I would like to use the Thingy 91 to count rotations making use of the accelerometer. So I wrote this function that seems to work to get the acceleration values from the ADXL362:
int ext_sensors_accel_lp_get(double *accel)
int err;
struct sensor_value data[ACCELEROMETER_CHANNELS];
err = sensor_sample_fetch_chan(accel_sensor_lp.dev, SENSOR_CHAN_ALL);
if (err) {
LOG_ERR("sensor_sample_fetch_chan, error: %d", err);
return -1;
err = sensor_channel_get(accel_sensor_lp.dev, SENSOR_CHAN_ACCEL_XYZ, data);
if (err) {
LOG_ERR("sensor_channel_get, error: %d", err);
return -1;
accel[0] = sensor_value_to_double(&data[0]);
accel[1] = sensor_value_to_double(&data[1]);
accel[2] = sensor_value_to_double(&data[2]);
//k_spinlock_key_t key = k_spin_lock(&(accel_sensor_lp.lock));
//*accel = sensor_value_to_double(&data);
//k_spin_unlock(&(accel_sensor_lp.lock), key);
return 0;
However, the values this function returns vary a lot, more than I expect from reading the datasheet:
0.068646 -0.558979 -8.620045
0.039226 -0.019613 -8.953471
-0.284392 0.323619 -8.786758
0.304006 0.225552 -9.855683
0.235359 -0.941438 -6.982334
0.774725 -1.029698 -10.012589
-0.470719 -0.274586 -8.933858
0.608012 -0.980665 -10.208722
(The one higher valued axis does change like you would expect when rotating the Thingy 91)
I also tried changing the measurement rate to 12.5Hz:# ADXL362 - Low-Power accelerometer used for activity and inactivity detection.
CONFIG_ADXL362=y
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_ADXL362_ABS_REF_MODE=1
CONFIG_ADXL362_ACCEL_RANGE_2G=y
#CONFIG_ADXL362_ACCEL_ODR_400=y
CONFIG_ADXL362_ACCEL_ODR_12_5=y
But this did not improve the results. I'm I missing something or just reading the values in the wrong manner perhaps?
