BLE advertising extensions power consumption and corrupt packet retransmission
  • Hardware: nRF52480 custom boards (One Central and one Peripheral)
  • SoftDevice: s140_nrf52_6.1.0_softdevice
  • SDK: 15.2
I switched my project to use advertising extensions in order to fit a larger advertising name.
Question 1: Do advertising extensions use more power for the advertiser (Peripheral) and scanner (Central) than legacy advertising?
I would think that advertising extensions would result in less power use because legacy advertising transmits the full advertising packet on all 3 advertising channels and advertising extensions only transmits a header on the 3 advertising channels and the full packet on one of the 37 data channels. If advertising extensions do use more power, I could resort to putting the advertising name in the scan response packet and not use advertising extensions.
Question 2: Do BLE beacon devices using advertising extensions have any link layer retransmission capabilities in the event that a corrupt advertising packet is received, or is this only for BLE connections? I assume the latter, but just double checking.
Derek
  • Hi Derek,
    1. Yes, extended advertising comes in many forms (longer packets, potentially additional packets on secondary channels). More time on air means more power consumption. Also, note that even short advertising packets have a significant current consumption (compared to longer), as much of the consumed energy is related to pre-processing, ramp-up etc. You can experiment with the effect of this in the online power profiler.
    2. There is no concept of re transmissions in advertising, as it is one way, and there is no ack mechanism. If you need retransmissions (because you need to avoid data loss), you need a connection.
  • Hey Einar,
    Thanks for your response. The online power profiler you linked doesn't seem to support advertising extensions unless I am missing something?
    Are you saying that using advertising extensions uses more power than using the existing scan response? My goal is to advertise the full local name (BLE_ADVDATA_FULL_NAME) which doesn't currently fit in the standard advertising packet with my other data. From what I have discovered today, the SoftDevice will always send a scan response even if not used or explicitly set by the application. If not set, a 0 length scan response packet is still sent. Based on my newfound knowledge, it seems more power effecient to put the full advertising name in the scan response than to use advertising extensions. Can you confirm this?
    Source:  Disable scan response
    Derek
  • Hi Derek,
    No, that is correct. I meant to suggest it as a simple way to see the effect packet length has on current consumption (and that even a packet with zero payload will not consume that much less than a longer advertising packet, due to all the other overhead).
    Yes. Putting additional data (like the full name) in a scan response packet will both be more power efficient and more compatible with older Bluetooth devices.
    Einar
