MORE GPIOS AS EVENTS
I am developing some application for that I want 12 pins as interrupt mode, but I can see only 8 pins can be configured.
Can anyone suggest me please.
Thanks, and regards.
  • You need to use the PORT event instead of the IN events. Then you can use any number of GPIOs. See:
    EVENTS_PORT
    GPIO — General purpose input/output
  • Hi haakonsh,
    In my application multiple buttons are also pressed together so these situations should be considered, and as per your suggestion if i use port events then still i can configure 8 interrupts since it has only 8 config in gpiote (0-7). If you have any code for the same then please do share it with me.
    Thanks and regards.
  • Hey Ajmal,
    The PORT event does not use GPIOTE channels at all.
    Call nrfx_gpiote_in_init() with an nrfx_gpiote_in_config_t struct where the hi_accuracy member is set to 'false'. The GPIOTE driver will now use the PORT event for the provided pin and its trigger config.
    BR,
    haakonsh.
  • Hi haakonsh,
    I tried as per your suggestion and i found that many pins are automatically getting triggered like Pin 0,1,2,3,11,12 etc. and also I am not able to configure more than one pin for port interrupt because it is triggering    NRF_BREAKPOINT_COND;
    uint32_t err_code;
    // Initialize GPIOTE module
    nrf_gpio_cfg_input(PIN_NUMBER_1, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_input(PIN_NUMBER_2, NRF_GPIO_PIN_PULLUP);
    NRF_P0->PIN_CNF[PIN_NUMBER_1] |= (GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos);
    NRF_GPIOTE->INTENSET = (1 << PIN_NUMBER_1);
    NRF_P0->PIN_CNF[PIN_NUMBER_2] |= (GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos);
    NRF_GPIOTE->INTENSET = (1 << PIN_NUMBER_2);
    nrfx_gpiote_in_config_t in_config;
    in_config.pull = NRF_GPIOTE_POLARITY_HITOLO;
    err_code = nrf_drv_gpiote_in_init(PIN_NUMBER_1, &in_config, port_event_handler);
    err_code = nrf_drv_gpiote_in_init(PIN_NUMBER_2, &in_config, port_event_handler);
    NVIC_EnableIRQ(GPIOTE_IRQn);
    BR,
    Ajmal
  • Try this:
    void port_event_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        switch(pin)
            case PIN_NUMBER_1:
                // Do stuff
            case PIN_NUMBER_2:
                // Do stuff
                // Do nothing, not interrested in any of the other pins port events
    uint32_t err_code;
    in_config.sense = NRF_GPIOTE_POLARITY_HITOLO;
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    in_config.is_watcher = false;
    in_config.hi_accuracy = false;
    in_config.skip_gpio_setup = false;
    If you still get an error, note the file name and line number.
