I've spent a couple days researching how to write a small amount of data to the storage_partition that is fairly standard in Nordic devicetrees. I haven't been successful and am looking for guidance.
My setup: nrf Connect SDK v2.2.0, Zephyr, nrf52840, using MCUBoot for DFU updates. I believe the fact that my application uses MCUBoot is the crucial bit of information.
Here's my board's Devicetree for the flash partitions.
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x000000000 0x0000C000>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0x0000C000 0x00067000>;
slot1_partition: partition@73000 {
label = "image-1";
reg = <0x00073000 0x00067000>;
scratch_partition: partition@da000 {
label = "image-scratch";
reg = <0x000da000 0x0001e000>;
* The flash starting at 0x000f8000 and ending at
* 0x000fffff is reserved for use by the application.
* Storage partition will be used by FCB/LittleFS/NVS
* if enabled.
storage_partition: partition@f8000 {
label = "storage";
reg = <0x000f8000 0x00008000>;
I am able to successfully build and run the following sample program for the nrf52840 DK. This sample does not assume MCUBoot is present.
If I import this sample into my application and board, which includes MCUBoot, it fails. Note that I've changed "slot1_partition" to "storage_partition". It works completely fine if I leave TEST_PARTITION as "slot1_partition".
#ifdef CONFIG_TRUSTED_EXECUTION_NONSECURE
#define TEST_PARTITION storage_partition
#else
#define TEST_PARTITION_OFFSET FIXED_PARTITION_OFFSET(TEST_PARTITION)
#define TEST_PARTITION_DEVICE FIXED_PARTITION_DEVICE(TEST_PARTITION)
#define FLASH_PAGE_SIZE 4096
#define TEST_DATA_WORD_0 0x1122
#define TEST_DATA_WORD_1 0xaabb
#define TEST_DATA_WORD_2 0xabcd
#define TEST_DATA_WORD_3 0x1234
#define FLASH_TEST_OFFSET2 0x41234
#define FLASH_TEST_PAGE_IDX 37
void main(void)
const struct device *flash_dev = TEST_PARTITION_DEVICE;
uint32_t buf_array_1[4] = { TEST_DATA_WORD_0, TEST_DATA_WORD_1,
TEST_DATA_WORD_2, TEST_DATA_WORD_3 };
uint32_t buf_array_2[4] = { TEST_DATA_WORD_3, TEST_DATA_WORD_1,
TEST_DATA_WORD_2, TEST_DATA_WORD_0 };
uint32_t buf_array_3[8] = { TEST_DATA_WORD_0, TEST_DATA_WORD_1,
TEST_DATA_WORD_2, TEST_DATA_WORD_3,
uint32_t buf_word = 0U;
uint32_t i, offset;
printf("\nNordic nRF5 Flash Testing\n");
printf("=========================\n");
if (!device_is_ready(flash_dev)) {
printf("Flash device not ready\n");
return;
The primary symptom here is that TEST_PARTITION_DEVICE gets processed as NULL, so the device is null and the device_is_ready() test fails.
So to summarize, my MCUBoot-enabled project cannot access storage_partition. It can access slot1_partition.
I've looked into possibly using pm_static.yml, but when I define the storage partition there, my application images don't get placed in the flash.
It would be wonderful if there were a simple way I could add the definition of the storage_partition only, or even better, directly use the devicetree's specification of the storage_partition.
Thanks in advance for looking into this.
Best,
Steve
