nRF5340: observe net core usage in memory map
Hi, I am developing for nRF5340 and would like to inspect net core memory usage. I am using the nRF Connect for VS Code extension (w/ nRF Connect SDK v2.1.0), and the Memory report action works well for this for the app core. Is there any way to generate a similar report for the net core?
    Unfortunately, there is no memory report for the network core in the VS Code extension.
    You can, however, open the build child image that you want to check the memory report on in a terminal, and use the command "ninja rom_report", e.g.:
    cd build\hci_rpmsg
    ninja rom_report
    ninja ram_report
    If you don't have the toolchain set up, open the terminal from Toolchain manager:
    Edvin
