SDHC SPI Send Command
Hello.
I have a custom board featuring nRF5340. I placed a microSD card reader in my board connected to SPI. I followed the fatfs zephyr example, but I'm struggling in mounting the disk.
I can correctly see the block count, sector size and capacity of the microSD, but as soon as I try to run fs_mount(&mp), the board resets.
When debugging, I saw that the board resets as it tries to run the function sdhc_spi_send_cmd
I don't know where the problem can be, since as I said I can correctly see the capacity of the card (I'm using a Premium microSDHC 32gb card by Verbatim )
I already tried to format the card both with Windows10 and the program SDCardFormatter, but nothing changed.
My devicetree for the spi/sd device is
&spi1 {
	status = "okay";
	cs-gpios = < &gpio0 7 GPIO_ACTIVE_LOW >;
	sck-pin = < 8 >;
	mosi-pin = < 9 >;
	miso-pin = < 10 >;
	sdhc0: sdhc@0 {
		compatible = "zephyr,sdhc-spi-slot";
		reg = <0>;
		status = "okay";
		label = "SDHC0";
		mmc {
			compatible = "zephyr,sdmmc-disk";
			status = "okay";
		spi-max-frequency = <16000000>;
And my connector is the following
  • This is instead sdhc_request when the SD card is in the slot. I honestly have no idea of what's happening.
  • Some investigation led me to understand where it arises the -134 error.
    It happens when the system checks the sd card type (either SDIO or SDMMC). The function sd_test_sdio returns -134.
    Inside of that, we try to send a sdhc command with opcode 5 and response type 85.
    This is the scope trace of that transaction is the following
  • Same return error also trying with a SanDisk Ultra microSDXC 128Gb.
    I don't think it's a problem of the SD I'm using, since as the original post says, I was able at least to retrieve the SD size
  • Hi
    The only reasons for error -134 (ENOTSUP) should be that the SD card is not recognized (likely due to incorrect setup) or that the SD card you're using is not supported which I don't think is the case with the SD cards you've mentioned using. Unfortunately I will need some time to set up something like this to test on my end, so I can't guarantee getting back to you with a tested solution any time soon. Some things you can check on your end:
    • Is the SD card reader powered sufficiently, maybe it is set to too low a voltage and thus browns out after reporting the SD size for example?
    • Is the SD size reported by the actual SD card, or is the size perhaps reported by the device tree?
    Without knowing what bytes we should expect return data on it's very hard to gather something from these scope traces, as it only seems to be empty data (FF) from the SD card reader except that 05 value.
    Simon
  • I can imagine it's not an easy and fast task, don't worry.
    - I cannot report the SD size anymore
    - The SD size never shows in the devicetree.
    The card is powered at 3.336V (measured with a multimeter)
    One thing I want to mention is that when I was able to retrieve the SD size, I was using a custom dts for my board, that was building only for the APPCORE. Due to the need of building also for the NETCORE, I started using it to build for nrf5340dk and used an overlay file to define my hardware.
