Hi, I am using nRF Connect SDK v2.2.0 on a nRF52840 custom board and I am trying to use the PSA API to perform a hash and verify operation using psa_hash_compute() and psa_verify_hash()
While using these functions I am seeing some errors and faults that I don't understand.
I have been following along with the example code under: /nrf/samples/crypto/ecdsa
Below is what I have set in my prj.conf file:
CONFIG_NRF_SECURITY=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_HEAP_SIZE=8192 CONFIG_PSA_CRYPTO_DRIVER_OBERON=y CONFIG_PSA_CRYPTO_DRIVER_CC3XX=n
This matches what is provided in the sample code.
My code is doing the following:
#define NRF_CRYPTO_EXAMPLE_ECDSA_TEXT_SIZE (100)
#define NRF_CRYPTO_EXAMPLE_ECDSA_PUBLIC_KEY_SIZE (65)
#define NRF_CRYPTO_EXAMPLE_ECDSA_SIGNATURE_SIZE (64)
#define NRF_CRYPTO_EXAMPLE_ECDSA_HASH_SIZE (64)
static uint8_t m_pub_key[NRF_CRYPTO_EXAMPLE_ECDSA_PUBLIC_KEY_SIZE];
static uint8_t m_signature[NRF_CRYPTO_EXAMPLE_ECDSA_SIGNATURE_SIZE];
static uint8_t m_hash[NRF_CRYPTO_EXAMPLE_ECDSA_HASH_SIZE];
static psa_key_handle_t keypair_handle;
static psa_key_handle_t pub_key_handle;
static uint8_t m_plain_text[NRF_CRYPTO_EXAMPLE_ECDSA_TEXT_SIZE] = {
"Example string to demonstrate basic usage of ECDSA."
/* Compute the SHA256 hash*/
cryptoStatus = psa_hash_compute(
PSA_ALG_SHA_256,
m_plain_text,
sizeof(m_plain_text),
m_hash,
sizeof( m_hash ),
&outputLen);
LOG_ERR("psa_hash_compute cryptoStatus %d", cryptoStatus);
/* Sign the hash */
cryptoStatus = psa_sign_hash(
keypair_handle,
PSA_ALG_ECDSA( PSA_ALG_SHA_256 ),
m_hash,
sizeof( m_hash ),
m_signature,
sizeof(m_signature),
&outputLen);
LOG_ERR("psa_sign_hash cryptoStatus %d", cryptoStatus);
cryptoStatus = psa_verify_hash(
pub_key_handle,
m_hash,
sizeof( m_hash ),
m_signature,
sizeof( m_signature ) );
LOG_ERR("psa_verify_hash cryptoStatus %d", cryptoStatus);
A few things:
- I have currently set my hash (m_hash variable) to be 64 bytes - and when I do that the call to psa_sign_hash returns back PSA_ERROR_INVALID_ARGUMENT (Error -135)
- The psa_hash_compute function runs correctly I have been able to verify that hash output is valid by verifying it with an offline SHA256 hash calculator but for some reason psa_sign_hash and psa_verify_hash both return INVALID ARGUMENT errors.
- My initial thought was that the size of the hash array might be the thing causing that error - so I changed the hash array to be 32 bytes (which matches wat the sample code has) and that was not helpful either.
- When I do that, the system actually throws a stack overflow fault.
- If i make the hash array any length > 32 - the stack overflow goes away but I am still left with the PSA_ERROR_INVALID_ARGUMENT error
I am not sure what I am doing wrong here, but seems like something small I am missing. Could you help?
I am went through the sample code and tried to make my configuration and settings exactly the same but not sure why this is failing. Any help would be appreciated
