libuarte+freertos receive wrong data
Hi there,
I used libuarte under FreeRTOS together with the SDK 17.1.0. When I test the application, I found that the data I received except some problem.
The baudrate is 921600, and I send the test data (abcdefg...), when i send about 10 pieces of data, the data I received was split into two parts.
i don't know what's going on.
uart.c is here.
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            UART_PRINTF("NRF_LIBUARTE_ASYNC_EVT_ERROR = %d.", p_evt->data.errorsrc);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            m_loopback_phase = true;
            memcpy(data_array, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            UART_PRINTF("data_array = %s", data_array);
            nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    APP_ERROR_CHECK(ret);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            UART_PRINTF("Unexpected LibUarte Event = %d.", p_evt->type);
int main()
    uint8_t err_code;
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_921600,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_HIGH,
            .pullup_rx  = 1
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    if(err_code != NRF_SUCCESS)
        UART_PRINTF("nrf_libuarte_async_init err_code = %d.", err_code);
    nrf_libuarte_async_enable(&libuarte);
BR,
Lurn
Parents Reply
  • Ok, now, when I sending data by uarte, something went wrong.
    you can see that, when I send 5A 0C 03 01 01 over uart for test, I can receive it correctly. then I modify the data in data[3] and data[4], the RTT print is OK, but the uart print is wrong. when i increase the data length, I found that the data from data[3] to data[31] are all 0.
    Any idea what the problem could be?
    BR,
    Lurn
