How to get the attributes from nordic ble from the example of "peripheral_lbs".
Hello All,
I'm tried to interface nordic with "peripheral_lbs" with arduino nano BLE with the example of "Led Control". Arduino nano ble is requesting attributes and nordic is disconnected after 10 seconds.
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
static struct bt_conn_cb conn_callbacks = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	//dk_set_led(USER_LED, led_state);
        printk("\n----------- led  changed cb -----------\n");
static bool app_button_cb(void)
        printk("\n----------- button  changed cb -----------\n");
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		uint32_t user_button_state = button_state & USER_BUTTON;
		bt_lbs_send_button_state(user_button_state);
		app_button_state = user_button_state ? true : false;
        printk("----------- button changed function -----------\n");
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
void main(void)
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	//err = dk_leds_init();
	//if (err) {
	//	printk("LEDs init failed (err %d)\n", err);
	//	return;
	//err = init_button();
	//if (err) {
	//	printk("Button init failed (err %d)\n", err);
	//	return;
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
        int i=0;
	for (;;) {
		//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
        printk(".");
Below code is from arduino
#include <ArduinoBLE.h>
// variables for button
const int buttonPin = 2;
int oldButtonState = LOW;
void setup() {
  Serial.begin(9600);
  while (!Serial);
  // configure the button pin as input
  pinMode(buttonPin, INPUT);
  Serial.println("Set button as i/p");
  // initialize the Bluetooth® Low Energy hardware
  BLE.begin();
  Serial.println("Bluetooth® Low Energy Central - LED control");
  Serial.println("--------- Start scanning for particular sercive id --> 19b10000-e8f2-537e-4f6c-d104768a1214");
  // start scanning for peripherals
//  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214");        //standard
  BLE.scanForUuid("00001523-1212-efde-1523-785feabcd123");          // nordic led uuid
  //00001525, 0x1212, 0xefde, 0x1523, 0x785feabcd123
void loop() {
  Serial.println("Checking peripheral is available or not");
  // check if a peripheral has been discovered
  BLEDevice peripheral = BLE.available();
  Serial.print("-------- peripheral = ");
  Serial.print(peripheral);
  if (peripheral) {
    // discovered a peripheral, print out address, local name, and advertised service
    Serial.print("Found and address is  ");
    Serial.println(peripheral.address());
    Serial.print(" ', local name is ");
    Serial.print(peripheral.localName());
    Serial.println("' advertise service uuid is  ");
    Serial.print(peripheral.advertisedServiceUuid());
    Serial.println();
    if (peripheral.localName() != "Nordic_LBS") {
      Serial.println("------Local name is not matched with 'LED'");
      return;
    Serial.println("-----------Stop Scanning ---------------");
    // stop scanning
    BLE.stopScan();
    Serial.println("------------- Controlled led is calling --------");
    controlLed(peripheral);
    Serial.println("------------- peripheral disconnected, start scanning again for service id --------");
    // peripheral disconnected, start scanning again
void controlLed(BLEDevice peripheral) {
  // connect to the peripheral
  Serial.println("Connecting ...");
  if (peripheral.connect()) {
    Serial.println("Connected");
  } else {
    Serial.println("Failed to connect!");
    return;
  // discover peripheral attributes
  Serial.println("Discovering attributes ...");
  if (peripheral.discoverAttributes()) {
    Serial.println("Attributes discovered");
  } else {
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
  // retrieve the LED characteristic
  BLECharacteristic ledCharacteristic = peripheral.characteristic("00001523-1212-efde-1523-785feabcd123");
  if (!ledCharacteristic) {
    Serial.println("Peripheral does not have LED characteristic!");
    return;
  } else if (!ledCharacteristic.canWrite()) {
    Serial.println("Peripheral does not have a writable LED characteristic!");
    return;
  while (peripheral.connected()) {
    // while the peripheral is connected
    // read the button pin
    int buttonState = digitalRead(buttonPin);
    if (oldButtonState != buttonState) {
      // button changed
      oldButtonState = buttonState;
      if (buttonState) {
        Serial.println("button pressed");
        // button is pressed, write 0x01 to turn the LED on
        ledCharacteristic.writeValue((byte)0x01);
//          ledCharacteristic.write("hello world");
//          if(ledCharacteristic.available()){
//           Serial.print( ledCharacteristic.read());
      } else {
        Serial.println("button released");
        // button is released, write 0x00 to turn the LED off
        ledCharacteristic.writeValue((byte)0x00);
  Serial.println("Peripheral disconnected");
Please help me,
Thanks.
  • Hi Ashok,
    I'm not familiar with the Arduino platform. However, please be aware that the UUID of the LBS service is different from the LBS characteristic
    Here is the service: 00001523-1212-efde-1523-785feabcd123
    And here is the LED characteristic: 00001525-1212-efde-1523-785feabcd123
    Button characteristic: 00001524-1212-efde-1523-785feabcd123
    If you want to acccess the LED characteristic, you need to use the correct UUID.
  • Hi Hung Bui,
    Thanks for the quick response.
    I tried to connect to the peripheral (nordic) with central (arduino nano nrf52840) device using the led characteristics uuid but still i'm unable to access the led characteristics.
      BLECharacteristic ledCharacteristic = peripheral.characteristic("00001525-1212-efde-1523-785feabcd123");
    Ashok.
  • Hi Ashok,
    Please try to debug and see what could be wrong here.
    I would suggest to test with the standard example provided by Arduino first before you move ahead.
    You need to make sure you managed to:
    1 - Scan
    2 - Connect
    3 - Discover the attribute table  (peripheral.discoverAttributes() )
    4 - Access the characteristic.
    You can consider using a sniffer trace to capture what happen over the air to make it easier to debug.
