nRF Sniffer not capturing packets after connection
I'm new to nRF Sniffer.  Just installed it and the installation seemed to go as expected.  I see my device in the device list when it is advertising.  After I select the device I can still see advertisement packets.  However, when the peripheral is connected to, then I no longer see any packets.  There is communication going on though.  Is there something that must be done to see the packets after the connection is made?
I'm using:
* nRF Sniffer 4.1.1
* nRF52840 Dongle (nRF6929 V 1.0.0 2018.22)
* M1 MacBook Pro Ventura 13.2.1
* Wireshark 4.0.3
    AFAIK, there is nothing more to be done for capturing the packets. So you are able to see the advertising packets after device filtering (by choosing your device in Wireshark) but not able to see the packets after connection is established?
    Did you follow everything mentioned in nRF sniffers section? Could you share sniffer_log for getting more idea on this?
    Kind Regards,
    Abhijith
  • Correct, I can see advertising packets after filtering.  But when I connect I just see a single CONNECT_IND in wire shark and that's it.
    I believe I followed everything in the nRF sniffers documentation.
    This is the /tmp/logs/log.txt output:
    01-Mar-2023 17:04:43 (-0600) INFO: Software version: 4.1.1
    01-Mar-2023 17:04:43 (-0600) INFO: sniffer started
    01-Mar-2023 17:04:43 (-0600) INFO: starting scan
    01-Mar-2023 17:04:43 (-0600) INFO: Scan flags: 0b11
    01-Mar-2023 17:04:43 (-0600) INFO: Sent TK to sniffer: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
    01-Mar-2023 17:04:43 (-0600) INFO: scanning started
    01-Mar-2023 17:04:43 (-0600) INFO: defaults written
    01-Mar-2023 17:04:43 (-0600) INFO: control loop
    01-Mar-2023 17:04:43 (-0600) INFO: Firmware version 4.1.1
    01-Mar-2023 17:04:43 (-0600) INFO: Firmware timestamp 35287739 reference: Mar 01 2023 17:04:43.619431 CST
    01-Mar-2023 17:09:55 (-0600) INFO: Clearing
    01-Mar-2023 17:11:32 (-0600) INFO: follow_device: [b'225', b' 187', b' 34', b' 69', b' 21', b' 200', b' 1']
    01-Mar-2023 17:11:32 (-0600) INFO: Sniffing device 14 - """"
    01-Mar-2023 17:11:32 (-0600) INFO: Follow flags: 0b0
    01-Mar-2023 17:11:33 (-0600) INFO: Following e1:bb:22:45:15:c8  random
  • It started working.  Not totally sure why.  But I did install ChmodBPF.  From what it said, I assumed that was only needed to capture packets in the OS.  But maybe that is needed for the BLE sniffer also?
    Yes, ChmodBPF  need to be installed for capturing packets by Wireshark in macOS. I am wondering why this only happened after establishing the connection.
    Anyhow Glad to hear that it resolved your issue.
    Kind Regards,
    Abhijith
  • Hi, I'd like to report, that this problem still exists.
    I've tested it and I have the same problem.
    If I use nRF52840 Dongle as a sniffer and nRF52832-DK as "nRF Connect for Desktop" device. With this combination I can see ADV_IND, SCAN_REQ, SCAN_RSP and CONNECT_IND packets, but nothing more. In wireshark's combo box "Device" I can see options: all advertising devices, follow IRK, but that's all. If I try to connect using "nRF Connect for Desktop" tool, advertising ADV_IND stops and CONNECT_IND packet is shown. If I disconnect, then advertising resumes.
    What is funny: If I switch the devices, so DK kit is a sniffer and a dongle is used to connect, then I can see all connection packets (GAP, GATT, empty PDU...). Wireshark's combo box contains more options as just 2 I've listed above.
    All software and firmware is up to date, freshly installed today. Running on Win 10.
