Hi
Is there an option in the code to change the rx sensitivity so received packet will be valid only if received by high rx level?
Thanks.
Hi
Thanks.
Hi Shay,
There isn't a scan filter for RSSI in the hardware or in the softdevice controller.
You would need to implement the RSSI filter in the application. Meaning you will receive a callback when the scanner find anything and then in the application you can discard advertising packet that has the RSSI lower than a certain level.
