Unable to build Hello World sample with MCUBoot configuration on macOS with M1
I've never been able to build my application that incorporates MCUBoot under macOS, and I believe others have had issues as well. I had to buy a PC to do most of my development, but my hope springs eternal that I can continue development on my M1 MacBook Air.
Setup: SDK v2.2.0, Zephyr, macOS Monterey.
I can easily reproduce the issue with the Hello World sample app. Here is how.
- Get a Apple Silicon MacBook (M1 or newer)
- Download the Hello World sample.
- Choose the v2.2.0 SDK.
- Set a build configuration for the nrf52840 DK.
- Do a pristine build, and it will compile fine.
- Add this line to the prj.conf:
  CONFIG_BOOTLOADER_MCUBOOT=y
- Do a pristine build, and it will fail with the errors below.
- My support information is also copied in below.
Note that I did a fresh reinstall of the SDK, Visual Studio Code, and nRF Connect before I tried the above. It fails the same way in my app, too.
It seems related to an environment variable issue with ZEPHYR_NRF_MODULE_DIR.  But that environment variable is correctly set to /opt/nordic/ncs/v2.2.0/nrf.
Hopefully someone at Nordic Semi can use this recipe and try to reproduce the issue and recommend a solution.
Best,
Steve
*  Executing task: nRF Connect: Build [pristine]: hello_world/build (active)
Building hello_world
west build --build-dir /Users/Steve/Projects/hello_world/build /Users/Steve/Projects/hello_world --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/Users/Steve/Projects/hello_world/prj.conf"
-- Application: /Users/Steve/Projects/hello_world
-- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: /Users/Steve/Library/Caches/zephyr
-- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr)
-- Board: nrf52840dk_nrf52840
-- Found host-tools: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/v2.2.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.2.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Generated zephyr.dts: /Users/Steve/Projects/hello_world/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/Steve/Projects/hello_world/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/Steve/Projects/hello_world/build/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.2.0/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.2.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration '/Users/Steve/Projects/hello_world/prj.conf'
Configuration saved to '/Users/Steve/Projects/hello_world/build/zephyr/.config'
Kconfig header saved to '/Users/Steve/Projects/hello_world/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: /opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Found Python3: /opt/nordic/ncs/toolchains/v2.2.0/bin/python3.9 (found version "3.9.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /Users/Steve/Projects/hello_world/build/mcuboot/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
-- Found Python3: /usr/local/bin/python3.9 (found suitable exact version "3.9.2") found components: Interpreter
-- Found devicetree overlay: /opt/nordic/ncs/v2.2.0/nrf/modules/mcuboot/usb.overlay
-- Found devicetree overlay: /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /Users/Steve/Projects/hello_world/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/Steve/Projects/hello_world/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/Steve/Projects/hello_world/build/mcuboot/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig
/opt/nordic/ncs/v2.2.0/zephyr/scripts/kconfig/kconfig.py: /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig:11: '/modules/mcuboot/boot/zephyr/Kconfig' not found (in 'source "$(ZEPHYR_NRF_MODULE_DIR)/modules/mcuboot/boot/zephyr/Kconfig"'). Check that environment variables are set correctly (e.g. $srctree, which is set to '/opt/nordic/ncs/v2.2.0/zephyr'). Also note that unset environment variables expand to the empty string.
CMake Error at /opt/nordic/ncs/v2.2.0/zephyr/cmake/modules/kconfig.cmake:328 (message):
  command failed with return code: 1
  /opt/nordic/ncs/v2.2.0/nrf/cmake/modules/kconfig.cmake:29 (include)
  /opt/nordic/ncs/v2.2.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
  /opt/nordic/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:44 (find_package)
CMake Error at /opt/nordic/ncs/v2.2.0/nrf/cmake/multi_image.cmake:429 (message):
  CMake generation for mcuboot failed, aborting.  Command: 1
  /opt/nordic/ncs/v2.2.0/nrf/cmake/multi_image.cmake:163 (add_child_image_from_source)
  /opt/nordic/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:234 (add_child_image)
See also "/Users/Steve/Projects/hello_world/build/CMakeFiles/CMakeOutput.log".
See also "/Users/Steve/Projects/hello_world/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.2.0/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/v2.2.0/bin/python3 -B/Users/Steve/Projects/hello_world/build -GNinja -DBOARD=nrf52840dk_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=/Users/Steve/Projects/hello_world/prj.conf -S/Users/Steve/Projects/hello_world
 *  The terminal process terminated with exit code: 1.
Here is my support information:
  "platform": {
    "os": "darwin",
    "osVersion": "Darwin Kernel Version 21.6.0: Mon Aug 22 20:20:05 PDT 2022; root:xnu-8020.140.49~2/RELEASE_ARM64_T8101",
    "osKernel": "21.6.0",
    "vscode": "1.75.1",
    "electron": "19.1.9",
    "node": "v16.14.2"
  "system": {
    "date": "2023-02-23T05:56:15.326Z",
    "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
    "vscodeUptime": "00:27:07",
    "osUptime": "249:59:45",
    "cpu": {
      "model": "Apple M1",
      "speed": "24 MHz",
      "count": 4
    "memory": {
      "total": "16.00 GB",
      "free": "0.12 GB"
  "workspace": {
    "name": "hello_world",
    "workspaceFile": null,
    "folders": [
      "/Users/Steve/Projects/hello_world"
  "extensions": {
    "internal": {
        "version": "2023.1.44",
        "path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.1.44-darwin-x64",
        "isActive": true
        "version": "2022.11.29",
        "path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.11.29",
        "isActive": true
        "version": "2022.11.153",
        "path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2022.11.153",
        "isActive": true
        "version": "2022.11.50",
        "path": "/Users/Steve/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2022.11.50",
        "isActive": true
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.14.3",
      "ms-vscode.js-debug": "1.75.1",
      "ms-vscode.js-debug-companion": "1.0.18",
      "ms-vscode.vscode-js-profile-table": "1.0.3",
      "twxs.cmake": "0.0.17"
  "tools": {
    "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.15.1",
    "/Applications/SEGGER/JLink/JLinkExe": "7.80c",
    "/usr/local/bin/nrfjprog": "10.19.0",
    "nrfutil": "Not found",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/cmake": "3.20.5",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/west": "0.14.0",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/python3": "3.9.6",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/ninja": "1.10.2",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/gperf": "3.1",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/dtc": "1.6.1",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/gn": "2073",
    "/opt/nordic/ncs/toolchains/v2.2.0/bin/git": "2.37.3",
    "gdbPath": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
  "sdks": [
      "version": "2.2.0",
      "path": "/opt/nordic/ncs/v2.2.0"
  "toolchains": [
      "version": "2.2.0",
      "path": "/opt/nordic/ncs/toolchains/v2.2.0"
  "connectedDevices": [],
  "deviceProviders": [
    "nrfjprog"
  "config": {
      "topdir": "/opt/nordic/ncs/v2.2.0",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.2.0}"
      "ozonePath": "",
      "applications": [
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig",
        "executeInDefaultShell": false
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true,
      "taskBindings": {},
      "debugging": {
        "backend": "nRF Debug",
        "flash": true,
        "bindings": {}
      "activeAppFollowActiveEditor": true
      "terminalMode": "character",
      "scrollBack": 1000
  "environment": {
    "westExe": "west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/v2.2.0/Cellar/git/2.37.3/libexec/git-core",
      "HOME": "/Users/Steve",
      "PATH": "/opt/nordic/ncs/toolchains/v2.2.0/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/v2.2.0/arm-zephyr-eabi/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
      "ZEPHYR_BASE": "/opt/nordic/ncs/v2.2.0/zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk",
      "USER": "Steve"
    "inherited": {
      "PATH": "/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
      "USER": "Steve"
    "toolchainPath": "/opt/nordic/ncs/toolchains/v2.2.0",
    "toolchainBinPath": "/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
    "toolchainVersion": "2.2.0"
  "terminal": {
    "shell": null,
    "defaultProfile": null
    I tried to reproduce on my Macbook Air M2 and Windows computer. Built the "Hello world" sample and then add CONFIG_BOOTLOADER_MCUBOOT=y to prj.conf.
    west build --build-dir /Users/oysa/Projects/hello_world/build /Users/oysa/Projects/hello_world
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: /Users/oysa/Projects/hello_world
    -- Cache files will be written to: /Users/oysa/Library/Caches/zephyr
    CMake Warning at /opt/nordic/ncs/v2.2.0/zephyr/cmake/modules/boards.cmake:88 (message):
      BOARD_ROOT element without a 'boards' subdirectory:
      /Users/oysa/Projects/hello_world/Support/298989/Q3Iot_NCS220_230105/boards
      Hints:
        - if your board directory is '/foo/bar/boards/<ARCH>/my_board' then add '/foo/bar' to BOARD_ROOT, not the entire board directory
        - if in doubt, use absolute paths
      /opt/nordic/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    -- Generated zephyr.dts: /Users/oysa/Projects/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/oysa/Projects/hello_world/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/oysa/Projects/hello_world/build/zephyr/dts.cmake
    Merged configuration '/Users/oysa/Projects/hello_world/prj.conf'
    Configuration saved to '/Users/oysa/Projects/hello_world/build/zephyr/.config'
    Kconfig header saved to '/Users/oysa/Projects/hello_world/build/zephyr/include/generated/autoconf.h'
    loading initial cache file /Users/oysa/Projects/hello_world/build/mcuboot/child_image_preload.cmake
    -- Generated zephyr.dts: /Users/oysa/Projects/hello_world/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/oysa/Projects/hello_world/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/oysa/Projects/hello_world/build/mcuboot/zephyr/dts.cmake
    Merged configuration '/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/boards/nrf52840dk_nrf52840.conf'
    Merged configuration '/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '/Users/oysa/Projects/hello_world/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/Users/oysa/Projects/hello_world/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/oysa/Projects/hello_world/build/mcuboot/zephyr/include/generated/autoconf.h'
    CMake Warning at /opt/nordic/ncs/v2.2.0/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
            --- WARNING: To maintain the integrity of secure boot, ---
            --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
    MCUBoot bootloader key file: /opt/nordic/ncs/v2.2.0/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/oysa/Projects/hello_world/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at /opt/nordic/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- WARNING: Using default MCUBoot key, it should not ---
              --- be used for production.                           ---
    -- Configuring done
    -- Generating done
    [1/180] Creating directories for 'mcuboot_subimage'
    [2/180] No download step for 'mcuboot_subimage'
    [3/180] No update step for 'mcuboot_subimage'
    [4/180] No patch step for 'mcuboot_subimage'
    [5/180] No configure step for 'mcuboot_subimage'
    [5/180] Performing build step for 'mcuboot_subimage'
    [1/190] Preparing syscall dependency handling
    [2/190] Generating misc/generated/syscalls_subdirs.trigger
    [3/190] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [4/190] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [5/190] Generating include/generated/driver-validation.h
    [6/190] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [7/190] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [8/190] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [9/190] Generating include/generated/offsets.h
    [10/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [11/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [12/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [13/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [14/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [15/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [16/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [17/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [18/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [19/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [20/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [21/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [22/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [23/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [24/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [25/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [26/190] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [27/190] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [28/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [29/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [30/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [31/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [32/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [33/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [34/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [35/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [36/190] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [37/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [38/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [39/190] Generating linker_zephyr_pre0.cmd
    [40/190] Generating linker_zephyr_pre1.cmd
    [41/190] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [42/190] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [43/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [44/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [45/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [46/190] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [47/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [48/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [49/190] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [50/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [51/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [52/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [53/190] Linking C static library zephyr/arch/common/libisr_tables.a
    [54/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [55/190] Linking C static library zephyr/arch/common/libarch__common.a
    [56/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [57/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [58/190] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [59/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [60/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [61/190] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [62/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [63/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [64/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [65/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [66/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [67/190] Linking C static library zephyr/libzephyr.a
    [68/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [69/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [70/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [71/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [72/190] Generating zephyr/autogen-pubkey.c
    [73/190] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [74/190] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [75/190] Building C object CMakeFiles/app.dir/keys.c.obj
    [76/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [77/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [78/190] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [79/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [80/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [81/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [82/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [83/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [84/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [85/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [86/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [87/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [88/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [89/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [90/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [91/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [92/190] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [93/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [94/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    [95/190] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [96/190] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
    [97/190] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [98/190] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [99/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [100/190] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [101/190] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [102/190] Building C object CMakeFiles/app.dir/os.c.obj
    [103/190] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [104/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [105/190] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [106/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [107/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [108/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [109/190] Building C object modules/segger/CMakeFiles/modules__segger.dir/opt/nordic/ncs/v2.2.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [110/190] Linking C static library modules/segger/libmodules__segger.a
    [111/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [112/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [113/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [114/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [115/190] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [116/190] Building C object CMakeFiles/app.dir/main.c.obj
    [117/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [118/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [119/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [120/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [121/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [122/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [123/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [124/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [125/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [126/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [127/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [128/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [129/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [130/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [131/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [132/190] Linking C static library zephyr/kernel/libkernel.a
    [133/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [134/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [135/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [136/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [137/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [138/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [139/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [140/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [141/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [142/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [143/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [144/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [145/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [146/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [147/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [148/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [149/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [150/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [151/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [152/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [153/190] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [154/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [155/190] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [156/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [157/190] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [158/190] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [159/190] Linking C static library app/libapp.a
    [160/190] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [161/190] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [162/190] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [163/190] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [164/190] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [165/190] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [166/190] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [167/190] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [168/190] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
    [169/190] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [170/190] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [171/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [172/190] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [173/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [174/190] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [175/190] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [176/190] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [177/190] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [178/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [179/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [180/190] Linking C executable zephyr/zephyr_pre0.elf
    [181/190] Generating dev_handles.c
    [182/190] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [183/190] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [184/190] Linking C executable zephyr/zephyr_pre1.elf
    [185/190] Generating linker.cmd
    [186/190] Generating isr_tables.c, isrList.bin
    [187/190] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [188/190] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [189/190] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [190/190] Linking C executable zephyr/zephyr.elf
               FLASH:       33676 B        48 KB     68.51%
                 RAM:       17792 B       256 KB      6.79%
            IDT_LIST:          0 GB         2 KB      0.00%
    [159/180] Linking C executable zephyr/zephyr_pre0.elf
    [163/180] Linking C executable zephyr/zephyr_pre1.elf
    [169/180] Linking C executable zephyr/zephyr.elf
               FLASH:       22764 B     499200 B      4.56%
                 RAM:        7616 B       256 KB      2.91%
    [172/180] Generating ../../zephyr/app_update.bin
    sign the payload
    [173/180] Generating ../../zephyr/app_signed.hex
    sign the payload
    [175/180] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [176/180] Generating ../../zephyr/app_moved_test_update.hex
    [178/180] No install step for 'mcuboot_subimage'
    [179/180] Completed 'mcuboot_subimage'
    [180/180] Generating zephyr/merged.hex
     *  Terminal will be reused by tasks, press any key to close it
    The first run was without the pristine flag set. So redid the process:
    west build --build-dir /Users/oysa/Projects/hello_world/build /Users/oysa/Projects/hello_world --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/oysa/Projects/hello_world/Support/298989/Q3Iot_NCS220_230105/boards" -DCONF_FILE:STRING="/Users/oysa/Projects/hello_world/prj.conf"
      Hints:
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    [1/187] Preparing syscall dependency handling
    [2/187] Creating directories for 'mcuboot_subimage'
    [3/187] No download step for 'mcuboot_subimage'
    [4/187] Generating misc/generated/syscalls_subdirs.trigger
    [5/187] No update step for 'mcuboot_subimage'
    [6/187] No patch step for 'mcuboot_subimage'
    [7/187] No configure step for 'mcuboot_subimage'
    [7/187] Performing build step for 'mcuboot_subimage'
    [2/190] Generating include/generated/version.h
    [3/190] Generating misc/generated/syscalls_subdirs.trigger
    [10/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [11/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [12/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [13/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [14/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [15/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [16/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [17/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [18/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [19/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [20/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [21/190] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [22/190] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [23/190] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [24/190] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [25/190] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [26/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [27/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [28/190] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [29/190] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [30/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [31/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [32/190] Linking C static library zephyr/drivers/console/libdrivers__console.a
    [33/190] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [34/190] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [35/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [36/190] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [37/190] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [38/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [39/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [40/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [41/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [42/190] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [43/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [44/190] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
    [45/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [46/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [47/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [48/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [49/190] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [50/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [51/190] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [52/190] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [53/190] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [54/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [55/190] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
    [56/190] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [57/190] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [58/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [59/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [60/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
    [61/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
    [62/190] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
    [63/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [64/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [65/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [66/190] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a
    [67/190] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [68/190] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
    [69/190] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
    [70/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [71/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [72/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [73/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [74/190] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [75/190] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
    [76/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [77/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [78/190] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [79/190] Generating linker_zephyr_pre0.cmd
    [80/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [81/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [82/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [83/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [84/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [85/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [86/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [87/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [88/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [89/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [90/190] Generating linker_zephyr_pre1.cmd
    [91/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [92/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [93/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [94/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [95/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [96/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [97/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [98/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [99/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [100/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [101/190] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [102/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [103/190] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [104/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [105/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [106/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [107/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [108/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [109/190] Linking C static library zephyr/arch/common/libisr_tables.a
    [110/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [111/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [112/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [113/190] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [114/190] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [115/190] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [116/190] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [117/190] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [118/190] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [119/190] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [120/190] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [121/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
    [122/190] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [123/190] Linking C static library zephyr/arch/common/libarch__common.a
    [124/190] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
    [125/190] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [126/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [127/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [128/190] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
    [129/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [130/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [131/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [132/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [133/190] Building C object modules/segger/CMakeFiles/modules__segger.dir/opt/nordic/ncs/v2.2.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [134/190] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [135/190] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [136/190] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [137/190] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [138/190] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
    [139/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [140/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [141/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [142/190] Generating zephyr/autogen-pubkey.c
    [143/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [144/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [145/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [146/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [147/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [148/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [149/190] Building C object CMakeFiles/app.dir/keys.c.obj
    [150/190] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [151/190] Building C object CMakeFiles/app.dir/os.c.obj
    [152/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [153/190] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
    [154/190] Linking C static library modules/segger/libmodules__segger.a
    [155/190] Building C object CMakeFiles/app.dir/main.c.obj
    [156/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [157/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [158/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [159/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [160/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [161/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [162/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [163/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
    [164/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
    [165/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [166/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [167/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [168/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    [169/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [170/190] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [171/190] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [172/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [173/190] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [174/190] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [175/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [176/190] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [177/190] Linking C static library zephyr/libzephyr.a
    [178/190] Linking C static library zephyr/kernel/libkernel.a
    [179/190] Linking C static library app/libapp.a
    [8/187] Generating include/generated/version.h
    [166/187] Linking C executable zephyr/zephyr_pre0.elf
    [170/187] Linking C executable zephyr/zephyr_pre1.elf
    [176/187] Linking C executable zephyr/zephyr.elf
    [178/187] No install step for 'mcuboot_subimage'
    [179/187] Completed 'mcuboot_subimage'
    [180/187] Generating zephyr/mcuboot_primary.hex
    [181/187] Generating zephyr/mcuboot_primary_app.hex
    [182/187] Generating ../../zephyr/app_update.bin
    sign the payload
    [183/187] Generating ../../zephyr/app_signed.hex
    sign the payload
    [184/187] Generating ../../zephyr/dfu_application.zip
    [185/187] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [186/187] Generating ../../zephyr/app_moved_test_update.hex
    [187/187] Generating zephyr/merged.hex
    Comparing your support information to mine, I couldn't see any difference that should cause this. Adding mine for you to compare:
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 22.1.0: Sun Oct  9 20:15:52 PDT 2022; root:xnu-8792.41.9~2/RELEASE_ARM64_T8112",
        "osKernel": "22.1.0",
        "vscode": "1.74.2",
        "electron": "19.1.8",
        "node": "v16.14.2"
      "system": {
        "date": "2023-02-23T09:37:12.164Z",
        "vscodeUptime": "00:07:08",
        "osUptime": "310:02:27",
        "cpu": {
          "model": "Apple M2",
          "speed": "24 MHz",
          "count": 4
        "memory": {
          "total": "8.00 GB",
          "free": "0.16 GB"
      "workspace": {
        "folders": [
          "/Users/oysa/Projects/hello_world"
      "extensions": {
        "internal": {
            "path": "/Users/oysa/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.1.44-darwin-arm64",
            "isActive": true
            "path": "/Users/oysa/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.11.29",
            "isActive": true
            "path": "/Users/oysa/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2022.11.153",
            "isActive": true
            "path": "/Users/oysa/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2022.11.50",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.6.10",
          "ms-vscode.js-debug": "1.74.1",
          "mcu-debug.debug-tracker-vscode": "0.0.13",
          "mcu-debug.memory-view": "0.0.19",
          "mcu-debug.rtos-views": "0.0.4",
      "tools": {
        "/Applications/SEGGER/JLink/JLinkExe": "7.66a",
        "/usr/local/bin/nrfjprog": "10.16.0",
      "sdks": [
          "version": "2.2.0",
          "version": "2.1.0",
          "path": "/opt/nordic/ncs/v2.1.0"
          "version": "2.1.2",
          "path": "/opt/nordic/ncs/v2.1.2"
          "version": "2.1.1",
          "path": "/opt/nordic/ncs/v2.1.1"
          "version": "1.9.1",
          "path": "/opt/nordic/ncs/v1.9.1"
      "toolchains": [
          "version": "1.9.1",
          "path": "/opt/nordic/ncs/v1.9.1/toolchain"
          "version": "2.1.0",
          "path": "/opt/nordic/ncs/toolchains/v2.1.0"
          "version": "2.1.1",
          "path": "/opt/nordic/ncs/toolchains/v2.1.1"
          "version": "2.1.2",
          "path": "/opt/nordic/ncs/toolchains/v2.1.2"
          "version": "2.2.0",
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:2.2.0}",
          "toolchain": {
          "ozonePath": "",
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "Support/298989/Q3Iot_NCS220_230105/boards"
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "activeAppFollowActiveEditor": false
          "scrollBack": 1000
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOME": "/Users/oysa",
          "PATH": "/opt/nordic/ncs/toolchains/v2.2.0/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/bin:/opt/nordic/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/v2.2.0/arm-zephyr-eabi/bin:/opt/homebrew/sbin:/opt/homebrew/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Applications/Wireshark.app/Contents/MacOS",
          "USER": "oysa"
        "inherited": {
          "PATH": "/opt/homebrew/sbin:/opt/homebrew/bin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Applications/Wireshark.app/Contents/MacOS",
          "USER": "oysa"
      "terminal": {
        "shell": null,
    Øyvind
    Easy to reproduce.
    Using ncs v2.5.1 on M1 Mac ie. arm64.
    $ file /opt/nordic/ncs/toolchains/20d68df7e5/bin/python3
    /opt/nordic/ncs/toolchains/20d68df7e5/bin/python3: Mach-O 64-bit executable x86_64
    CONFIG_BOOTLOADER_MCUBOOT=y.
    the ncs-provided python3 uses system libraries (arm64) to create zephyr/autogen-pubkey.c.
    Thus, Python throws execption at:
    from cryptography.hazmat.bindings._openssl import ffi, lib
    because my system-installed cffi is arm64, not x86_64.
    How do I fixt his?
    Mikael
  • Thanks for reopening this issue, Mikael.  I had given up on getting my M2 Mac to work and had moved to Windows, but hopefully your observation will enable me to go back to the Mac. -- Steve
  • I hope so too.
    NOTE for Nordic: This is on a clean install of nRF Connect SDK v2.5.2.  No previous Library/Application Support/nrf.... files.
  • I hope so too.
