can´t build a configuration in nrf9160 custom board
i am a beginner on the nordic microcontrollers, and i bought a nrf9160 custom board to start, is from signetik, en they have a problem with the documentation, because don´t have documentation.
In resume, i have some interruptions and problems in software level:
At the time to build the proyect in vscode whit the extensions pack of nordic apears the error:
Building hello_world_142
west build --build-dir c:\Users\Abrah\Documents\Job\HTech\M1-N1\M1-N1\Curses\hello_world_142\build c:\Users\Abrah\Documents\Job\HTech\M1-N1\M1-N1\Curses\hello_world_142 --pristine --board signetik_sigcellns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE"
Including boilerplate (Zephyr base): C:/ncs/v1.4.2/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/Abrah/Documents/Job/HTech/M1-N1/M1-N1/Curses/hello_world_142
-- Zephyr version: 2.4.0 (C:/ncs/v1.4.2/zephyr)
-- Found Python3: C:/ncs/v1.4.2/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components:  Interpreter
-- Found west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Board: signetik_sigcellns
-- Cache files will be written to: C:/ncs/v1.4.2/zephyr/.cache
-- Found dtc: C:/ncs/v1.4.2/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/ncs/v1.4.2/toolchain/opt)
-- Found BOARD.dts: C:/ncs/v1.4.2/zephyr/boards/arm/signetik_iot/signetik_sigcellns.dts
Error: signetik_sigcellns.dts.pre.tmp:393.23-24 syntax error
FATAL ERROR: Unable to parse input tree
CMake Error at C:/ncs/v1.4.2/zephyr/cmake/dts.cmake:213 (message):
  command failed with return code: 1
  C:/ncs/v1.4.2/zephyr/cmake/app/boilerplate.cmake:590 (include)
  C:/ncs/v1.4.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  C:/ncs/v1.4.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
Signetik (who made radio),provide a repository in which to find the dts files for the build configuration, which were added to the boards in the zephyr directory
I use toolchain version 1.4.2, because the files of repository match with this version.
so I would appreciate if I have to add some configuration, I have a problem with the versions
