nRF9160 MQTT message payload over 2302 bytes results in Socket error: POLLERR and dropped connection
Setup:
Modem firmware: mfw_nrf9160_1.3.2
nRF Connect SDK v2.1.2
nRF Connect for VS Code v2023.1.44
Windows 11
We are connecting to AWS over MQTT and subscribing to 1 message topic. If we publish to that topic from another device with a payload larger than 2302 bytes, the nRF9160 device gets Socket error: POLLERR and the AWS connection is dropped. There are not any other errors that appear in my log.
I found another forum post ("nRF9160 issue in receiving MQTT publish messages larger than 2048 bytes over TLS" Case ID: 254191) which seems to be the exact same problem. There were some workarounds mentioned that involved reducing the size of the MQTT message, but I am wondering if there is now any way to get around this without reducing the size of the MQTT message? Also is there going to be a "fix" to this problem at any point?
[2023-02-16 15:04:24.337] [74636725] <dbg> net_mqtt_sock_tls: (0x2000e310): Created socket 0
[2023-02-16 15:04:34.258] [74970250] <dbg> net_mqtt_sock_tls: (0x2000e310): Connect completed
[2023-02-16 15:04:34.258] [74970267] <dbg> net_mqtt_enc: Encoding Protocol Description.
[2023-02-16 15:04:34.258]                                4d 51 54 54                                      |MQTT
[2023-02-16 15:04:34.258] [74970268] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000006 cur:0x20026645, end:0x20027840
[2023-02-16 15:04:34.258] [74970269] <dbg> net_mqtt_enc: (0x2000e310): >> val:0004 cur:0x20026645, end:0x20027840
[2023-02-16 15:04:34.258] [74970272] <dbg> net_mqtt_enc: (0x2000e310): Encoding Protocol Version 04.
[2023-02-16 15:04:34.258] [74970273] <dbg> net_mqtt_enc: (0x2000e310): >> val:04 cur:0x2002664b, end:0x20027840
[2023-02-16 15:04:34.258] [74970273] <dbg> net_mqtt_enc: (0x2000e310): >> val:00 cur:0x2002664c, end:0x20027840
[2023-02-16 15:04:34.258] [74970274] <dbg> net_mqtt_enc: (0x2000e310): Encoding Keep Alive Time 0384.
[2023-02-16 15:04:34.258] [74970275] <dbg> net_mqtt_enc: (0x2000e310): >> val:0384 cur:0x2002664d, end:0x20027840
[2023-02-16 15:04:34.258] [74970275] <dbg> net_mqtt_enc: Encoding Client Id.
[2023-02-16 15:04:34.258]                                64 65 76 69 6e 2d 63 65  6c 6c 2d 74 65 73 74    |devin-ce ll-test
[2023-02-16 15:04:34.260] [74970276] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000011 cur:0x2002664f, end:0x20027840
[2023-02-16 15:04:34.260] [74970277] <dbg> net_mqtt_enc: (0x2000e310): >> val:000f cur:0x2002664f, end:0x20027840
[2023-02-16 15:04:34.260] [74970278] <dbg> net_mqtt_enc: Encoding Will Topic.
[2023-02-16 15:04:34.260]                                6c 61 73 74 77 69 6c 6c  74 6f 70 69 63          |lastwill topic
[2023-02-16 15:04:34.260] [74970278] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:0000000f cur:0x20026660, end:0x20027840
[2023-02-16 15:04:34.260] [74970279] <dbg> net_mqtt_enc: (0x2000e310): >> val:000d cur:0x20026660, end:0x20027840
[2023-02-16 15:04:34.260] [74970280] <dbg> net_mqtt_enc: Encoding Will Message.
[2023-02-16 15:04:34.260]                                7b 22 6c 61 73 74 77 69  6c 6c 22 3a 20 22 6f 66 |{"lastwi ll": "of
[2023-02-16 15:04:34.260]                                66 6c 69 6e 65 22 7d                             |fline"}
[2023-02-16 15:04:34.260] [74970281] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000019 cur:0x2002666f, end:0x20027840
[2023-02-16 15:04:34.260] [74970281] <dbg> net_mqtt_enc: (0x2000e310): >> val:0017 cur:0x2002666f, end:0x20027840
[2023-02-16 15:04:34.262] [74970282] <dbg> net_mqtt_enc: (0x2000e310): << msg type:0x10 length:0x00000043
[2023-02-16 15:04:34.262] [74970283] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000043 cur:(nil), end:(nil)
[2023-02-16 15:04:34.262] [74970285] <dbg> net_mqtt_enc: (0x2000e310): Fixed header length = 02
[2023-02-16 15:04:34.262] [74970286] <dbg> net_mqtt_enc: (0x2000e310): >> val:10 cur:0x20026643, end:0x20027840
[2023-02-16 15:04:34.262] [74970287] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000043 cur:0x20026644, end:0x20027840
[2023-02-16 15:04:34.262] [74977889] <inf> net_mqtt: Connect completed
[2023-02-16 15:04:34.262] [74977903] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:545: Using send socket timeout of 60 seconds
[2023-02-16 15:04:34.262] [74977915] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:800: AWS IoT broker connection request sent
[2023-02-16 15:04:34.450] [74985373] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:592: mqtt_input call
[2023-02-16 15:04:34.720] [74985374] <dbg> net_mqtt: (0x2000e310): state:0x00000002
[2023-02-16 15:04:34.720] [74985375] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025442
[2023-02-16 15:04:34.720] [74985378] <dbg> net_mqtt_dec: (0x2000e310): << val:20
[2023-02-16 15:04:34.720] [74985379] <dbg> net_mqtt_dec: (0x2000e310): length:0x00000002
[2023-02-16 15:04:34.720] [74985382] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: Received MQTT_PKT_TYPE_CONNACK!
[2023-02-16 15:04:34.720] [74985383] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025442, end:0x20025444
[2023-02-16 15:04:34.720] [74985384] <dbg> net_mqtt_dec: (0x2000e310): << val:00
[2023-02-16 15:04:34.720] [74985384] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025443, end:0x20025444
[2023-02-16 15:04:34.720] [74985385] <dbg> net_mqtt_dec: (0x2000e310): << val:00
[2023-02-16 15:04:34.720] [74985385] <dbg> net_mqtt_dec: (0x2000e310): [CID 0x20010610]: session_present_flag: 0
[2023-02-16 15:04:34.720] [74985386] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: return_code: 0
[2023-02-16 15:04:34.720] [74985398] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:219: MQTT client connected!
[2023-02-16 15:04:34.722] [74989038] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:229: Subscribing to topics
[2023-02-16 15:04:34.722] [74989052] <dbg> loggers: 2023-02-16 21:04:32 debug aws_iot.c:132: Subscribing to application topic: curb/messages/devin-cell-test
[2023-02-16 15:04:34.722] [74989053] <dbg> net_mqtt: (0x2000e310): [CID 0x20010610]:[State 0x06]: >> message id 0x3def topic count 0x0001
[2023-02-16 15:04:34.722] [74989070] <dbg> net_mqtt_enc: (0x2000e310): >> val:3def cur:0x20026645, end:0x20027840
[2023-02-16 15:04:34.722] [74989070] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:0000001f cur:0x20026647, end:0x20027840
[2023-02-16 15:04:34.724] [74989071] <dbg> net_mqtt_enc: (0x2000e310): >> val:001d cur:0x20026647, end:0x20027840
[2023-02-16 15:04:34.724] [74989074] <dbg> net_mqtt_enc: (0x2000e310): >> val:01 cur:0x20026666, end:0x20027840
[2023-02-16 15:04:34.724] [74989074] <dbg> net_mqtt_enc: (0x2000e310): << msg type:0x82 length:0x00000022
[2023-02-16 15:04:34.724] [74989075] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000022 cur:(nil), end:(nil)
[2023-02-16 15:04:34.724] [74989076] <dbg> net_mqtt_enc: (0x2000e310): Fixed header length = 02
[2023-02-16 15:04:34.724] [74989076] <dbg> net_mqtt_enc: (0x2000e310): >> val:82 cur:0x20026643, end:0x20027840
[2023-02-16 15:04:34.724] [74989077] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000022 cur:0x20026644, end:0x20027840
[2023-02-16 15:04:34.724] [74989078] <dbg> net_mqtt: (0x2000e310): [0x20010610]: Transport writing 36 bytes.
[2023-02-16 15:04:35.232] [74994021] <dbg> net_mqtt: (0x2000e310): [0x20010610]: Transport write complete.
[2023-02-16 15:04:35.232] [74994022] <dbg> net_mqtt: (0x2000e310): [CID 0x20010610]:[State 0x06]: << result 0x00000000
[2023-02-16 15:04:35.232] [75004213] <dbg> loggers: 2023-02-16 21:04:33 debug aws_iot.c:592: mqtt_input call
[2023-02-16 15:04:35.232] [75004215] <dbg> net_mqtt: (0x2000e310): state:0x00000006
[2023-02-16 15:04:35.232] [75004217] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025442
[2023-02-16 15:04:35.232] [75004217] <dbg> net_mqtt_dec: (0x2000e310): << val:90
[2023-02-16 15:04:35.232] [75004218] <dbg> net_mqtt_dec: (0x2000e310): length:0x00000003
[2023-02-16 15:04:35.232] [75004223] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: Received MQTT_PKT_TYPE_SUBACK!
[2023-02-16 15:04:35.232] [75004223] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025442, end:0x20025445
[2023-02-16 15:04:35.232] [75004224] <dbg> net_mqtt_dec: (0x2000e310): << val:3def
[2023-02-16 15:04:35.232] [75004225] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025444, end:0x20025445
[2023-02-16 15:04:35.232] [75004225] <dbg> net_mqtt_dec: (0x2000e310): << bin len:00000001
[2023-02-16 15:04:46.896] [75390083] <dbg> loggers: 2023-02-16 21:04:44 debug aws_iot.c:880: Socket error: POLLERR
[2023-02-16 15:04:46.897] [75390096] <dbg> loggers: 2023-02-16 21:04:44 debug aws_iot.c:881: Cloud connection was unexpectedly closed.
[2023-02-16 15:04:46.897] [75390108] <dbg> loggers: 2023-02-16 21:04:44 debug aws_iot.c:894: Forcing disconnect
[2023-02-16 15:03:24.294] [72669313] <dbg> net_mqtt_sock_tls: (0x2000e310): Created socket 0
[2023-02-16 15:03:35.375] [73040727] <dbg> net_mqtt_sock_tls: (0x2000e310): Connect completed
[2023-02-16 15:03:35.375] [73040745] <dbg> net_mqtt_enc: Encoding Protocol Description.
[2023-02-16 15:03:35.375]                                4d 51 54 54                                      |MQTT
[2023-02-16 15:03:35.375] [73040745] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000006 cur:0x20026645, end:0x20027840
[2023-02-16 15:03:35.375] [73040747] <dbg> net_mqtt_enc: (0x2000e310): >> val:0004 cur:0x20026645, end:0x20027840
[2023-02-16 15:03:35.375] [73040747] <dbg> net_mqtt_enc: (0x2000e310): Encoding Protocol Version 04.
[2023-02-16 15:03:35.375] [73040748] <dbg> net_mqtt_enc: (0x2000e310): >> val:04 cur:0x2002664b, end:0x20027840
[2023-02-16 15:03:35.375] [73040749] <dbg> net_mqtt_enc: (0x2000e310): >> val:00 cur:0x2002664c, end:0x20027840
[2023-02-16 15:03:35.375] [73040749] <dbg> net_mqtt_enc: (0x2000e310): Encoding Keep Alive Time 0384.
[2023-02-16 15:03:35.375] [73040750] <dbg> net_mqtt_enc: (0x2000e310): >> val:0384 cur:0x2002664d, end:0x20027840
[2023-02-16 15:03:35.375] [73040753] <dbg> net_mqtt_enc: Encoding Client Id.
[2023-02-16 15:03:35.375]                                64 65 76 69 6e 2d 63 65  6c 6c 2d 74 65 73 74    |devin-ce ll-test
[2023-02-16 15:03:35.378] [73040753] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000011 cur:0x2002664f, end:0x20027840
[2023-02-16 15:03:35.378] [73040754] <dbg> net_mqtt_enc: (0x2000e310): >> val:000f cur:0x2002664f, end:0x20027840
[2023-02-16 15:03:35.378] [73040755] <dbg> net_mqtt_enc: Encoding Will Topic.
[2023-02-16 15:03:35.378]                                6c 61 73 74 77 69 6c 6c  74 6f 70 69 63          |lastwill topic
[2023-02-16 15:03:35.378] [73040756] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:0000000f cur:0x20026660, end:0x20027840
[2023-02-16 15:03:35.378] [73040756] <dbg> net_mqtt_enc: (0x2000e310): >> val:000d cur:0x20026660, end:0x20027840
[2023-02-16 15:03:35.378] [73040757] <dbg> net_mqtt_enc: Encoding Will Message.
[2023-02-16 15:03:35.378]                                7b 22 6c 61 73 74 77 69  6c 6c 22 3a 20 22 6f 66 |{"lastwi ll": "of
[2023-02-16 15:03:35.378]                                66 6c 69 6e 65 22 7d                             |fline"}
[2023-02-16 15:03:35.378] [73040758] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:00000019 cur:0x2002666f, end:0x20027840
[2023-02-16 15:03:35.378] [73040759] <dbg> net_mqtt_enc: (0x2000e310): >> val:0017 cur:0x2002666f, end:0x20027840
[2023-02-16 15:03:35.379] [73040760] <dbg> net_mqtt_enc: (0x2000e310): << msg type:0x10 length:0x00000043
[2023-02-16 15:03:35.379] [73040760] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000043 cur:(nil), end:(nil)
[2023-02-16 15:03:35.379] [73040761] <dbg> net_mqtt_enc: (0x2000e310): Fixed header length = 02
[2023-02-16 15:03:35.379] [73040761] <dbg> net_mqtt_enc: (0x2000e310): >> val:10 cur:0x20026643, end:0x20027840
[2023-02-16 15:03:35.379] [73040762] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000043 cur:0x20026644, end:0x20027840
[2023-02-16 15:03:35.379] [73048374] <inf> net_mqtt: Connect completed
[2023-02-16 15:03:35.379] [73048388] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:545: Using send socket timeout of 60 seconds
[2023-02-16 15:03:35.379] [73048400] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:800: AWS IoT broker connection request sent
[2023-02-16 15:03:35.503] [73053797] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:592: mqtt_input call
[2023-02-16 15:03:35.779] [73053798] <dbg> net_mqtt: (0x2000e310): state:0x00000002
[2023-02-16 15:03:35.779] [73053802] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025442
[2023-02-16 15:03:35.779] [73053803] <dbg> net_mqtt_dec: (0x2000e310): << val:20
[2023-02-16 15:03:35.779] [73053803] <dbg> net_mqtt_dec: (0x2000e310): length:0x00000002
[2023-02-16 15:03:35.779] [73053806] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: Received MQTT_PKT_TYPE_CONNACK!
[2023-02-16 15:03:35.779] [73053807] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025442, end:0x20025444
[2023-02-16 15:03:35.779] [73053808] <dbg> net_mqtt_dec: (0x2000e310): << val:00
[2023-02-16 15:03:35.779] [73053809] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025443, end:0x20025444
[2023-02-16 15:03:35.779] [73053809] <dbg> net_mqtt_dec: (0x2000e310): << val:00
[2023-02-16 15:03:35.779] [73053810] <dbg> net_mqtt_dec: (0x2000e310): [CID 0x20010610]: session_present_flag: 0
[2023-02-16 15:03:35.779] [73053810] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: return_code: 0
[2023-02-16 15:03:35.779] [73053823] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:219: MQTT client connected!
[2023-02-16 15:03:35.781] [73057472] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:229: Subscribing to topics
[2023-02-16 15:03:35.781] [73057486] <dbg> loggers: 2023-02-16 21:03:33 debug aws_iot.c:132: Subscribing to application topic: curb/messages/devin-cell-test
[2023-02-16 15:03:35.781] [73057487] <dbg> net_mqtt: (0x2000e310): [CID 0x20010610]:[State 0x06]: >> message id 0xc4c1 topic count 0x0001
[2023-02-16 15:03:35.781] [73057504] <dbg> net_mqtt_enc: (0x2000e310): >> val:c4c1 cur:0x20026645, end:0x20027840
[2023-02-16 15:03:35.781] [73057504] <dbg> net_mqtt_enc: (0x2000e310): >> str_size:0000001f cur:0x20026647, end:0x20027840
[2023-02-16 15:03:35.782] [73057505] <dbg> net_mqtt_enc: (0x2000e310): >> val:001d cur:0x20026647, end:0x20027840
[2023-02-16 15:03:35.782] [73057506] <dbg> net_mqtt_enc: (0x2000e310): >> val:01 cur:0x20026666, end:0x20027840
[2023-02-16 15:03:35.782] [73057506] <dbg> net_mqtt_enc: (0x2000e310): << msg type:0x82 length:0x00000022
[2023-02-16 15:03:35.782] [73057507] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000022 cur:(nil), end:(nil)
[2023-02-16 15:03:35.782] [73057508] <dbg> net_mqtt_enc: (0x2000e310): Fixed header length = 02
[2023-02-16 15:03:35.782] [73057508] <dbg> net_mqtt_enc: (0x2000e310): >> val:82 cur:0x20026643, end:0x20027840
[2023-02-16 15:03:35.782] [73057511] <dbg> net_mqtt_enc: (0x2000e310): >> length:0x00000022 cur:0x20026644, end:0x20027840
[2023-02-16 15:03:35.782] [73057512] <dbg> net_mqtt: (0x2000e310): [0x20010610]: Transport writing 36 bytes.
[2023-02-16 15:03:36.307] [73062468] <dbg> net_mqtt: (0x2000e310): [0x20010610]: Transport write complete.
[2023-02-16 15:03:36.307] [73062470] <dbg> net_mqtt: (0x2000e310): [CID 0x20010610]:[State 0x06]: << result 0x00000000
[2023-02-16 15:03:36.307] [73073331] <dbg> loggers: 2023-02-16 21:03:34 debug aws_iot.c:592: mqtt_input call
[2023-02-16 15:03:36.307] [73073333] <dbg> net_mqtt: (0x2000e310): state:0x00000006
[2023-02-16 15:03:36.307] [73073335] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025442
[2023-02-16 15:03:36.307] [73073335] <dbg> net_mqtt_dec: (0x2000e310): << val:90
[2023-02-16 15:03:36.307] [73073336] <dbg> net_mqtt_dec: (0x2000e310): length:0x00000003
[2023-02-16 15:03:36.307] [73073339] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: Received MQTT_PKT_TYPE_SUBACK!
[2023-02-16 15:03:36.307] [73073340] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025442, end:0x20025445
[2023-02-16 15:03:36.307] [73073340] <dbg> net_mqtt_dec: (0x2000e310): << val:c4c1
[2023-02-16 15:03:36.307] [73073341] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025444, end:0x20025445
[2023-02-16 15:03:36.307] [73073342] <dbg> net_mqtt_dec: (0x2000e310): << bin len:00000001
[2023-02-16 15:03:48.497] [73478768] <dbg> loggers: 2023-02-16 21:03:46 debug aws_iot.c:592: mqtt_input call
[2023-02-16 15:03:48.855] [73478769] <dbg> net_mqtt: (0x2000e310): state:0x00000006
[2023-02-16 15:03:48.855] [73478773] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025442
[2023-02-16 15:03:48.855] [73478774] <dbg> net_mqtt_dec: (0x2000e310): << val:30
[2023-02-16 15:03:48.855] [73478776] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025440, end:0x20025443
[2023-02-16 15:03:48.855] [73478776] <dbg> net_mqtt_dec: (0x2000e310): << val:30
[2023-02-16 15:03:48.855] [73478777] <dbg> net_mqtt_dec: (0x2000e310): length:0x0000091d
[2023-02-16 15:03:48.855] [73478780] <dbg> net_mqtt_rx: (0x2000e310): [CID 0x20010610]: Received MQTT_PKT_TYPE_PUBLISH
[2023-02-16 15:03:48.855] [73478780] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025443, end:0x20025462
[2023-02-16 15:03:48.855] [73478781] <dbg> net_mqtt_dec: (0x2000e310): >> cur:0x20025443, end:0x20025462
[2023-02-16 15:03:48.855] [73478782] <dbg> net_mqtt_dec: (0x2000e310): << val:001d
[2023-02-16 15:03:48.855] [73478782] <dbg> net_mqtt_dec: (0x2000e310): << str_size:0000001f
[2023-02-16 15:03:48.855] [73478783] <dbg> net_mqtt_rx: (0x2000e310): PUB QoS:00, message len 000008fe, topic len 0000001d
