Sometimes RF 2.4G Tx without a NRF_RADIO_EVENT_END event
Hi there,
I'm working on nrf52840 & NCS 2.0.0.  Sometime I can not get a NRF_RADIO_EVENT_END event so the while loop under the radio_tx function will be stuck.
Is there any suggestions?
void radio_tx(uint8_t channel, uint8_t pattern, uint8_t *packet)
    radio_disable();
    radio_config(pattern);
    nrf_radio_mode_set(NRF_RADIO, NRF_RADIO_MODE_BLE_1MBIT);
    nrf_radio_shorts_enable(NRF_RADIO,
                NRF_RADIO_SHORT_READY_START_MASK |
                NRF_RADIO_SHORT_END_DISABLE_MASK);
    nrf_radio_packetptr_set(NRF_RADIO, packet);
    nrf_radio_txpower_set(NRF_RADIO, RADIO_TXPOWER_TXPOWER_Pos4dBm);
    nrf_radio_frequency_set(NRF_RADIO, CHAN_TO_FREQ(channel));
    nrf_radio_event_clear(NRF_RADIO, NRF_RADIO_EVENT_END);
    nrf_radio_event_clear(NRF_RADIO, NRF_RADIO_EVENT_READY);
    //nrf_radio_int_enable(NRF_RADIO, NRF_RADIO_INT_END_MASK);
    // printk("NRF_RADIO_INT_END_MASK\n");
    nrf_radio_task_trigger(NRF_RADIO, NRF_RADIO_TASK_TXEN);
    while(!nrf_radio_event_check(NRF_RADIO, NRF_RADIO_EVENT_END)) {
        // wait for transmit tx packet
static void radio_config(uint8_t pattern)
    uint8_t playload_length;
    nrf_radio_packet_conf_t packet_conf;
    nrf_radio_modecnf0_set(NRF_RADIO, true, RADIO_MODECNF0_DTX_Center);
    nrf_radio_txaddress_set(NRF_RADIO, 0);
    nrf_radio_rxaddresses_set(NRF_RADIO, 1);
    switch (pattern)
    case TRANSMIT_PATTERN_SHORT :
        nrf_radio_crc_configure(NRF_RADIO, RADIO_CRCCNF_LEN_Two, NRF_RADIO_CRC_ADDR_INCLUDE, 0x880083);
        nrf_radio_prefix0_set(NRF_RADIO, 0xA0);
        nrf_radio_base0_set(NRF_RADIO, 0x38393A3B);
        playload_length = 28;
    case TRANSMIT_PATTERN_LONG :
        nrf_radio_crc_configure(NRF_RADIO, RADIO_CRCCNF_LEN_Two, NRF_RADIO_CRC_ADDR_INCLUDE, 0x47CF56);
        nrf_radio_base0_set(NRF_RADIO, 0x5C5D5E5F);
        playload_length = 249;
    case TRANSMIT_PATTERN_OTA :
        nrf_radio_prefix0_set(NRF_RADIO, 0xBB);
        nrf_radio_base0_set(NRF_RADIO, 0xC5D5E5F5);
    nrf_radio_crcinit_set(NRF_RADIO, 0xffff);
    memset(&packet_conf, 0, sizeof(packet_conf));
/*** PCNF0 ***/
    packet_conf.lflen = 0;
    packet_conf.s0len = 0;
    packet_conf.s1len = 0;
    packet_conf.s1incl = 0;
    packet_conf.cilen = 0;
    packet_conf.plen = NRF_RADIO_PREAMBLE_LENGTH_8BIT;
    packet_conf.crcinc = 0;
    packet_conf.termlen =0;
/*** PCNF1 ***/
    packet_conf.maxlen = playload_length;
    packet_conf.statlen = playload_length;
    packet_conf.balen = 4;
    packet_conf.big_endian = false;
    packet_conf.whiteen = true;
    nrf_radio_packet_configure(NRF_RADIO, &packet_conf);
radio
