I'm using LWIP stack for downloading about 200KB file and each chuck size is 84bytes, the connection stops completely in between ~ around 10 KB without any error and even ping doesn't reach, it would great if someone could help me here.
Thanks
Ajesh
Thanks
Ajesh
Hi Ajesh,
Can you give some more information on your setup and debugging like
SDK revision.
Application that you are using to transfer these data.
If you started your app in debugger mode and when the error occurs, have you paused the debugger to see the context of the app?
Hi Susheel,
Thanks for the quick reply.
We are downloading binary data from a PC application. Into our device flash.
After downloading up to 10KB the downloading stops.
From the PC application 84B of data is sent at a time and we send a 34B of response to get the next packet or frame.
When the response is sent, the status is successful, but the data is not been seen on the Ethernet link, sometime partial data is received (verified this using a Wireshark).
The Debug mode is enabled, since this doesn't throw an error, we were not able to clearly see the context, Will try to pause and post the results here.
SDK version used: 17.0.2
Ajesh, Gaurav have reached to me to prioritize this case.
Can you please give me a minimalistic project to reproduce this? reproducing this at my desk will get more attention for the development team to get a workaround quicker.
