh_dfu.c,  554,   RADIO TX! SLOT 0, count 15, interval: periodic, handle: FFFE
    00> <t:     418551>, nrf_mesh_dfu.c,  565, Killing a TX slot prematurely (repeats done: 0).
    00> <t:     418558>, nrf_mesh_dfu.c,  593,   SERIAL TX (type: 65534)
  • Hi Shahin97,
    I'm sorry but there are several things I am not clear in your description here.
    • What is the blinky binary?
    • What is the DFU binary? Is it the DFU example?
    • What have you flashed on the device prior to the DFU attempt?
    I would also like to know a few info to know how familiar you are with understanding the feature:
    • Have you read the DFU feature documentation thoroughly?
    • Have you successfully run basic DFU example and follow the guide in the feature documentation?
      I recommend you follow the basic example and guide without any modification first to have a good understanding of the feature, before attempting modiifcation and adaptations.
    • Have you examined the "Possible cause" hint given by the serial interface?
      From the two logs you have seen, I think it is likely that the SoftDevice version was not considered correctly in your steps.
    Finally, please be informed that the nRF5 SDK for Mesh is in maintenance mode, and development of new project for it is not recommended.
    Please consider the nRF Connect SDK (NCS). It is true that current version of NCS does not support DFU over Bluetooth Mesh. However, it currently supports DFU over BLE for Mesh device. While this solution is not over Mesh, it is also far faster.
    Hieu
    Following the link - https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v5.0.0%2Fmd_doc_user_guide_modules_dfu_configuring_performing.html
    The Blinky binary is the binary file in bin/blinky folder as shown in the guide.
    The DFU binary, is the DFU example binary.
    Following this tutorial, I have successfully been able to perform DFU update. However, the the Blinky program does not contain any DFU and so the program cannot be flashed again.
    So my goal is to create an app that can be flashed multiple times. ie My Application + DFU.
    I assumed instead of flashing blinky. I could flash the DFU example again to see if I could reflash it multiple times instead of adding the routines to my application as a quick test (of course remaking the zip with updated application version)
    I have understood your situation now. It is logical what you want to achieve and the direction you are going.
    Have you checked what I said about the "Possible cause" regarding the SoftDevice version in the commands?
    Another thing that could be wrong here is incorrect application ID or application version used when generating the DFU Package. Please also check that.
    Finally, please consider what I have said about the nRF Connect SDK.
  • I have noticed that the possible causes are not reliable as it is a generic statement to cover all bases.
    The bootloader & soft devices + dfu are already flashed onto the MCU. the update only flashes the new application not the bootloader or soft devices, the existing bootloader & soft devices remain on the MCU unchanged.
    The application ID's match and the version is incremented by 1 as stated in the tutorial.
    Unfortunately BLE MESH DFU is a requirement.
    My guess would be the size of the update, as the Blinky zip  is considerably smaller than the dfu.zip which could cause an issue, any other suggestions?
