Hello DevZone community,
I'm playing with the nRF5340 Audio Application and I'm trying to modify it to support a scenario where one headset can be switching between two unicast gateways. First, ACL connection between the first gateway and the headset is established, so that the audio stream can be configured and started. Then I want to do the same for the other gateway, i.e. to establish ACL connection and if certain conditions are met, stop the first stream and configure and start the new one from the new gateway. The point I struggle with is, that the second ACL connection gets established - I get the connected_cb - but right after that the connection is always ended with BT_HCI_ERR_CONN_LIMIT_EXCEEDED as a result, despite the fact I increased CONFIG_BT_MAX_CONN to 2.
This leads me to a question - is this scenario where one headset (peripheral) can accept more simultaneous ACL connections even supported by LE Audio Controller Subsystem for nRF53?
Thanks!
Lada
