I'm running Windows 11, VSCode nRF Connect plugin, WSL, using NCS v2, with an board of nrf52_adafruit_feather, and the application won't build.
Executing task: nRF Connect: Generate config nrf52_adafruit_feather for /home/doug/git/webusb Building webusb west build --build-dir /home/doug/git/webusb/build /home/doug/git/webusb --pristine --board nrf52_adafruit_feather -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /home/doug/git/webusb -- Found Python3: /home/doug/ncs/toolchains/v2.0.0/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter -- Cache files will be written to: /home/doug/.cache/zephyr -- Zephyr version: 3.0.99 (/home/doug/ncs/v2.0.0/zephyr) -- Found west (found suitable version "0.13.1", minimum required is "0.7.1") -- Board: nrf52_adafruit_feather -- Found host-tools: zephyr 0.14.1 (/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found dtc: /home/doug/ncs/toolchains/v2.0.0/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: zephyr 0.14.1 (/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk) -- Found BOARD.dts: /home/doug/ncs/v2.0.0/zephyr/boards/arm/nrf52_adafruit_feather/nrf52_adafruit_feather.dts -- Generated zephyr.dts: /home/doug/git/webusb/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /home/doug/git/webusb/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /home/doug/git/webusb/build/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: /home/doug/git/webusb/build/zephyr/dts.cmake Parsing /home/doug/git/webusb/Kconfig Loaded configuration '/home/doug/ncs/v2.0.0/zephyr/boards/arm/nrf52_adafruit_feather/nrf52_adafruit_feather_defconfig' Merged configuration '/home/doug/git/webusb/prj.conf' Merged configuration '/home/doug/git/webusb/build/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/home/doug/git/webusb/build/zephyr/.config' Kconfig header saved to '/home/doug/git/webusb/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.3.0 -- The CXX compiler identification is GNU 10.3.0 -- The ASM compiler identification is GNU -- Found assembler: /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message): CONFIG_USB_DEVICE_VID has default value 0x2FE3. This value is only for testing and MUST be configured for USB products. CMake Warning at /home/doug/ncs/v2.0.0/zephyr/CMakeLists.txt:814 (message): No SOURCES given to Zephyr library: drivers__usb__device Excluding target from build. -- Configuring done -- Generating done -- Build files have been written to: /home/doug/git/webusb/build -- west build: building application [1/179] Preparing syscall dependency handling [2/179] Generating include/generated/version.h -- Zephyr version: 3.0.99 (/home/doug/ncs/v2.0.0/zephyr), build: v3.0.99-ncs1 [3/179] Generating misc/generated/syscalls_subdirs.trigger [4/179] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [5/179] Generating include/generated/driver-validation.h [6/179] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [7/179] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [8/179] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [9/179] Generating include/generated/offsets.h [10/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [11/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [12/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [13/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [14/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [15/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [16/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [17/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [18/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [19/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [20/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [21/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [22/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [23/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [24/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [25/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [26/179] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [27/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj [28/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [29/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [30/179] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [31/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [32/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [33/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj [34/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj [35/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [36/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [37/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [38/179] Building C object CMakeFiles/app.dir/src/main.c.obj [39/179] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj [40/179] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [41/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj [42/179] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [43/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj [44/179] Building C object CMakeFiles/app.dir/src/webusb.c.obj [45/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj [46/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj [47/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj [48/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg2.c.obj [49/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_uart.c.obj [50/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [51/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/bos.c.obj [52/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj [53/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj [54/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [55/179] Linking C static library app/libapp.a [56/179] Generating linker_zephyr_pre1.cmd [57/179] Generating linker_zephyr_pre0.cmd [58/179] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj [59/179] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [60/179] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [61/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [62/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [63/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [64/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [65/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [66/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [67/179] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [68/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [69/179] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [70/179] Linking C static library zephyr/arch/common/libisr_tables.a [71/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [72/179] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [73/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [74/179] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [75/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [76/179] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [77/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [78/179] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [79/179] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [80/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [81/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [82/179] Linking C static library zephyr/arch/common/libarch__common.a [83/179] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [84/179] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [85/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [86/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [87/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [88/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [89/179] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [90/179] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [91/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [92/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [93/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [94/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [95/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [96/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [97/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [98/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [99/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [100/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [101/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [102/179] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [103/179] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [104/179] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [105/179] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj [106/179] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj [107/179] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [108/179] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj [109/179] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [110/179] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj [111/179] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj [112/179] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uart.c.obj [113/179] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj [114/179] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [115/179] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a [116/179] Linking C static library zephyr/lib/posix/liblib__posix.a [117/179] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [118/179] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [119/179] Linking C static library zephyr/drivers/hwinfo/libdrivers__hwinfo.a [120/179] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [121/179] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [122/179] Linking C static library zephyr/drivers/console/libdrivers__console.a [123/179] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a [124/179] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [125/179] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf52.c.obj [126/179] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [127/179] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [128/179] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [129/179] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [130/179] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [131/179] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [132/179] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/doug/ncs/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [133/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [134/179] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [135/179] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [136/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [137/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [138/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_transfer.c.obj [139/179] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [140/179] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [141/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [142/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [143/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [144/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [145/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [146/179] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [147/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [148/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj [149/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj [150/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [151/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj [152/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj [153/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj [154/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj [155/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj [156/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj [157/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj [158/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj [159/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [160/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj [161/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj [162/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [163/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [164/179] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [165/179] Linking C static library zephyr/kernel/libkernel.a [166/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_descriptor.c.obj [167/179] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/device/usb_device.c.obj [168/179] Linking C static library zephyr/libzephyr.a [169/179] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map : && ccache /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/home/doug/git/webusb/build/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/hwinfo/libdrivers__hwinfo.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"/home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m/nofp" -L/home/doug/git/webusb/build/zephyr -lgcc zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cd /home/doug/git/webusb/build/zephyr && /home/doug/ncs/toolchains/v2.0.0/usr/local/lib/python3.8/site-packages/cmake/data/bin/cmake -E echo /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_halt_endpoint_req': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1016: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1022: undefined reference to `usb_dc_ep_clear_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `set_endpoint': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:533: undefined reference to `usb_dc_ep_configure' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:543: undefined reference to `usb_dc_ep_enable' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_handle_std_device_req': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:819: undefined reference to `usb_dc_set_address' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `reset_endpoint': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:581: undefined reference to `usb_dc_ep_disable' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `disable_interface_ep': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1178: undefined reference to `usb_dc_ep_disable' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_get_status_endpoint': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:987: undefined reference to `usb_dc_ep_is_stalled' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `composite_setup_ep_cb': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1489: undefined reference to `usb_dc_ep_set_callback' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_write': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1318: undefined reference to `usb_dc_ep_write' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_data_to_host': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:266: undefined reference to `usb_dc_ep_write' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_handle_control_transfer': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:356: undefined reference to `usb_dc_ep_read' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:290: undefined reference to `usb_dc_ep_read' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:293: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:317: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:318: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:335: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:348: undefined reference to `usb_dc_ep_read' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:351: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:360: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:361: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:374: undefined reference to `usb_dc_ep_set_stall' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_device.c.obj): in function `usb_enable': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1545: undefined reference to `usb_dc_set_status_callback' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1547: undefined reference to `usb_dc_attach' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1562: undefined reference to `usb_dc_ep_configure' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1568: undefined reference to `usb_dc_ep_configure' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1574: undefined reference to `usb_dc_ep_set_callback' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1580: undefined reference to `usb_dc_ep_set_callback' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1593: undefined reference to `usb_dc_ep_enable' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_device.c:1598: undefined reference to `usb_dc_ep_enable' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_descriptor.c.obj): in function `usb_validate_ep_cfg_data': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_descriptor.c:261: undefined reference to `usb_dc_ep_check_cap' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_transfer.c.obj): in function `usb_transfer_work': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:111: undefined reference to `usb_dc_ep_read_wait' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:125: undefined reference to `usb_dc_ep_mps' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:132: undefined reference to `usb_dc_ep_read_continue' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_transfer.c.obj): in function `usb_transfer_ep_callback': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:180: undefined reference to `usb_dc_ep_read_wait' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/libzephyr.a(usb_transfer.c.obj): in function `usb_transfer': /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:244: undefined reference to `usb_dc_ep_mps' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:244: undefined reference to `usb_dc_ep_mps' /home/doug/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/doug/ncs/v2.0.0/zephyr/subsys/usb/device/usb_transfer.c:254: undefined reference to `usb_dc_ep_read_continue' collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /home/doug/ncs/toolchains/v2.0.0/usr/local/bin/cmake --build /home/doug/git/webusb/build
Any thoughts on what I need to do to get this to work?
Thanks.
Doug
