FOTA Upgrade Server implementation
Our project consists of 1 to many sensor devices using hte UBlox NORA B126 (nRF5340) processor.  Via Zigbee network, these end points connect to a Zigbee coordinator, which is a Digi IX15 Gateway devices that has an XBee3 module for Zigbee communications.  From the Gateway, we will use MQTT to communicate to the cloud.
 I am trying to implement the Zigbee FOTA API.  From the online Nordic resources, I am in the process of adapting the Light Switch example, that illustrates use of the Zigbee FOTA.
 Is there additional information available regarding the Zigbee FOTA API and additional examples that illustrate (1) the communications that take place so I can understand what is taking place in the event of issues; (2) how to implement the OTA upgrade server, which would store the OTA image, but also manage the inbound/outbound ZCL communications?
 As described, I will need to implement Zigbee FOTA support on a third party device.  Yet, I lack understanding or samples/examples that would even explain how to implement an upgrade server if I was using another Nordic nRF52840 or nRF6340 device.
 I appreicate any assistance in moving forward with my implementation
  • Hello Thomas,
    As a starting page for Zigbee FOTA, please see:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/zigbee/zigbee_fota.html#lib-zigbee-fota
    Setting up the server however is not straight forward. We actually don't have any ways of setting up a DFU server on a DK in NCS. To perform the update, you need to either look into the implementation in nrfutil or the DFU server from the nRF5 SDK (Zigbee and Thread version). So the new image can be generated using NCS, but to transfer it, you need to use one of the old tools. I guess you can look at the implementation of either nrfutil on Github or the nRF5_SDK_for_Thread_and_zigbee\examples\zigbee\ota\experimental_server to see how you can transfer the image to the target.
    Edvin
  • Hi Edvin,
    Thank you for your response.  While implementing the client side, I've become fairly familiar with the referenced web resource, but I will review again since I easily could have overlooked something.
    With that said, is there any documentation that shows how to implement on a non-DK device?  We will actually be using the Digi IX15 Gateway, which has an XBee 3 module.  For your testing of FOTA for the light_switch exmaple, what was used as the upgrade server for testing the FOTA implementation within the light switch example code?  Any information regarding implementation would be helpful.
    Admittedly, I am fairly new to Zigbee communications.  Should I be able to find answers in Zigbee Cluster Library documentation?  Even with that said, if Nordic provided a FOTA example with the light switch example, I would expect Nordic should be able to provide some implementation information of the upgrade server.
    Tom
  • Hello Tom,
    I am afraid all the documentation that I can find is the OTA Server examples' description:
    https://infocenter.nordicsemi.com/topic/sdk_tz_v4.2.0/zigbee_example_ota_server.html?cp=9_3_3_8_5_2_1
    But please note that all the information here about the bootloader and SoftDevice is not relevant, as this has changed in NCS. The relevant part is only the Zigbee OTA Upgrade Cluster (which you can find more information on in the Zigbee Cluster Specification).
    Regarding the 3rd party device, I am sorry, but I can't be of much help. You need to find a Zigbee stack that can run on that device, and you need to implement the OTA Upgrade Server on that device.
    Yes, I also wish there was some upgrade server in NCS, but unfortunately I have been pointed to nrfutil and the nRF5 SDK when asking our Zigbee team for this earlier. I guess that most gateways that are hosting the OTA Upgrade Server are not running on Nordic devices (like in your case).
    Edvin
