Utilize external flash with nrf9160 SiP on Custom board.
I would like to use the external flash to increase the internal flash, no intention, at the moment, to use it for MCUBoot file or FOTA .
How do I configure it, if it is even possible.
Info:
- nRF Connect SDK: 2.0.0
- nrf9160 SiP on custom board.
- Flash commuincate over SPI.
- Flash is working.
Thanks in advance.
  • Okay it builds fine but it enters a "Starting bootloader" loop.
    It will continue forever.
    Maybe the bootloader is placed at the first image slot?
  • Do you have logs in your application?
    For debugging, try to configure your application with CONFIG_RESET_ON_FATAL_ERROR=n.
    Do you still get a loop with this config?
    Sigurd Hellesvik
  • Due to a mistake from my side I did not save the state where is was stock in a endless "Starting bootloader" loop.
    I'm back to the BUS FAULT, as described above.
    But in my search for a solution for the endless "Starting bootloader" loop, I did find this:
     RE: nRF9160dk FOTA using external flash, ncs 2.0.2
    Will it be the best idea to start using nRF Connect SDK version 2.3.0 for avoiding any problems relating to this?
  • Good find!
    The potential issues mentioned in that thread should be fixed in future versions of the nRF Connect SDK.
    So yes, if it is possible for you, upgrading your project would likely be a good idea.
    Sigurd Hellesvik
  • Okay thank you.
    I have upgraded the SDK version from 2.0.0 to 2.3.0 and it builds fine and when I run it it, it gives this output:
    The only problem is that it never boot up the user app.
    I have added a more verbose logging:
    [00:00:00.379,150] <ESC><inf> NRFX_SPIM: Function: nrfx_spim_init, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.387,695] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20005290 - rx_bufs 0x20005298 - 1<ESC><CR><LF>
    [00:00:00.398,315] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200052a0 (2), current_rx 0x200052a0 (2), tx buf/len 0x20005288/1, rx buf/len 0x20005288/1<ESC><CR><LF>
    [00:00:00.414,123] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.421,630] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x200052d7/1<ESC><CR><LF>
    [00:00:00.430,114] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x200052d7/1<ESC><CR><LF>
    [00:00:00.438,629] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.446,746] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.454,254] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.462,310] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.470,367] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:00.479,644] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.487,792] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200052a8 - rx_bufs 0x200052b0 - 1<ESC><CR><LF>
    [00:00:00.498,413] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200052b8 (2), current_rx 0x200052b8 (2), tx buf/len 0x200052a0/1, rx buf/len 0x200052a0/1<ESC><CR><LF>
    [00:00:00.514,221] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.521,728] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x2000530c/3<ESC><CR><LF>
    [00:00:00.530,212] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x2000530c/3<ESC><CR><LF>
    [00:00:00.538,696] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.546,844] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.554,351] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.562,408] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.570,465] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:00.579,742] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    *** Booting Zephyr OS build v3.2.99-ncs2 ***<CR><LF>
    [00:00:00.591,949] <ESC><dbg> os: k_sched_unlock: scheduler unlocked (0x20000338:0)<ESC><CR><LF>
    [00:00:00.599,731] <ESC><inf> mcuboot: Starting bootloader<ESC><CR><LF>
    [00:00:00.605,804] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20005238 - rx_bufs 0x20005240 - 1<ESC><CR><LF>
    [00:00:00.616,394] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20005248 (2), current_rx 0x20005248 (2), tx buf/len 0x20005230/4, rx buf/len 0x20005230/4<ESC><CR><LF>
    [00:00:00.632,202] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.639,709] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20001830/32<ESC><CR><LF>
    [00:00:00.648,284] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20001830/32<ESC><CR><LF>
    [00:00:00.656,890] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.665,008] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.672,546] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.680,572] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.688,629] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:00.697,906] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.706,146] <ESC><inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3<ESC><CR><LF>
    [00:00:00.716,186] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051d8 - rx_bufs 0x200051e0 - 1<ESC><CR><LF>
    [00:00:00.726,837] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051e8 (2), current_rx 0x200051e8 (2), tx buf/len 0x200051d0/4, rx buf/len 0x200051d0/4<ESC><CR><LF>
    [00:00:00.742,645] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.750,152] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005238/16<ESC><CR><LF>
    [00:00:00.758,728] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005238/16<ESC><CR><LF>
    [00:00:00.767,303] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.775,451] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.782,958] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.790,985] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.799,041] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:00.808,319] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.816,497] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051d8 - rx_bufs 0x200051e0 - 1<ESC><CR><LF>
    [00:00:00.827,117] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051e8 (2), current_rx 0x200051e8 (2), tx buf/len 0x200051d0/4, rx buf/len 0x200051d0/4<ESC><CR><LF>
    [00:00:00.842,926] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.850,433] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005237/1<ESC><CR><LF>
    [00:00:00.858,917] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005237/1<ESC><CR><LF>
    [00:00:00.867,431] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.875,549] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.883,087] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.891,143] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.899,200] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:00.908,477] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.916,625] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051c8 - rx_bufs 0x200051d0 - 1<ESC><CR><LF>
    [00:00:00.927,246] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051d8 (2), current_rx 0x200051d8 (2), tx buf/len 0x200051c0/4, rx buf/len 0x200051c0/4<ESC><CR><LF>
    [00:00:00.943,084] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.950,592] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005292/1<ESC><CR><LF>
    [00:00:00.959,075] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005292/1<ESC><CR><LF>
    [00:00:00.967,559] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:00.975,677] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:00.983,215] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.991,241] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:00.999,298] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.008,575] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.016,754] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051c8 - rx_bufs 0x200051d0 - 1<ESC><CR><LF>
    [00:00:01.027,374] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051d8 (2), current_rx 0x200051d8 (2), tx buf/len 0x200051c0/4, rx buf/len 0x200051c0/4<ESC><CR><LF>
    [00:00:01.043,182] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.050,689] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005293/1<ESC><CR><LF>
    [00:00:01.059,173] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005293/1<ESC><CR><LF>
    [00:00:01.067,687] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.075,805] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.083,312] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.091,369] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.099,426] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.108,703] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.116,851] <ESC><inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3<ESC><CR><LF>
    [00:00:01.127,075] <ESC><inf> mcuboot: Boot source: none<ESC><CR><LF>
    [00:00:01.132,507] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x20005238 - rx_bufs 0x20005240 - 1<ESC><CR><LF>
    [00:00:01.143,127] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20005248 (2), current_rx 0x20005248 (2), tx buf/len 0x20005230/4, rx buf/len 0x20005230/4<ESC><CR><LF>
    [00:00:01.158,935] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.166,442] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20001830/32<ESC><CR><LF>
    [00:00:01.175,018] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20001830/32<ESC><CR><LF>
    [00:00:01.183,624] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.191,741] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.199,249] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.207,305] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.215,362] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.224,639] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.232,818] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051f8 - rx_bufs 0x20005200 - 1<ESC><CR><LF>
    [00:00:01.243,408] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20005208 (2), current_rx 0x20005208 (2), tx buf/len 0x200051f0/4, rx buf/len 0x200051f0/4<ESC><CR><LF>
    [00:00:01.259,216] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.266,723] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005258/16<ESC><CR><LF>
    [00:00:01.275,299] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005258/16<ESC><CR><LF>
    [00:00:01.283,905] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.292,022] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.299,530] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.307,586] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.315,643] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.324,920] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.333,099] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051f8 - rx_bufs 0x20005200 - 1<ESC><CR><LF>
    [00:00:01.343,719] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x20005208 (2), current_rx 0x20005208 (2), tx buf/len 0x200051f0/4, rx buf/len 0x200051f0/4<ESC><CR><LF>
    [00:00:01.359,527] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.367,034] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x20005257/1<ESC><CR><LF>
    [00:00:01.375,518] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x20005257/1<ESC><CR><LF>
    [00:00:01.384,033] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.392,150] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.399,658] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.407,714] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.415,771] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.425,048] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.433,227] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051e8 - rx_bufs 0x200051f0 - 1<ESC><CR><LF>
    [00:00:01.443,847] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051f8 (2), current_rx 0x200051f8 (2), tx buf/len 0x200051e0/4, rx buf/len 0x200051e0/4<ESC><CR><LF>
    [00:00:01.459,655] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.467,163] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x200052a2/1<ESC><CR><LF>
    [00:00:01.475,646] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x200052a2/1<ESC><CR><LF>
    [00:00:01.484,161] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.492,279] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.499,816] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.507,873] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.515,930] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.525,207] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.533,355] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: tx_bufs 0x200051e8 - rx_bufs 0x200051f0 - 1<ESC><CR><LF>
    [00:00:01.543,975] <ESC><dbg> spi_nrfx_spim: spi_context_buffers_setup: current_tx 0x200051f8 (2), current_rx 0x200051f8 (2), tx buf/len 0x200051e0/4, rx buf/len 0x200051e0/4<ESC><CR><LF>
    [00:00:01.559,783] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.567,291] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len 0x200052a3/1<ESC><CR><LF>
    [00:00:01.575,805] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len 0x200052a3/1<ESC><CR><LF>
    [00:00:01.584,289] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.592,407] <ESC><dbg> NRFX_SPIM: irq_handler: Event: NRF_SPIM_EVENT_END.<ESC><CR><LF>
    [00:00:01.599,945] <ESC><dbg> spi_nrfx_spim: spi_context_update_tx: tx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.608,001] <ESC><dbg> spi_nrfx_spim: spi_context_update_rx: rx buf/len (nil)/0<ESC><CR><LF>
    [00:00:01.616,058] <ESC><dbg> spi_nrfx_spim: transfer_next_chunk: Transaction finished with status 0<ESC><CR><LF>
    [00:00:01.625,335] <ESC><inf> NRFX_SPIM: Function: spim_xfer, error code: NRFX_SUCCESS.<ESC><CR><LF>
    [00:00:01.633,483] <ESC><inf> mcuboot: Swap type: none<ESC><CR><LF>
    [00:00:01.742,462] <ESC><inf> mcuboot: Bootloader chainload address offset: 0x10000<ESC><CR><LF>
    [00:00:01.750,213] <ESC><inf> mcuboot: Jumping to the first image slot<ESC><CR><LF>
