Timer stops working after a while
I am working on a project in which I am using code from central and peripheral hr example. I only need the scanning and advertising part and not HRS so I removed the HRS code. I also want to connect my board with a phone to config some settings like ID, calibration, etc. For this, I have also added a code from the Peripheral UART example. After combining these codes, the code should work like this.
On startup, MCU will wait for a mobile to connect with it and when a disconnected() callback happens, MCU will run in scan and adv mode. But what I observe is that in main(), my timer stops working when I call a function bt_update_packet(). When I am commenting bt_update_packet(), the timer continues to run without a problem. This is only happening when I am combining the two examples mentioned above. When I am not including peripheral uart code in my project timer is working fine and bt_update_packet() also happens to run without a problem. Can anybody help? I am using nRF connect sdk 2.1.2 and nRF52832 dev kit.
Here is my code and project configuration. Any help would be very appreciated. Thanks in advance!
#include <zephyr/zephyr.h>
#include <zephyr/drivers/flash.h>
#include <zephyr/storage/flash_map.h>
#include <zephyr/device.h>
#include "include/adc.h"
#include "include/application.h"
#include "include/temp_sensor.h"
#include "include/bt.h"
#include "include/board_config.h"
#include "include/slave_param.h"
#pragma region "FLASH Configuration"
#ifdef CONFIG_TRUSTED_EXECUTION_NONSECURE
#define FLASH_TEST_LABEL image_1_nonsecure
#else
#pragma endregion
 * Macros
#define RUN_STATUS_LED 				DK_LED1
#define SLEEP_TIME_MS 				100
#define TIMER_INTERVAL_MSEC 		1000
#define FLASH_TEST_OFFSET 			FLASH_AREA_OFFSET(FLASH_TEST_LABEL)
#define FLASH_TEST_DEVICE 			FLASH_AREA_DEVICE(FLASH_TEST_LABEL)
#define FLASH_PAGE_SIZE 			4096
#define TEST_DATA_WORD_0 			0x1234
#define TEST_DATA_WORD_1 			0xabcd
#define TEST_DATA_WORD_2 			0xa1b1
#define TEST_DATA_WORD_3 			0xc1d1
#define FLASH_TEST_OFFSET2 			0x41234
#define FLASH_TEST_PAGE_IDX 		37
#define CUSTOM_MAC_ADDR_LEN			15		//13 (without ID number)
#pragma region "BT LE Configuration"
uint8_t advData[MAX_NUM_OF_BYTES] = {};
static struct bt_data ad[] = {
	BT_DATA(BT_DATA_MANUFACTURER_DATA, advData, sizeof(advData)),
static struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME)
#pragma endregion
 * Global Variables
char mac_address_str[CUSTOM_MAC_ADDR_LEN];
uint8_t sdData[MAX_NUM_OF_BYTES] = {};
uint8_t *pSdData = sdData;
volatile bool uartConnectFlag = false;
volatile bool configFlag = false;
uint8_t counter = 0;
volatile bool timerUARTFlag = false;
volatile bool advUpdateFlag = false;
volatile bool scanStopFlag = false;
volatile bool timerStartFlag = false;
 * Handlers
#pragma region "Scanning"
static bool data_cb(struct bt_data *data, void *user_data)
	*pSdData = user_data;
	uint8_t len;
	switch (data->type)
	case BT_DATA_MANUFACTURER_DATA:
		len = MIN(data->data_len, DATABYTES - 1);
		memcpy(pSdData, data->data, len);
		pSdData[len] = '\0';
		return false;
		return true;
static void scan_recv(const struct bt_le_scan_recv_info *info, struct net_buf_simple *buf)
	char le_addr[BT_ADDR_LE_STR_LEN];
	uint8_t parseDataBytes[DATABYTES];
	uint16_t data_len;
	memset(parseDataBytes, 0, sizeof(parseDataBytes));
	data_len = buf->len;
	bt_data_parse(buf, data_cb, parseDataBytes);
	bt_addr_le_to_str(info->addr, le_addr, sizeof(le_addr));
	if (strncmp(le_addr, "E0:FE:52:79:8B:7F", 17) == 0)
		// printk("Slave SCAN -> Master device: %s, AD data len: %u  Databytes:\n"
		// 		"%x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x\n\n",
		// 		le_addr, data_len,
		// 		sdData[0], sdData[1], sdData[2], sdData[3], sdData[4], sdData[5], sdData[6], sdData[7], sdData[8],
		// 		sdData[9], sdData[10], sdData[11], sdData[12], sdData[13], sdData[14], sdData[15], sdData[16], sdData[17],
		// 		sdData[18], sdData[19], sdData[20], sdData[21], sdData[22], sdData[23], sdData[24], sdData[25], sdData[26],
		// 		sdData[27], sdData[28]);
		// static uint16_t scanCount = 0;
		// printk("Scan count %d\n", scanCount++);
		gpio_pin_toggle_dt(&leds_array[3]);
static struct bt_le_scan_cb scan_callbacks = {
	.recv = scan_recv,
struct bt_le_scan_param scan_param = {
	.type = BT_LE_SCAN_TYPE_PASSIVE,
	.options = BT_LE_SCAN_OPT_NONE,
	.interval = BT_GAP_SCAN_FAST_INTERVAL,
	.window = BT_GAP_SCAN_FAST_INTERVAL, 		// changed from BT_GAP_SCAN_FAST_WINDOW
#pragma endregion
void timer_ISR(void)
	// sysFlags.timer_10ms_flag = true;
	sysFlags.timer_10ms_count++;
	if ((sysFlags.timer_10ms_count % ADC_TIMER_COUNTS) == 0)
		sysFlags.adc_sample_task = true;
	if ((sysFlags.timer_10ms_count % BT_ADV_TIMER_COUNTS) == 0)
		sysFlags.bt_adv_task = true;
	if (sysFlags.timer_10ms_count == 100)
		sysFlags.timer_10ms_count = 0;
		sysFlags.timer_1000ms_flag = true;
void bt_update_packet(void)
	int res;
	res = bt_le_adv_stop();
	if (res)
		printk("************ADV STOP failed!************ bt_cb (err %d)\n", res);
		return;
	printk("************ADV STOP successful!************\n");
	slave.soc_temp = LOBYTE(nrf52_chip_temperature());
	advData[0] = read_slave_id();
	advData[1] = slave.counter++;
	advData[2] = slave.cellsVoltage[0].adc_m_16bits.adc_hiByte;
	advData[3] = slave.cellsVoltage[0].adc_m_16bits.adc_loByte;
	advData[4] = slave.cellsVoltage[1].adc_m_16bits.adc_hiByte;
	advData[5] = slave.cellsVoltage[1].adc_m_16bits.adc_loByte;
	advData[6] = slave.cellsVoltage[2].adc_m_16bits.adc_hiByte;
	advData[7] = slave.cellsVoltage[2].adc_m_16bits.adc_loByte;
	advData[8] = slave.cellsVoltage[3].adc_m_16bits.adc_hiByte;
	advData[9] = slave.cellsVoltage[3].adc_m_16bits.adc_loByte;
	advData[10] = slave.cellsTemperature[0].adc_m_16bits.adc_loByte;
	advData[11] = slave.cellsTemperature[1].adc_m_16bits.adc_loByte;
	advData[12] = slave.cellsTemperature[2].adc_m_16bits.adc_loByte;
	advData[13] = slave.cellsTemperature[3].adc_m_16bits.adc_loByte;
	advData[14] = slave.soc_temp;
	advData[15] = slave.current[1];
	advData[16] = slave.current[0];
	advData[17] = slave.cell_soc[0];
	advData[18] = slave.cell_soc[1];
	advData[19] = slave.cell_soc[2];
	advData[20] = slave.cell_soc[3];
	advData[21] = slave.status;
	for (uint8_t i = 22; i < sizeof(advData); i++)
		advData[i] = 0xB0 + (i - 21); // RFU bytes
	// updating adv data
	ad[0].data = advData;
	ad[0].data_len = sizeof(advData);
	ad[0].type = BT_DATA_MANUFACTURER_DATA;
	// updating sd data
	get_mac_address(mac_address_str, sizeof(mac_address_str));
	sd[0].data = mac_address_str;
	sd[0].data_len = sizeof(mac_address_str);
	sd[0].type = BT_DATA_NAME_COMPLETE;
	res = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	if (res)
		printk("Advertising failed to start bt_cb (err %d)\n", res);
		return;
	printk("ADV started again!\n");
	// printk("Slave ADV  = %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x %x\n\n",
	// 		advData[0], advData[1], advData[2], advData[3], advData[4], advData[5], advData[6], advData[7], advData[8],
	// 		advData[9], advData[10], advData[11], advData[12], advData[13], advData[14], advData[15], advData[16], advData[17],
	// 		advData[18], advData[19], advData[20], advData[21], advData[22], advData[23], advData[24], advData[25], advData[26],
	// 		advData[27], advData[28]);
K_TIMER_DEFINE(htimer, &timer_ISR, NULL);
#pragma region "BLE UART"
#include "uart_async_adapter.h"
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/usb/usb_device.h>
#include <soc.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/settings/settings.h>
#include <stdio.h>
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED1
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
static struct k_work_delayable uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type) {
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req) {
			return;
		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf->len > 0) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf) {
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
				   data);
		uart_tx(uart, &buf->data[aborted_len],
			buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		printk("Not able to allocate UART receive buffer");
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	if (!device_is_ready(uart)) {
		return -ENODEV;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err && (err != -EALREADY)) {
			LOG_ERR("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		LOG_ERR("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		LOG_INF("Wait for DTR");
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr) {
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			LOG_WRN("Failed to set DSR, ret code %d", err);
	tx = k_malloc(sizeof(*tx));
	if (tx) {
		pos = snprintf(tx->data, sizeof(tx->data),
			       "Starting Nordic UART service example\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data))) {
			k_free(tx);
			LOG_ERR("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
	} else {
		return -ENOMEM;
	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
	if (err) {
		LOG_ERR("Cannot display welcome message (err: %d)", err);
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)", err);
		return;
	printk("Connected %s", addr);
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	printk("\nconnected()\n");
	printk("Disconnected: %s (reason %u)", addr, reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
	timerStartFlag = true;
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", addr, level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", addr,
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	printk("Received data from: %s", addr);
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			printk("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
#pragma endregion
void main(void)
	int err;
	int blink_status = 0;
	err = uart_init();
	if (err)
		error();
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED))
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return;
		// err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		// if (err) {
		// 	printk("Failed to register authorization info callbacks.\n");
		// 	return;
	// DIP switches initialization
	dip_switch_init();
	// ADC initialization
	err = adc_init();
	if (err)
		printk("ADC setup failed (error %d)\n", err);
		return;
	// Reset advData buffer
	bt_data_bytes_reset(advData, sizeof(advData));
	printk("Starting Peripheral\n");
	// LEDs initialization (disable for ble uart)
	err = leds_init();
	if (err)
		printk("LEDs init failed (err %d)\n", err);
		return;
	// BT initialization
	err = bt_enable(NULL);
	if (err)
		return;
	printk("\nBluetooth initialized\n");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS))
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err)
		printk("\nFailed to initialize UART service (err: %d)\n", err);
		return;
	// Get slave ID based on dip switch position and MAC addr
	//  Scanning initialization
	bt_le_scan_cb_register(&scan_callbacks);
	printk("Registered scan callbacks\n");
	// Starting adv
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	if (err)
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising started\n");
	// Timer initialization
	k_timer_start(&htimer, K_MSEC(1000), K_MSEC(10));
	static uint16_t countValue = 0;
	while (1)
		if(timerStartFlag == true)
			advUpdateFlag = true;
			printk("Timer started\n");
			err = bt_le_adv_stop();
			if (err)
				printk("Stop adv failed (err %d)\n", err);
				return err;
			printk("adv stopped\n");
			err = bt_le_scan_start(&scan_param, data_cb);
			if (err)
				printk("Start scanning failed (err %d)\n", err);
				return err;
			printk("Scanning started\n");
		if (sysFlags.timer_1000ms_flag == true)
			sysFlags.timer_1000ms_flag = false;
			gpio_pin_toggle_dt(&leds_array[1]);
		runApplication();
		if (sysFlags.bt_adv_task == true)
			sysFlags.bt_adv_task = false;
			if(advUpdateFlag == true)
				bt_update_packet();
				gpio_pin_toggle_dt(&leds_array[2]);
void ble_write_thread(void)
	// Don't go any further until BLE is initialized
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;)
		// Wait indefinitely for data to be sent over bluetooth
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
							K_FOREVER);
		if (bt_nus_send(NULL, buf->data, buf->len)) {
			LOG_WRN("Failed to send data over BLE connection");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
# Copyright (c) 2021 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_DEVICE_NAME="Slave"      # -> SlaveXX_22476E
CONFIG_BT_DEVICE_APPEARANCE=832
CONFIG_BT_MAX_CONN=2
CONFIG_BT_MAX_PAIRED=2
CONFIG_BT_SMP=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_HRS=y
CONFIG_BT_HRS_CLIENT=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_DK_LIBRARY=y
CONFIG_SENSOR=y
# CONFIG_STDOUT_CONSOLE=y
# CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_TEMP_NRF5=y
# added for extended packet
#CONFIG_BT_EXT_ADV=y
# added for ADC
CONFIG_GPIO=y
CONFIG_ADC=y
# CONFIG_ADC_ASYNC=y
# CONFIG_CBPRINTF_FP_A_SUPPORT=y
# CONFIG_USE_SEGGER_RTT=y
# CONFIG_LOG=y
# CONFIG_LOG_BACKEND_SHOW_COLOR=y
# Enable multithreading
# CONFIG_MULTITHREADING=y
# TIMER 4
# CONFIG_NRFX_TIMER4=y
# Sensor
# CONFIG_SENSOR=y
# Enable internal oscillator
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y
# Enable MPU
# CONFIG_ARM_MPU=y
# Enable hardware stack protection
# CONFIG_HW_STACK_PROTECTION=y
# Configure GPIO as pin RESET
# CONFIG_GPIO_AS_PINRESET=y
# FLASH configuration
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
# Get MAC address
CONFIG_BT_HCI_VS_EXT=y
# ------------------------- For BLE uart -------------------------
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# This example requires more workqueue stack
# CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048       by default = 2048 (no need to include)
# Config logger
CONFIG_LOG=n    #y
CONFIG_LOG_BACKEND_RTT=n    #y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
# Enable the NUS service
CONFIG_BT_NUS=y
