MORE GPIOS AS EVENTS
I am developing some application for that I want 12 pins as interrupt mode, but I can see only 8 pins can be configured.
Can anyone suggest me please.
Thanks, and regards.
  • Hi haakonsh,
    can you see at the right corner the err_code is LOCAL_ERR_CODE this is happening when nrf_drv_gpiote_in_init is called for the second time.
    Thanks for your reply.
  • You need to increase NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS to however many pins you want to use. As well as call nrfx_gpiote_in_event_enable() for each pin.
    You can provide unique event handlers to each pin, you don't need to use a single event handler like 'port_event_handler'.
    //Set 'NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 2' in nrfx_config.h!
    void port_event_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        switch(pin)
            case PIN_NUMBER_1:
                if(action == NRF_GPIOTE_POLARITY_HITOLO)
                    // Do stuff
                else if((action == NRF_GPIOTE_POLARITY_LOTOHI)
                    // Do stuff
            case PIN_NUMBER_2:
                    // Do stuff
                    // Do stuff
                // Do nothing, not interrested in any of the other pins port events
    uint32_t err_code;
    // Initialize GPIOTE module
    nrfx_gpiote_in_config_t in_config;
    in_config.sense = NRF_GPIOTE_POLARITY_HITOLO;
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    in_config.is_watcher = false;
    in_config.hi_accuracy = false;
    in_config.skip_gpio_setup = false;
    err_code = nrf_drv_gpiote_in_init(PIN_NUMBER_1, &in_config, port_event_handler);
    err_code = nrf_drv_gpiote_in_init(PIN_NUMBER_2, &in_config, port_event_handler);
    nrfx_gpiote_in_event_enable(PIN_NUMBER_1, false);
    nrfx_gpiote_in_event_enable(PIN_NUMBER_2, false);
  • Hi haakonsh,
    I will try this code and thank you so much for your continues support.
    Thanks and regards
    Ajmal
