LTE-M behavior and Power saving Modes
I m seeing a wierd behavior when communicating over LTE with the nRF9160.
According to iBasis you can communicate with the eSIM with LTE-M in Germany and PSM is supported.
i connect to an LTE-M Network. Disabling or Enabling PSM or DRX dosen't change anything.
The picture below shows the Power Consumption. I m not sure what happens after 20 Seconds after connecting to the Network. Can some one explain?
It seems that PSM dosn't work here. How can i check if PSM is availabel and used?
The other thing is when changing to NBioT. It works so the network coverage map from iBasis isn't Up To Date. iBasis-simplified-coverage-map-for-web.pdf (nordicsemi.com)
Activating PSM does make a difference as shown below.
PSM deactivated
PSM aktivated
Is this how PSM should work?
Can someone explain what happens?
