Programming external custom board with nrf52832 DK
Hi all,
I have a custom board running on nrf52840. I need to flash the custom board with the NRF52832 DK. But I am running into some issues. the development is at early stages and there are too many failure points and variables. So I just need to be sure at every step what each error means.
I tried recovering using 'nrfjprog --recover' . It ave the same error. I am attaching the log of the recover operation.
One question I have is about the connection between the target board and the DK. I have not connected the VDD_nrf (pin #1 on P20) or the VDD (pin #2 on p20) since my target board is powered by an external USB source. Is it necessary that I should connect these ? i saw a lot of suggested schematics between the target and the DK but i do not know which one of these to accept. Can you recommend a connection that works ?
Thank you
  • I'm seeing a similar issue but with nRF52840 DK 3.0.0 specifically. Always happens if I try to program the target which isnt powered on. The DK just enters this broken state which can only be fixed by flashing the target with a dedicated debugger.
    Also happens when my target is battery powered for some reason. Previous DK board worked just fine, didn't have this issue.
    I've only found that it has something to do with how nrfjprog erases the memory. When the J-link reports a failed read, for example it can't check for readback protection, the erase command in nrfjprog just ignores this and tries to continue with the erasing which leads me to believe this is some bug on Nordic's side.
    Take a look at this guide for the connection.
    Sorry, the attached log is broken and I am not able to open it. Could you please specify the version of the JLink you are trying with?
    Kind Regards,
    Abhijith
  • Hi, after verifying the connections with the target board, with the help of the guide you provided, I could get rid of the issue. But now I have another issue while flashing.
    Can you explain the reason behind this ?
    When I tried to reocver the device using nrfjprog --recover, I got the same error as before. Attaching the generated log.
    [2023-Mar-10 16:16:01] [debug] --------------------------------------------------------------------------------
    [2023-Mar-10 16:16:01] [debug] nrfjprog --recover --log
    [2023-Mar-10 16:16:01] [debug] nrfjprog version 10.19.0 external
    [2023-Mar-10 16:16:01] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2023-Mar-10 16:16:01] [ info] Library loaded, loading member functions.
    [2023-Mar-10 16:16:01] [ info] Member functions succesfully loaded.
    [2023-Mar-10 16:16:01] [debug] [ Client] - open
    [2023-Mar-10 16:16:01] [debug] [ Client] - start
    [2023-Mar-10 16:16:01] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 7cf1581a-fb8c-43aa-b5ae-fb63ee446994.
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2023-Mar-10 16:16:01] [debug] [  JLink] - Logger sink registered in JLink logger
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - open
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - just_check_family
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - open_dll
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2023-Mar-10 16:16:01] [ info] [SeggerBackend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLink_x64.dll.
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command open executed for 39 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [ Client] - config
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command config executed for 6 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [ Client] - enum_emu_snr
    [2023-Mar-10 16:16:01] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2023-Mar-10 16:16:01] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Set batch mode
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - dll_version
    [2023-Mar-10 16:16:01] [ info] [SeggerBackend] - Segger dll version 7.86.c loaded.
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - config
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - enum_emu_snr
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command enum_emu_con_info executed for 4 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [ Client] - connect_to_emu_with_snr
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - enum_emu_con_info
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - enum_emu_con_info
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_get_num_emus
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Segger logging enabled.
    [2023-Mar-10 16:16:01] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01
    [2023-Mar-10 16:16:01] [trace] [  JLink] - Hardware: V1.00
    [2023-Mar-10 16:16:01] [trace] [  JLink] - S/N: 1050316948
    [2023-Mar-10 16:16:01] [trace] [  JLink] - OEM: SEGGER
    [2023-Mar-10 16:16:01] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2023-Mar-10 16:16:01] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2023-Mar-10 16:16:01] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 25.912ms returns "O.K."
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_HasError()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_Lock()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.002ms returns 0x01
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.002ms returns 0x00
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.004ms returns 0x00
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.012ms returns 0
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.731ms returns 0x00
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.010ms
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.121ms
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_GetSpeed()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.006ms returns 2000
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_GetSN()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.004ms returns 1050316948
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - read_device_family
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_IsOpen()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.005ms returns 0x01
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - read_debug_port_idr
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - read_debug_port_register
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - coresight_configure
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.248ms returns 0
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 100.468ms returns 0
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.663ms returns -1
    [2023-Mar-10 16:16:01] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.595ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 1.015ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.673ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.616ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.610ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.944ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.937ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.757ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.680ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.692ms returns -1
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command connect_to_emu_with_snr executed for 168 milliseconds with result -102
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.603ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.656ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.612ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.592ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.574ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.513ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.530ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.566ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.593ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.643ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.647ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.536ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.531ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.728ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.490ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.504ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.500ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.601ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.528ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.014ms
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 165 milliseconds with result -102
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - close
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.033ms returns 0x01
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - close
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - disconnect_from_emu
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - is_connected_to_device
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_IsConnected()
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.037ms returns FALSE
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.563ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.553ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.584ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.550ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.539ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.594ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.476ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.510ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.548ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.495ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.570ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.473ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.628ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.779ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.562ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.537ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.587ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.507ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.488ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.549ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.928ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.534ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.470ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.499ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.491ms returns -1
    [2023-Mar-10 16:16:01] [trace] [  JLink] - - 0.069ms
    [2023-Mar-10 16:16:01] [trace] [  JLink] - JLINK_Close()
    [2023-Mar-10 16:16:01] [debug] [SeggerBackend] - Segger Backend closed.
    [2023-Mar-10 16:16:01] [debug] [  nRFXX] - nRF family DLL closed
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command close executed for 56 milliseconds with result 0
    [2023-Mar-10 16:16:01] [debug] [ Client] - terminate
    [2023-Mar-10 16:16:01] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command close executed for 53 milliseconds with result 0
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2023-Mar-10 16:16:01] [trace] [ Worker] - Executed 6 commands for 229 milliseconds
    [2023-Mar-10 16:16:01] [debug] [ Client] - Worker process exited with code: 0
    [2023-Mar-10 16:16:01] [debug] [ Client] - Child process terminated with result 0
    [2023-Mar-10 16:16:01] [trace] [ Client] - Executed 6 commands for 273 milliseconds
    Jlink version is 7.86b
    Thank you
    Please see that nRF52 only supports external devices powered with 3V. Can you recheck what voltage your custom board is powered with? Is it  because of the hardware, do you have any schematics or layout files for checking or reviewing.
    Kind Regards,
    Abhijith
  • Hi, I figured out the problem. The connections were right but there was a loose contact between the P20 on the DK and my custom board. Sorry for the mess here.
    Thank you.
