problem with UART update on nRF52840
Good morning,
in our project we would like to implement a DFU system of our Nordic 52840 through UART. In the final version of the board the 52840 will be connected to another MCU through serial, but for the moment we are updating the Nordic through a USB serial adapted connected to the rx/tx pins of the Nordic MCU and using the nrfutil.
What we observe is the following:
1) If I upload the fw through nrfutil after having loaded the SD and the BL itself, the procedure is successful in about 25 seconds
2) If I cancel the DFU procedure while it is ongoing and then I repeat it, only the first SLIP packets are exchanged and the first 4k data batch is sent. When the CRC is requested to the Nordic, no answer is apparently received and the program exits. Please see the attached log, obtained with the -v-v-v-v nrfutil option. The command I use is:
nrfutil -v -v -v -v dfu serial -cd 1 -p COM36 -fc 0 -b 115200 -pkg NordicPackage.zip
the used zip has been signed with a proprietary private key (.pem file) and of course the bootloader has been compiled with the related public key. I believe I am safe on the public/private key side cause otherwise the first update would not be successful. We also tried the procedure with the usb-serial option, but the behaviour seems to be the same.
Can you please tell me if you have any idea on what the problem is? I would (naively?) expect that if I interrupt the UART DFU procedure in the middle I should then be able to safely repeat it.
Please find attached:
the sdk_config.h used (it has been changed wrt the original one to adapt it to the project's needs)
the aforementioned log file
Thank you.
Stefano
C:\work\vdf_40170_ca\Prj\tools\App_Generator>nrfutil -v -v -v -v dfu serial -cd 1 -p COM36 -fc 0 -b 115200 -pkg P567_FPNFC_Mesh_App_0_0_0_JustNordic.zip
2023-02-17 09:03:42,181 Using board at serial port: COM36
2023-02-17 09:03:42,190 Sending Application image.
2023-02-17 09:04:13,673 SLIP: --> [9, 1]
2023-02-17 09:04:13,686 SLIP: <-- [96, 9, 1, 1]
2023-02-17 09:04:13,686 Serial: Set Packet Receipt Notification 0
2023-02-17 09:04:13,686 SLIP: --> [2, 0, 0]
2023-02-17 09:04:13,702 SLIP: <-- [96, 2, 1]
2023-02-17 09:04:13,702 SLIP: --> [7]
2023-02-17 09:04:13,718 SLIP: <-- [96, 7, 1, 131, 0]
2023-02-17 09:04:13,718 Sending init packet...
2023-02-17 09:04:13,718 Serial: Selecting Object: type:1
2023-02-17 09:04:13,719 SLIP: --> [6, 1]
2023-02-17 09:04:13,733 SLIP: <-- [96, 6, 1, 0, 2, 0, 0, 141, 0, 0, 0, 133, 3, 198, 153]
2023-02-17 09:04:13,733 Serial: Object selected:  max_size:512 offset:141 crc:2579891077
2023-02-17 09:04:13,734 SLIP: --> [4]
2023-02-17 09:04:13,749 SLIP: <-- [96, 4, 1]
2023-02-17 09:04:13,749 Sending firmware file...
2023-02-17 09:04:13,750 Serial: Selecting Object: type:2
2023-02-17 09:04:13,750 SLIP: --> [6, 2]
2023-02-17 09:04:13,766 SLIP: <-- [96, 6, 1, 0, 16, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,766 Serial: Object selected:  max_size:4096 offset:0 crc:0
2023-02-17 09:04:13,766 SLIP: --> [1, 2, 0, 16, 0, 0]
2023-02-17 09:04:13,781 SLIP: <-- [96, 1, 1]
2023-02-17 09:04:13,781 Serial: Streaming Data: len:4096 offset:0 crc:0x00000000
2023-02-17 09:04:13,781 SLIP: --> [8, 0, 253, 3, 32, 9, 17, 4, 0, 49, 17, 4, 0, 51, 17, 4, 0, 53, 17, 4, 0, 55, 17, 4, 0, 57, 17, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 59, 17, 4, 0, 61, 17, 4, 0, 0, 0, 0, 0, 63, 17, 4, 0, 65, 17, 4, 0]
2023-02-17 09:04:13,783 SLIP: --> [8, 67, 17, 4, 0, 67, 17, 4, 0, 101, 34, 4, 0, 65, 40, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 177, 32, 4, 0, 133, 35, 4, 0, 67, 17, 4, 0, 53, 37, 4, 0, 137, 207, 2, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0]
2023-02-17 09:04:13,788 SLIP: --> [8, 105, 53, 4, 0, 89, 178, 3, 0, 65, 12, 3, 0, 197, 28, 4, 0, 41, 179, 3, 0, 67, 17, 4, 0, 153, 24, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 73, 37, 4, 0, 67, 17, 4, 0, 221, 34, 4, 0, 67, 17, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,794 SLIP: --> [8, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 67, 17, 4, 0, 41, 180, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 67, 17, 4, 0, 0, 0, 0, 0, 67, 17, 4, 0]
2023-02-17 09:04:13,800 SLIP: --> [8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,805 SLIP: --> [8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,811 SLIP: --> [8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,816 SLIP: --> [8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2023-02-17 09:04:13,823 SLIP: --> [8, 16, 181, 5, 76, 35, 120, 51, 185, 4, 75, 19, 177, 4, 72, 175, 243, 0, 128, 1, 35, 35, 112, 16, 189, 72, 57, 0, 32, 0, 0, 0, 0, 112, 93, 5, 0, 8, 181, 3, 75, 27, 177, 3, 73, 3, 72, 175, 243, 0, 128, 8, 189, 0, 0, 0, 0, 76, 57, 0, 32, 112, 93, 5, 0]
2023-02-17 09:04:13,828 SLIP: --> [8, 21, 75, 0, 43, 8, 191, 19, 75, 157, 70, 163, 245, 128, 58, 0, 33, 139, 70, 15, 70, 19, 72, 20, 74, 18, 26, 38, 240, 145, 252, 15, 75, 0, 43, 0, 208, 152, 71, 14, 75, 0, 43, 0, 208, 152, 71, 0, 32, 0, 33, 4, 0, 13, 0, 13, 72, 0, 40, 2, 208, 12, 72, 40, 240]
2023-02-17 09:04:13,834 SLIP: --> [8, 95, 254, 38, 240, 65, 248, 32, 0, 41, 0, 33, 240, 41, 254, 38, 240, 43, 248, 0, 191, 0, 0, 8, 0, 0, 253, 3, 32, 0, 0, 0, 0, 0, 0, 0, 0, 72, 57, 0, 32, 116, 205, 0, 32, 65, 239, 4, 0, 85, 255, 4, 0, 56, 181, 4, 70, 69, 24, 172, 66, 1, 209, 0, 32]
2023-02-17 09:04:13,840 SLIP: --> [8, 5, 224, 20, 248, 1, 11, 23, 240, 41, 254, 0, 40, 245, 208, 56, 189, 56, 181, 5, 70, 12, 70, 21, 240, 65, 250, 41, 70, 21, 240, 68, 250, 160, 66, 52, 191, 0, 32, 1, 32, 56, 189, 55, 181, 13, 70, 4, 70, 104, 185, 169, 178, 0, 34, 32, 70, 1, 240, 83, 253, 1, 33, 141, 248]
2023-02-17 09:04:13,846 SLIP: --> [8, 7, 0, 13, 241, 7, 0, 255, 247, 213, 255, 3, 176, 48, 189, 255, 247, 209, 255, 0, 40, 249, 209, 236, 231, 7, 181, 12, 72, 3, 33, 255, 247, 228, 255, 11, 75, 27, 104, 91, 4, 13, 213, 10, 75, 27, 104, 3, 43, 9, 221, 9, 75, 9, 74, 211, 248, 4, 53, 9, 73, 0, 146, 4, 32]
2023-02-17 09:04:13,851 SLIP: --> [8, 87, 34, 13, 240, 59, 249, 3, 176, 93, 248, 4, 251, 68, 18, 5, 0, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 194, 17, 5, 0, 180, 17, 5, 0, 1, 72, 5, 33, 255, 247, 191, 191, 71, 18, 5, 0, 7, 181, 12, 72, 3, 33, 255, 247, 184, 255, 11, 75, 27, 104, 91, 4]
2023-02-17 09:04:13,857 SLIP: --> [8, 13, 213, 10, 75, 27, 104, 3, 43, 9, 221, 9, 75, 9, 74, 211, 248, 4, 53, 9, 73, 0, 146, 4, 32, 105, 34, 13, 240, 15, 249, 3, 176, 93, 248, 4, 251, 76, 18, 5, 0, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 195, 17, 5, 0, 180, 17, 5, 0, 1, 72, 3, 33]
2023-02-17 09:04:13,862 SLIP: --> [8, 255, 247, 147, 191, 79, 18, 5, 0, 31, 181, 2, 35, 141, 248, 5, 0, 141, 248, 4, 48, 56, 34, 141, 248, 10, 48, 5, 33, 189, 248, 4, 48, 173, 248, 8, 32, 2, 168, 173, 248, 11, 48, 255, 247, 126, 255, 5, 176, 93, 248, 4, 251, 21, 240, 178, 185, 8, 181, 23, 240, 183, 253, 128, 178]
2023-02-17 09:04:13,868 SLIP: --> [8, 8, 189, 7, 181, 13, 241, 7, 0, 23, 240, 114, 253, 32, 185, 157, 248, 7, 0, 3, 176, 93, 248, 4, 251, 0, 32, 250, 231, 112, 181, 13, 70, 136, 176, 20, 70, 0, 42, 69, 208, 54, 41, 39, 208, 7, 216, 1, 41, 0, 240, 140, 128, 25, 41, 117, 208, 23, 240, 74, 253, 58, 224, 55, 41]
2023-02-17 09:04:13,874 SLIP: --> [8, 58, 208, 56, 41, 248, 209, 16, 70, 0, 240, 62, 254, 196, 178, 255, 44, 72, 78, 173, 248, 20, 0, 68, 209, 51, 104, 88, 4, 42, 213, 70, 75, 27, 104, 3, 43, 38, 221, 69, 75, 69, 74, 211, 248, 4, 53, 0, 146, 156, 34, 68, 73, 4, 32, 13, 240, 161, 248, 27, 224, 17, 70, 2, 32]
2023-02-17 09:04:13,879 SLIP: --> [8, 0, 240, 92, 251, 176, 185, 59, 75, 27, 104, 93, 4, 13, 213, 58, 75, 27, 104, 3, 43, 9, 221, 57, 75, 59, 74, 211, 248, 4, 53, 0, 146, 129, 34, 56, 73, 4, 32, 13, 240, 137, 248, 23, 240, 17, 253, 0, 32, 255, 247, 50, 255, 8, 176, 112, 189, 17, 70, 3, 32, 0, 240, 62, 251]
2023-02-17 09:04:13,885 SLIP: --> [8, 0, 40, 247, 209, 43, 75, 27, 104, 92, 4, 238, 213, 42, 75, 27, 104, 3, 43, 234, 221, 41, 75, 45, 74, 211, 248, 4, 53, 0, 146, 141, 34, 223, 231, 2, 35, 173, 248, 27, 0, 5, 33, 6, 168, 141, 248, 26, 48, 173, 248, 24, 80, 255, 247, 249, 254, 51, 104, 89, 4, 218, 213, 30, 75]
2023-02-17 09:04:13,891 SLIP: --> [8, 27, 104, 3, 43, 214, 221, 157, 248, 21, 32, 28, 75, 29, 73, 211, 248, 4, 53, 205, 233, 1, 66, 30, 74, 0, 146, 4, 32, 169, 34, 13, 240, 77, 248, 199, 231, 255, 247, 109, 255, 99, 120, 131, 66, 194, 209, 17, 75, 27, 104, 90, 4, 190, 213, 16, 75, 27, 104, 3, 43, 186, 221, 15, 75]
2023-02-17 09:04:13,896 SLIP: --> [8, 20, 74, 211, 248, 4, 53, 0, 146, 179, 34, 146, 231, 255, 247, 89, 255, 99, 120, 131, 66, 174, 209, 7, 75, 27, 104, 91, 4, 170, 213, 6, 75, 27, 104, 3, 43, 166, 221, 5, 75, 11, 74, 211, 248, 4, 53, 0, 146, 188, 34, 126, 231, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64]
2023-02-17 09:04:13,903 SLIP: --> [8, 253, 17, 5, 0, 180, 17, 5, 0, 205, 17, 5, 0, 229, 17, 5, 0, 24, 18, 5, 0, 59, 18, 5, 0, 58, 18, 5, 0, 112, 181, 14, 70, 21, 70, 0, 36, 165, 66, 6, 235, 4, 0, 2, 208, 23, 240, 160, 252, 8, 177, 160, 178, 112, 189, 1, 52, 244, 231, 8, 70, 17, 70, 8, 177]
2023-02-17 09:04:13,909 SLIP: --> [8, 255, 247, 120, 190, 112, 71, 7, 181, 141, 248, 7, 16, 13, 241, 7, 0, 1, 33, 255, 247, 111, 254, 3, 176, 93, 248, 4, 251, 23, 240, 120, 188, 31, 40, 138, 191, 5, 75, 79, 240, 160, 67, 0, 240, 31, 0, 211, 248, 16, 53, 35, 250, 0, 240, 0, 240, 1, 0, 112, 71, 0, 3, 0, 80]
2023-02-17 09:04:13,914 SLIP: --> [8, 4, 75, 26, 120, 26, 177, 152, 120, 0, 240, 1, 0, 112, 71, 1, 32, 250, 231, 0, 191, 101, 57, 0, 32, 12, 75, 27, 104, 91, 4, 7, 181, 14, 213, 11, 75, 27, 104, 3, 43, 10, 221, 10, 75, 10, 74, 211, 248, 4, 53, 10, 73, 0, 146, 4, 32, 64, 242, 63, 18, 12, 240, 190, 255]
2023-02-17 09:04:13,919 SLIP: --> [8, 7, 75, 0, 34, 90, 112, 3, 176, 93, 248, 4, 251, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 121, 18, 5, 0, 102, 18, 5, 0, 101, 57, 0, 32, 112, 181, 78, 77, 44, 120, 1, 44, 136, 176, 46, 70, 52, 208, 2, 44, 58, 208, 75, 78, 52, 120, 98, 30, 1, 42, 43, 216]
2023-02-17 09:04:13,926 SLIP: --> [8, 163, 30, 92, 66, 92, 65, 3, 37, 56, 35, 141, 248, 20, 80, 141, 248, 21, 64, 173, 248, 24, 48, 2, 35, 141, 248, 26, 48, 5, 33, 189, 248, 20, 48, 173, 248, 27, 48, 6, 168, 255, 247, 31, 254, 62, 75, 27, 104, 90, 4, 15, 213, 61, 75, 27, 104, 171, 66, 11, 221, 60, 75, 61, 74]
2023-02-17 09:04:13,931 SLIP: --> [8, 211, 248, 4, 53, 60, 73, 0, 146, 205, 233, 1, 84, 177, 34, 4, 32, 12, 240, 116, 255, 0, 35, 51, 112, 8, 176, 112, 189, 2, 32, 30, 240, 71, 252, 0, 40, 199, 209, 2, 35, 43, 112, 196, 231, 30, 240, 128, 252, 0, 40, 192, 209, 49, 75, 24, 104, 154, 136, 6, 144, 155, 121, 141, 248]
2023-02-17 09:04:13,937 SLIP: --> [8, 30, 48, 32, 70, 173, 248, 28, 32, 30, 240, 184, 252, 38, 75, 0, 40, 51, 209, 43, 74, 105, 120, 146, 120, 27, 104, 145, 66, 3, 244, 128, 67, 24, 209, 107, 177, 33, 75, 27, 104, 4, 43, 9, 221, 32, 75, 37, 74, 211, 248, 4, 53, 32, 73, 0, 146, 5, 32, 130, 34, 12, 240, 62, 255]
2023-02-17 09:04:13,943 SLIP: --> [8, 0, 35, 8, 33, 6, 168, 141, 248, 30, 48, 32, 240, 177, 252, 0, 35, 51, 112, 144, 231, 123, 177, 21, 75, 27, 104, 4, 43, 11, 221, 20, 75, 211, 248, 4, 53, 205, 233, 1, 33, 23, 74, 0, 146, 18, 73, 136, 34, 5, 32, 12, 240, 35, 255, 2, 35, 227, 231, 27, 104, 89, 4, 13, 213]
2023-02-17 09:04:13,948 SLIP: --> [8, 10, 75, 27, 104, 4, 43, 9, 221, 9, 75, 16, 74, 211, 248, 4, 53, 9, 73, 0, 146, 5, 32, 143, 34, 12, 240, 16, 255, 1, 35, 208, 231, 105, 57, 0, 32, 100, 57, 0, 32, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 24, 18, 5, 0, 102, 18, 5, 0, 152, 22, 5, 0]
2023-02-17 09:04:13,954 SLIP: --> [8, 213, 200, 0, 32, 159, 18, 5, 0, 183, 18, 5, 0, 235, 18, 5, 0, 45, 233, 240, 65, 5, 70, 198, 176, 12, 70, 0, 41, 0, 240, 132, 128, 68, 75, 15, 136, 26, 104, 18, 244, 128, 79, 152, 70, 23, 208, 66, 75, 27, 104, 3, 43, 19, 221, 65, 75, 138, 120, 211, 248, 4, 53, 2, 146]
2023-02-17 09:04:13,960 SLIP: --> [8, 160, 241, 54, 2, 62, 73, 210, 178, 4, 32, 81, 248, 34, 32, 1, 146, 60, 74, 0, 146, 60, 73, 64, 242, 107, 18, 12, 240, 207, 254, 55, 45, 101, 209, 163, 120, 30, 70, 0, 43, 53, 208, 216, 248, 0, 32, 82, 4, 49, 213, 49, 74, 18, 104, 3, 42, 45, 221, 3, 51, 51, 74, 128, 43]
2023-02-17 09:04:13,965 SLIP: --> [8, 40, 191, 128, 35, 210, 248, 0, 192, 32, 70, 5, 170, 3, 235, 4, 14, 16, 248, 1, 27, 79, 234, 17, 24, 1, 240, 15, 1, 28, 249, 8, 128, 130, 248, 0, 128, 28, 249, 1, 16, 81, 112, 134, 69, 2, 241, 2, 2, 238, 209, 5, 169, 0, 34, 1, 248, 19, 32, 32, 75, 36, 74, 211, 248]
2023-02-17 09:04:13,971 SLIP: --> [8, 4, 53, 1, 146, 35, 74, 2, 145, 0, 146, 31, 73, 79, 244, 185, 114, 4, 32, 12, 240, 147, 254, 179, 28, 26, 10, 141, 248, 21, 32, 141, 248, 23, 112, 5, 34, 5, 169, 0, 32, 63, 10, 141, 248, 20, 80, 141, 248, 22, 48, 141, 248, 24, 112, 255, 247, 128, 254, 0, 34, 5, 33, 5, 168]
2023-02-17 09:04:13,976 SLIP: --> [8, 1, 240, 111, 250, 5, 70, 94, 177, 3, 52, 2, 70, 49, 70, 32, 70, 1, 240, 103, 250, 50, 70, 5, 70, 33, 70, 0, 32, 255, 247, 109, 254, 41, 70, 0, 32, 255, 247, 111, 254, 70, 176, 189, 232, 240, 129, 0, 38, 209, 231, 0, 191, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64]
2023-02-17 09:04:13,982 SLIP: --> [8, 184, 22, 5, 0, 6, 19, 5, 0, 102, 18, 5, 0, 228, 45, 0, 32, 217, 25, 5, 0, 37, 19, 5, 0, 3, 120, 2, 43, 2, 209, 64, 104, 25, 240, 219, 185, 1, 43, 250, 208, 112, 71, 0, 0, 8, 181, 33, 240, 193, 250, 3, 75, 0, 40, 20, 191, 2, 34, 1, 34, 26, 112, 8, 189]
2023-02-17 09:04:13,989 SLIP: --> [8, 100, 57, 0, 32, 14, 74, 0, 35, 50, 248, 51, 16, 129, 66, 3, 209, 2, 235, 195, 3, 88, 104, 112, 71, 1, 51, 13, 43, 244, 209, 1, 40, 8, 208, 2, 40, 8, 208, 3, 40, 8, 209, 2, 34, 5, 75, 3, 235, 194, 3, 239, 231, 0, 34, 249, 231, 1, 34, 247, 231, 2, 72, 112, 71]
2023-02-17 09:04:13,994 SLIP: --> [8, 220, 22, 5, 0, 196, 22, 5, 0, 45, 19, 5, 0, 255, 247, 22, 189, 55, 181, 20, 77, 43, 120, 19, 187, 19, 76, 163, 120, 165, 43, 19, 75, 27, 104, 12, 191, 90, 34, 165, 34, 91, 4, 162, 112, 14, 213, 16, 75, 27, 104, 4, 43, 10, 221, 15, 75, 15, 73, 211, 248, 4, 53, 1, 146]
2023-02-17 09:04:14,000 SLIP: --> [8, 14, 74, 0, 146, 5, 32, 204, 34, 12, 240, 248, 253, 163, 120, 107, 112, 1, 36, 44, 112, 255, 247, 70, 254, 32, 70, 3, 176, 48, 189, 0, 32, 251, 231, 0, 191, 105, 57, 0, 32, 213, 200, 0, 32, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 102, 18, 5, 0, 63, 19, 5, 0]
2023-02-17 09:04:14,006 SLIP: --> [8, 240, 181, 57, 76, 35, 120, 135, 176, 203, 185, 98, 120, 186, 185, 227, 120, 54, 78, 12, 43, 30, 217, 51, 104, 90, 4, 14, 213, 52, 75, 27, 104, 3, 43, 10, 221, 51, 75, 52, 74, 211, 248, 4, 53, 51, 73, 0, 146, 4, 32, 79, 244, 211, 114, 12, 240, 193, 253, 1, 35, 35, 112, 0, 32]
2023-02-17 09:04:14,012 SLIP: --> [8, 1, 240, 192, 249, 16, 177, 0, 32, 1, 240, 12, 250, 255, 247, 10, 254, 7, 176, 240, 189, 1, 35, 42, 72, 99, 112, 79, 244, 0, 65, 20, 240, 33, 254, 51, 104, 39, 77, 19, 244, 128, 79, 22, 208, 32, 75, 27, 104, 3, 43, 18, 221, 226, 120, 31, 75, 5, 235, 194, 1, 53, 248, 50, 32]
2023-02-17 09:04:14,017 SLIP: --> [8, 211, 248, 4, 53, 73, 104, 1, 146, 31, 74, 2, 145, 0, 146, 27, 73, 79, 244, 216, 114, 4, 32, 12, 240, 145, 253, 51, 104, 226, 120, 91, 4, 53, 248, 50, 112, 19, 213, 18, 75, 27, 104, 3, 43, 15, 221, 5, 235, 194, 5, 16, 75, 106, 104, 211, 248, 4, 53, 1, 146, 19, 74, 0, 146]
2023-02-17 09:04:14,023 SLIP: --> [8, 14, 73, 2, 151, 79, 244, 202, 114, 4, 32, 12, 240, 119, 253, 0, 35, 5, 169, 54, 32, 141, 248, 22, 48, 173, 248, 20, 112, 255, 247, 120, 254, 227, 120, 1, 51, 227, 112, 170, 231, 101, 57, 0, 32, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 98, 19, 5, 0, 102, 18, 5, 0]
2023-02-17 09:04:14,029 SLIP: --> [8, 108, 57, 0, 32, 220, 22, 5, 0, 114, 19, 5, 0, 141, 19, 5, 0, 8, 181, 7, 75, 7, 74, 8, 72, 0, 33, 25, 112, 89, 112, 217, 112, 20, 240, 174, 253, 24, 177, 189, 232, 8, 64, 25, 240, 214, 184, 8, 189, 101, 57, 0, 32, 25, 102, 2, 0, 68, 23, 5, 0, 45, 233, 240, 79]
2023-02-17 09:04:14,034 SLIP: --> [8, 4, 70, 207, 176, 13, 70, 0, 41, 0, 240, 165, 130, 131, 30, 1, 43, 0, 242, 32, 130, 75, 136, 18, 43, 1, 217, 0, 36, 8, 225, 1, 43, 26, 217, 0, 32, 255, 247, 77, 252, 105, 120, 6, 70, 1, 240, 10, 249, 104, 112, 0, 32, 173, 248, 32, 96, 255, 247, 67, 252, 105, 120, 6, 70]
2023-02-17 09:04:14,039 SLIP: --> [8, 1, 240, 0, 249, 189, 248, 32, 48, 104, 112, 67, 234, 6, 32, 107, 136, 173, 248, 32, 0, 2, 59, 107, 128, 106, 136, 114, 177, 13, 241, 34, 1, 0, 32, 255, 247, 251, 252, 107, 136, 152, 66, 1, 70, 213, 209, 106, 120, 13, 241, 34, 0, 1, 240, 245, 248, 104, 112, 0, 32, 255, 247, 33, 252]
2023-02-17 09:04:14,046 SLIP: --> [8, 107, 120, 131, 66, 201, 209, 180, 79, 181, 248, 2, 128, 59, 104, 3, 44, 3, 244, 128, 67, 62, 70, 0, 240, 125, 129, 195, 177, 175, 75, 27, 104, 3, 43, 20, 221, 189, 248, 32, 64, 173, 75, 32, 70, 211, 248, 4, 53, 5, 147, 255, 247, 167, 254, 171, 74, 1, 144, 0, 146, 205, 233, 2, 72]
2023-02-17 09:04:14,052 SLIP: --> [8, 5, 155, 169, 73, 79, 244, 24, 114, 4, 32, 12, 240, 215, 252, 167, 76, 111, 136, 1, 35, 163, 112, 51, 104, 3, 244, 128, 67, 0, 47, 64, 240, 222, 128, 187, 177, 157, 75, 27, 104, 3, 43, 19, 221, 189, 248, 32, 80, 155, 75, 40, 70, 211, 248, 4, 53, 5, 147, 255, 247, 131, 254, 156, 74]
2023-02-17 09:04:14,057 SLIP: --> [8, 0, 146, 205, 233, 1, 5, 5, 155, 151, 73, 64, 242, 5, 34, 4, 32, 12, 240, 180, 252, 189, 248, 32, 0, 6, 169, 30, 240, 123, 248, 0, 40, 89, 209, 51, 104, 157, 248, 26, 128, 189, 248, 24, 80, 88, 4, 193, 70, 35, 213, 223, 248, 40, 162, 218, 248, 0, 48, 3, 43, 29, 221, 223, 248]
2023-02-17 09:04:14,063 SLIP: --> [8, 32, 178, 40, 70, 219, 248, 4, 53, 5, 147, 255, 247, 91, 254, 137, 74, 5, 155, 1, 144, 0, 146, 205, 233, 2, 88, 131, 73, 64, 242, 221, 18, 4, 32, 12, 240, 139, 252, 51, 104, 205, 248, 20, 176, 19, 244, 128, 79, 3, 208, 218, 248, 0, 48, 3, 43, 94, 220, 54, 35, 141, 248, 52, 48]
2023-02-17 09:04:14,069 SLIP: --> [8, 9, 241, 2, 3, 27, 10, 141, 248, 55, 80, 5, 34, 45, 10, 13, 169, 0, 32, 8, 241, 2, 8, 141, 248, 53, 48, 141, 248, 56, 80, 141, 248, 54, 128, 255, 247, 106, 252, 0, 34, 5, 33, 13, 168, 1, 240, 89, 248, 5, 70, 185, 241, 0, 15, 10, 208, 2, 70, 73, 70, 7, 152, 1, 240]
2023-02-17 09:04:14,075 SLIP: --> [8, 80, 248, 7, 153, 5, 70, 74, 70, 0, 32, 255, 247, 86, 252, 41, 70, 0, 32, 255, 247, 88, 252, 0, 37, 148, 248, 0, 128, 184, 241, 0, 15, 32, 209, 255, 177, 227, 120, 100, 74, 1, 59, 50, 248, 51, 32, 189, 248, 32, 48, 154, 66, 22, 209, 97, 72, 20, 240, 0, 253, 51, 104, 132, 248]
2023-02-17 09:04:14,080 SLIP: --> [8, 1, 128, 89, 4, 14, 213, 85, 75, 27, 104, 3, 43, 10, 221, 84, 75, 91, 74, 211, 248, 4, 53, 84, 73, 0, 146, 4, 32, 64, 242, 57, 18, 12, 240, 44, 252, 0, 45, 0, 240, 148, 128, 80, 75, 0, 36, 156, 112, 32, 70, 79, 176, 189, 232, 240, 143, 82, 75, 7, 154, 211, 248, 0, 224]
2023-02-17 09:04:14,085 SLIP: --> [8, 184, 241, 128, 15, 196, 70, 13, 171, 40, 191, 79, 240, 128, 12, 12, 235, 2, 10, 24, 70, 146, 69, 3, 241, 2, 3, 17, 209, 0, 35, 0, 248, 28, 48, 5, 155, 72, 74, 211, 248, 4, 53, 1, 146, 71, 74, 2, 144, 0, 146, 61, 73, 79, 244, 239, 114, 4, 32, 12, 240, 255, 251, 124, 231]
2023-02-17 09:04:14,092 SLIP: --> [8, 18, 248, 1, 27, 79, 234, 17, 27, 1, 240, 15, 1, 30, 249, 11, 176, 3, 248, 2, 188, 30, 249, 1, 16, 3, 248, 1, 28, 218, 231, 27, 179, 223, 248, 184, 144, 217, 248, 0, 48, 3, 43, 29, 221, 189, 248, 32, 128, 43, 77, 64, 70, 213, 248, 4, 53, 5, 147, 255, 247, 163, 253, 52, 74]
2023-02-17 09:04:14,097 SLIP: --> [8, 5, 155, 1, 144, 205, 233, 2, 135, 0, 146, 39, 73, 79, 244, 4, 114, 4, 32, 12, 240, 211, 251, 51, 104, 19, 244, 128, 79, 168, 70, 3, 208, 217, 248, 0, 48, 3, 43, 5, 220, 57, 70, 8, 168, 30, 240, 188, 251, 5, 70, 113, 231, 35, 75, 186, 28, 211, 248, 0, 192, 128, 42, 13, 171]
2023-02-17 09:04:14,103 SLIP: --> [8, 40, 191, 128, 34, 13, 241, 32, 14, 0, 32, 29, 70, 30, 248, 1, 27, 79, 234, 17, 25, 1, 240, 15, 1, 28, 249, 9, 144, 131, 248, 0, 144, 1, 48, 28, 249, 1, 16, 89, 112, 130, 66, 3, 241, 2, 3, 237, 209, 0, 35, 5, 248, 18, 48, 20, 74, 216, 248, 4, 53, 1, 146, 19, 74]
2023-02-17 09:04:14,109 SLIP: --> [8, 0, 146, 9, 73, 2, 149, 64, 242, 17, 34, 4, 32, 12, 240, 150, 251, 202, 231, 165, 112, 1, 36, 107, 231, 224, 45, 0, 32, 220, 45, 0, 32, 0, 16, 1, 64, 174, 19, 5, 0, 102, 18, 5, 0, 101, 57, 0, 32, 228, 19, 5, 0, 13, 20, 5, 0, 220, 22, 5, 0, 108, 57, 0, 32]
2023-02-17 09:04:14,114 SLIP: --> [8, 99, 20, 5, 0, 228, 45, 0, 32, 217, 25, 5, 0, 37, 19, 5, 0, 50, 20, 5, 0, 27, 179, 223, 248, 232, 145, 217, 248, 0, 48, 3, 43, 29, 221, 189, 248, 32, 64, 109, 78, 32, 70, 214, 248, 4, 53, 5, 147, 255, 247, 40, 253, 106, 74, 5, 155, 1, 144, 0, 146, 205, 233, 2, 72]
2023-02-17 09:04:14,120 SLIP: --> [8, 104, 73, 79, 244, 27, 114, 4, 32, 12, 240, 88, 251, 59, 104, 19, 244, 128, 79, 180, 70, 3, 208, 217, 248, 0, 48, 3, 43, 13, 220, 98, 78, 105, 136, 1, 36, 8, 168, 180, 112, 30, 240, 62, 251, 0, 40, 127, 244, 28, 175, 176, 112, 255, 247, 28, 250, 26, 231, 107, 136, 91, 74, 2, 51]
2023-02-17 09:04:14,126 SLIP: --> [8, 20, 104, 128, 43, 13, 170, 40, 191, 128, 35, 8, 174, 0, 32, 23, 70, 22, 248, 1, 27, 79, 234, 17, 30, 1, 240, 15, 1, 20, 249, 14, 224, 130, 248, 0, 224, 1, 48, 97, 86, 81, 112, 131, 66, 2, 241, 2, 2, 238, 209, 0, 34, 7, 248, 19, 32, 77, 74, 220, 248, 4, 53, 1, 146]
2023-02-17 09:04:14,131 SLIP: --> [8, 76, 74, 0, 146, 71, 73, 2, 151, 64, 242, 109, 34, 4, 32, 12, 240, 21, 251, 196, 231, 144, 179, 1, 40, 127, 244, 223, 173, 223, 248, 28, 129, 216, 248, 0, 48, 91, 4, 36, 213, 223, 248, 20, 145, 217, 248, 0, 48, 3, 43, 30, 221, 14, 136, 57, 79, 48, 70, 215, 248, 4, 53, 5, 147]
2023-02-17 09:04:14,137 SLIP: --> [8, 255, 247, 192, 252, 170, 120, 5, 155, 1, 144, 205, 233, 2, 98, 58, 74, 0, 146, 52, 73, 64, 242, 147, 34, 4, 32, 12, 240, 239, 250, 216, 248, 0, 48, 19, 244, 128, 79, 188, 70, 3, 208, 217, 248, 0, 48, 3, 43, 36, 220, 41, 70, 55, 32, 255, 247, 235, 251, 185, 230, 47, 75, 27, 104]
2023-02-17 09:04:14,144 SLIP: --> [3]
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\Scripts\nrfutil-script.py", line 33, in <module>
    sys.exit(load_entry_point('nrfutil==6.1.3', 'console_scripts', 'nrfutil')())
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\click\core.py", line 1128, in __call__
    return self.main(*args, **kwargs)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\click\core.py", line 1053, in main
    rv = self.invoke(ctx)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\click\core.py", line 1659, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\click\core.py", line 1395, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\click\core.py", line 754, in invoke
    return __callback(*args, **kwargs)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\__main__.py", line 1063, in serial
    do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\__main__.py", line 980, in do_serial
    dfu.dfu_send_images()
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
    self._dfu_send_image(self.manifest.application)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\dfu\dfu.py", line 100, in _dfu_send_image
    self.dfu_transport.send_firmware(data)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 301, in send_firmware
    response['crc'] = self.__stream_data(data=data, crc=response['crc'], offset=i)
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 474, in __stream_data
    response = self.__calculate_checksum()
  File "C:\Users\uPD008\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 412, in __calculate_checksum
    raise NordicSemiException('Did not receive checksum response from DFU target. '
pc_ble_driver_py.exceptions.NordicSemiException: Did not receive checksum response from DFU target. If MSD is enabled on the target device, try to disable it ref. https://wiki.segger.com/index.php?title=J-Link-OB_SAM3U
7282.sdk_config.h
  • Dear Hung Bui,
    Thank you for your quick answer. The 0x57000 address is not where the application starts (instead it correctly starts at the flash address in the linker script, 0x26000) but where the fw I am sending through the slip protocol is cached before being moved to 0x26000. My understanding is that in the dual bank framework the bootloader starts caching the fw I send through the slip protocol from the first useful address after the "old" application ends, in blocks of 0x1000: indeed my old application starts at 0x26000 and ends at 0x56EE0 and, in the case of successful update (_1 file) I see a copy of the application fw from 0x57000 on. My settings in the sdk_config is not to force dual bank update, but I believe there is enough space to proceed with dual bank (and I assume that in a single bank update an abrupt interruption of the update process would corrupt the application fw).
    If I interrupt the update process (_2 file) I see 4k (sorry if in my previous message I said 1k, it is 0x1000=4096) set to 0xFF from the address 0x64000 to 0x65000, which should correspond to the 0x1000 being transmitted when I hit the ctrl-c keys. If I then retry the process (_3 file), the initial 0x1000 (i.e. from 0x57000 to 0x58000) is set to 0xff, which means that the update failed when trying to upload the first 4k data.
    I should also mention that the first image present before the first successful update is larger than the one uploaded through the serial protocol, as it contains some additional, extra-fw data we need for our application, which you can see in the _1 dump starting at 0x58000 and finishing at about 0x71000. Even if those data are never reached by the application fw, the packet has been generated in such a way that those bytes are part of the fw itself, i.e. the computed crc is coherent (and indeed the Nordic correctly boots after the application has been loaded). Can you clarify to me how exactly the bootloader sets the initial address where the CACHED fw is stored during the update process before being moved to the application address? In our case I would expect the bootloader to cache the new image at about 0x72000, instead it starts at 0x57000, thus erasing our custom data (which are not relevant to us anymore at that moment).
    The dump was taken with J-flash v. 7.84.
    Thank you.
    Stefano
  • Hi Stefano,
    Thanks for the explanation.
    Your understanding is correct. The bootloader will allocate the new image into bank 1 starting from the first page right after the current application.
    If you have a look at update_data_addr_get() you can find how it's calculated.
    Basically nrf_dfu_bank1_start_addr() = nrf_dfu_bank0_start_addr() + bank_0.image_size
    nrf_dfu_bank0_start_addr() is either MBR or softdevice size, depends if the softdevice is flashed or not.
    bank_0.image_size is the image size you provide in your init packet of the previous DFU update.
    So what I suspect is that the image size may not match with the actual image size you have including the extra data pages.
    I would suggest to test first with a "normal"  image , for example our example project. And make sure you can continue after  you break the DFU process. After that you can test with your customized image. Please double check which bank_0.image_size you have.
  • Dear Hung Bui,
    I will perform the test you advised tomorrow morning, could not do it today. Just one question in the meanwhile: I create the manipulated image by adding the additional firmware to the standard Nordic firmware with srecord and then I sign the resulting hex (with "nrf package generate") to be able to upload it to a secure bootloader. I guess what you said means that somewhere in the new hex there is still the value of the standalone nordic image (i.e. bank_0.image_size) in place of the Nordic+custom data size, and this somehow causes problems when the update is interrupted (but does not seem to prevent a "regular" update). Can you tell me exactly where this value is in the hex?
    Thank you.
    Stefano
  • Hi Stefano,
    The bank_0.image_size that you can find in the code is from the init data inside the .zip file that you use to DFU update the current firmware. If you have a look at a DFU .zip package you will find this (here is the test image in the SDK)
    The .dat file contain the information about the size of the image. It will be transmitted to the bootloader and the bootloader use the information to receive the image. Please take a look here: https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.1.0/lib_bootloader_dfu_validation.html?cp=9_1_3_5_1_1_0#lib_bootloader_dfu_init
    If you generate the .zip file after you manipulate with the hex I think the app_size should reflect the new size of the hex. I am not aware of anywhere in the hex we store the original size of the image.
  • Dear Hung Bui,
    Thank you for your answer. I performed the test you advised yesterday. In the attached file _1 and _2 you can see Nordic MCU flash images where a successful update is performed respectively using the BLE nordic nrf connect app (starting with just the SD+bootloader onboard) and our update tool, which reproduces the Nordic update through the slip protocol via UART, including sending the nordic in bootloader by setting the related pin to active while rebooting. As you can see the two images are the same, except that in the UART version I see the cached copy of the new fw starting at 0x57000. Only Nordic fw is uploaded this time, no other hidden data.
    In file _3 you can see an interrupted update. The update started on a Nordic set up as in flash image _2. The  differences between _3 and _2, as you can see by comparing the two files, are the "0xff-set" 0x1000 bytes at address 0x05E000 (the starting address different from the one in my former email because of the randomicity of my ctrl+c update interruption) and a few bytes at address 0xFE000, which according to the linker script is where the mbr_params_range is. If I then try to repeat the update after the interruption (image _4) I see that the update process stops after sendin the first 0x1000 bytes. By comparing  images _3 and _4 the only difference is in the first 0x1000 bytes at 0x57000, which in _4 are set to 0xff. By looking at the oscilloscope during this update process I can confirm that only the first 0x1000 byte data is sent to the Nordic, but somehow not written, the CRC is not returned to the program updating the Nordic and thus the update process exits. As a comparison, in the successful update before the interruption I can see the whole firmware flowing on the serial link with the oscilloscope.
    Could the modified lines at 0xFE000 in _3 have something to do with the failing update? Or could somehow the flash enter a state where it is not writable after I interrupt the update, so that when I try the update again (_4 file) the first 0x1000 data batch is sent to the Nordic but not written? Or maybe this used to be a problem in old Nordic libraries which is now solved (I have to use 16.0.0 for legacy reasons)?
    Really running short of ideas here, any tip is very welcome!
    Stefano
    Nordic_Update_with_app_1.txtNordic_Update_from_serial_2.txtNordic_Update_from_serial_with_interruption_3.txtNordic_Update_from_serial_after_interruption_4.txt
