nrf5340_audio app build fails when selecting external flash
I am using ncs v2.2.0 on Windows.
Using the python buildprog.py script I am able to build and run the nrf5340_audio application with the bootloader enabled and using the internal flash memory.
Here is the build command that builds and runs correctly:
C:\ncs\v2.2.0\nrf\applications\nrf5340_audio>python .\tools\buildprog\buildprog.py -c both --pristine -b release -d gateway -m internal
If I then build using the external flash memory option using the following command, the build fails:
C:\ncs\v2.2.0\nrf\applications\nrf5340_audio>python .\tools\buildprog\buildprog.py -c both --pristine -b release -d gateway -m external
Here is the output from the build process:
----- START OF BUILD OUTPUT -----
Invoking build step
Net core uses precompiled hex
Run: west build C:\ncs\v2.2.0\nrf\applications\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -p -d C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\build\dev_gateway\build_release -DCONFIG_AUDIO_DEV=2 -DCONFIG_AUDIO_DFU=2 -DCONF_FILE=prj_release.conf
-- Application: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio
-- Using NCS Toolchain 2.2.0 for building. (C:/ncs/toolchains/v2.2.0/cmake)
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay
-- Generated zephyr.dts: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/dts.cmake
warning: Experimental symbol NRF5340_AUDIO is enabled.
warning: Experimental symbol AUDIO_DFU_ENABLE is enabled.
warning: Experimental symbol BT_ISO_CENTRAL is enabled.
warning: Experimental symbol BT_AUDIO is enabled.
warning: Experimental symbol BT_AUDIO_UNICAST_CLIENT is enabled.
warning: Experimental symbol BT_VCS_CLIENT is enabled.
warning: Experimental symbol BT_MCS is enabled.
warning: Experimental symbol BT_MPL is enabled.
warning: Experimental symbol MCTL is enabled.
Parsing C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/Kconfig
Loaded configuration 'C:/ncs/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/prj_release.conf'
Merged configuration 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/mcuboot/child_image_preload.cmake
CMake Warning (dev) at C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/mcuboot/child_image_preload.cmake:9 (set):
Syntax error in cmake code at
when parsing string
C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay;c:\ncs\v2.2.0\zephyr\/../nrf/modules/mcuboot/flash_sim.overlay
Invalid escape sequence \v
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/mcuboot/child_image_preload.cmake:10 (set):
when parsing string
C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-mcuboot_external_flash.conf;c:\ncs\v2.2.0\zephyr\/../nrf/subsys/partition_manager/partition_manager_enabled.conf
-- Application: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
CMake Error at C:/ncs/v2.2.0/zephyr/cmake/modules/dts.cmake:2147483647 (zephyr_variable_set_too_late):
when parsing string
C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay;c:\ncs\v2.2.0\zephyr\/../nrf/modules/mcuboot/flash_sim.overlay C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
Invalid character escape '\v'.
C:/ncs/v2.2.0/zephyr/cmake/modules/dts.cmake:93 (if)
C:/ncs/v2.2.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
C:/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:44 (find_package)
CMake Error: Error in cmake code at
Unknown:0:
A command failed during the invocation of callback "zephyr_variable_set_too_late".-- Configuring incomplete, errors occurred!
CMake Error at C:/ncs/v2.2.0/nrf/cmake/multi_image.cmake:429 (message):
CMake generation for mcuboot failed, aborting. Command: 1
C:/ncs/v2.2.0/nrf/cmake/multi_image.cmake:163 (add_child_image_from_source)
C:/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:234 (add_child_image)
See also "C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/CMakeFiles/CMakeOutput.log".
See also "C:/ncs/v2.2.0/nrf/applications/nrf5340_audio/build/dev_gateway/build_release/CMakeFiles/CMakeError.log".
←[91mFATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-DWEST_PYTHON=D:\Python\python.exe' '-BC:\ncs\v2.2.0\nrf\applications\nrf5340_audio\build\dev_gateway\build_release' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp -DCONFIG_AUDIO_DEV=2 -DCONFIG_AUDIO_DFU=2 -DCONF_FILE=prj_release.conf '-SC:\ncs\v2.2.0\nrf\applications\nrf5340_audio'
←[0mTraceback (most recent call last):
File "C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 394, in <module>
__main()
File "C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 377, in __main
__build_module(build_cfg, options)
File "C:\ncs\v2.2.0\nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 146, in __build_module
raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 1
----- END OF BUILD OUTPUT -----
Is the use of external flash a supported option when using ncs v2.2.0?
If so, can give me some guidance on how to resolve this build issue?
-- Kristopher
  • Hello Kristopher,
    I do not think the current audio DK has external flash. You could get an external flash device and wire it to the DK though.
    I understand this can be confusing considering the references to external flash in some of the documentation, for an explaination of that, see here.
    Elfving
  • Hi Elfving,
    I have attached an external SPI flash memory to the nrf5340 audio dev kit and now I am trying to get the application compiled so it will interact with the external memory.  The issue here is that audio app does not build if I compile with the switch that selects the external memory.
    I have been doing some more debugging and I discovered that the script "\ncs\v2.2.0\zephyr\zephyr-env.cmd" sets the variable ZEPHYR_BASE to "c:\ncs\v2.2.0\zephyr\.  I noticed in the build output that some of the paths looked suspicious so I changed the value of ZEPHYR_BASE to be "c:/ncs/v2.2.0/zephyr/" and now I can build the audio application with the external memory option.
    Is there another env var configuration script that should be used to set the env vars when using ncs on a Window machine?
    -- Kristopher
  • Hello again Kristopher, and sorry about the wait.
    Great that you have in a way found the problem. You could set the enviroment variables ZEPHYR_BASE and toolchain using the script that you can find within the {NCS version}/zephyr/ folder. You could also alternatively run the cmd from the toolchain manager using the drop down menu next to the NCS version you're using.
    I believe this issue stems from where your application is placed in relation to the SDK. Do you have a freestanding application?
    Elfving
  • Hi Elfving,
    This build issue happens when I try to build the nrf5340_audio application in the ncs directory.  On my system ncs is installed on the C: drive and the app I am trying to build is in the following directory:
    I am trying make sure that I have the ncs SDK and build systems installed and configured correctly on my PC.
    Can you verify that you are able to build the nrf5340_audio application with the external DFU memory option builds on one of your windows PC systems?
    -- Kristopher
  • Hi Elfving,
    I also encountered the same problem in NCS2.2.0.
    lenovo@□□□˼□ MINGW64 /d/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/tools/buildprog
    $ python buildprog.py -c both -b debug -d both -m external -M -p
    No programmer/debugger connected to PC
    No snrs connected
    | snr  | snr conn |  device | only reboot  | core app programmed | core net programmed |
    | 1000 |  False   | headset | Not selected |     Selected TBD    |     Selected TBD    |
    | 1000 |  False   | gateway | Not selected |     Selected TBD    |     Selected TBD    |
    Invoking build step
    Run: west build D:\NCS_2.x\v2.2.0\nrf\applications\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -d D:\NCS_2.x\v2.2.0\nrf\applications\nrf5340_audio\build\dev_headset\build_debug -DCONFIG_AUDIO_DEV=1 -DCONFIG_AUDIO_DFU=2 -DCONFIG_B0N_MINIMAL=y
    -- Application: D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio
    -- Using NCS Toolchain 2.2.0 for building. (D:/NCS_2.x/toolchains/v2.2.0/cmake)
    -- Found Python3: D:/NCS_2.x/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/NCS_2.x/v2.2.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (D:/NCS_2.x/v2.2.0/zephyr)
    -- Found host-tools: zephyr 0.15.1 (D:/NCS_2.x/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (D:/NCS_2.x/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: D:/NCS_2.x/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/NCS_2.x/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay
    -- Generated zephyr.dts: D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/dts.cmake
    warning: Experimental symbol BT_ISO_PERIPHERAL is enabled.
    warning: Experimental symbol BT_AUDIO_UNICAST_SERVER is enabled.
    warning: Experimental symbol BT_VCS is enabled.
    warning: Experimental symbol BT_CSIS is enabled.
    warning: Experimental symbol BT_MCC is enabled.
    warning: Experimental symbol BT_CAP_ACCEPTOR is enabled.
    Parsing D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/Kconfig
    Loaded configuration 'D:/NCS_2.x/v2.2.0/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/prj.conf'
    Merged configuration 'D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/.config'
    Kconfig header saved to 'D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/zephyr/include/generated/autoconf.h'
    -- Found assembler: D:/NCS_2.x/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: D:/NCS_2.x/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    loading initial cache file D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/mcuboot/child_image_preload.cmake
    CMake Warning (dev) at D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/mcuboot/child_image_preload.cmake:9 (set):
      when parsing string
        D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay;D:\NCS_2.x\v2.2.0\zephyr/../nrf/modules/mcuboot/flash_sim.overlay
      Invalid escape sequence \N
    CMake Warning (dev) at D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/mcuboot/child_image_preload.cmake:10 (set):
      when parsing string
        D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-mcuboot_external_flash.conf;D:\NCS_2.x\v2.2.0\zephyr/../nrf/subsys/partition_manager/partition_manager_enabled.conf
    -- Application: D:/NCS_2.x/v2.2.0/bootloader/mcuboot/boot/zephyr
    CMake Error at D:/NCS_2.x/v2.2.0/zephyr/cmake/modules/dts.cmake:2147483647 (zephyr_variable_set_too_late):
      when parsing string
        D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/dfu/conf/overlay-dfu_external_flash.overlay;D:\NCS_2.x\v2.2.0\zephyr/../nrf/modules/mcuboot/flash_sim.overlay D:/NCS_2.x/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
      Invalid character escape '\N'.
      D:/NCS_2.x/v2.2.0/zephyr/cmake/modules/dts.cmake:93 (if)
      D:/NCS_2.x/v2.2.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
      D:/NCS_2.x/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      D:/NCS_2.x/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    Unknown:0:
    CMake Error at D:/NCS_2.x/v2.2.0/nrf/cmake/multi_image.cmake:429 (message):
      D:/NCS_2.x/v2.2.0/nrf/cmake/multi_image.cmake:163 (add_child_image_from_source)
      D:/NCS_2.x/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:234 (add_child_image)
    See also "D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/CMakeFiles/CMakeOutput.log".
    See also "D:/NCS_2.x/v2.2.0/nrf/applications/nrf5340_audio/build/dev_headset/build_debug/CMakeFiles/CMakeError.log".
    FATAL ERROR: command exited with status 1: 'D:\NCS_2.x\toolchains\v2.2.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=D:\NCS_2.x\toolchains\v2.2.0\opt\bin\python.exe' '-BD:\NCS_2.x\v2.2.0\nrf\applications\nrf5340_audio\build\dev_headset\build_debug' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp -DCONFIG_AUDIO_DEV=1 -DCONFIG_AUDIO_DFU=2 -DCONFIG_B0N_MINIMAL=y '-SD:\NCS_2.x\v2.2.0\nrf\applications\nrf5340_audio'
      File "buildprog.py", line 394, in <module>
        __main()
      File "buildprog.py", line 377, in __main
      File "buildprog.py", line 146, in __build_module
    Zero
