I recently discover a new bug in the app_timer2 lib of the lastest SDK (17.1.0) using the softdevice s132_7.2.0
Here are the steps to reproduce the bug:
1- create a repeated timer in main().
APP_TIMER_DEF(TIMER1);
int main()
uint32_t err_code = app_timer_create(&TIMER1, APP_TIMER_MODE_REPEATED, TIMER1_IRQ_Handle);
2- start the timer with 2000ms of interval.
app_timer_start(TIMER1, APP_TIMER_TICKS(2000), NULL);
3- when the timer expires, stop it in its interrupt handler and start it again with the same interval (2000ms)
static void TIMER1_IRQ_Handle(void * p_context)
app_timer_stop(TIMER1);
uint32_t err_code = app_timer_start(TIMER1, APP_TIMER_TICKS(2000), NULL);
NRF_LOG_INFO("TIMER1_IRQ_Handle app_timer_start err =%d\n",err_code)
the BUG : the timer will expire in 4000ms the second time and the in next others and not in 2000ms
it seems that the timer always expires in a double interval than the one given to it in the interrupt handler
Do you have any workaround for this bug ?.
Attached a simple .c example to directly reproduce the bug.
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_beacon_main main.c
* @ingroup ble_sdk_app_beacon
* @brief Beacon Transmitter Sample Application main file.
* This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
ret_code_t err_code;
uint32_t ram_start = 0;
err_code = nrf_sdh_ble_default_cfg_set(0xFF, &ram_start);
// Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing timers. */
static void timers_init(void)
nrf_pwr_mgmt_run();
* @brief Function for application main entry.
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
NRF_LOG_INFO("main app_timer_create err=%d \n",err_code);
NRF_LOG_INFO("main app_timer_start err=%d \n",err_code);
// Enter main loop.
for (;; )
idle_state_handle();
