nRF9160's getting bricked?
After updating device to modem firmware 1.3.4, I am having multiple modules being bricked and failing to connect.
When using the nRF Programmer, I get the following error:
Failed to get device memory map: async task failure for id: 13813516378 msg: [jlink] JLINKARM_DLL_ERROR (Origin: "Error when running fw program.")
When programming using VSCode and the nRF Connect, I get the following:
[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
Failed to read device memories.
[error] [  nRF91] - Failed when checking readback protect status.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /Users/chris/Documents/GitHub/cube-nRF9160-v2/copperCube/build/zephyr/merged.hex --sectorerase --verify -f NRF91 --snr 801028146
After updating the firmware to 1.3.4, I cannot connect to the board to update the modem firmware and I cannot connect to the board to download new application firmware.  The module does not run and does not output anything to console.  Another board not on this firmware works fine (1.3.2).
I have tried the following approach on multiple 1.3.4 boards and found them all to brick.  Some will program and run once or twice, and others will fail to program after the firmware update altogether.
Doing the same exact process with 1.3.2 boards, nothing happens and it works as intended.  Is anyone else having this issue?  I now have multiple "dead" nRF9160 modules.
nrfjprog --recover does not work and I have gone through multiple other threads searching for a solution to no avail.
I am on a 16in MacBook Pro M2.
