NRF52832 interface with MCP2515
I am currently working on adding a CANBUS line to a Bluetooth application that uses the NRF52832. I have successfully initialized the CANBUS controller as well as the SPI lines. I am unable to send or receive any data to or from the connected CANBUS. I am not getting any errors when using nrf_drv_spi_transfer function, so it does not seem like the spi bus has an issue. Here is my set up for the spi bus.
void mcp_spi_init()
    uint32_t err_code = NRF_SUCCESS;
    nrf_drv_gpiote_in_config_t mcp2515_int_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    mcp2515_int_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(MCP2515_PIN_INT, &mcp2515_int_config, mcp2515_int_pin_handler);
    nrf_drv_gpiote_in_event_enable(MCP2515_PIN_INT, true);
    mcp_can_setcs(SPI_SS_PIN);
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.frequency = NRF_DRV_SPI_FREQ_250K;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    err_code = nrf_drv_spi_init(&can_spi, &spi_config, spi_can_event_handler, NULL);
    #if MCP2515_DEBUG_MODE
        NRF_LOG_INFO("mcp_spi_init complete");
Following this I initialize my CANBUS controller.
static void can_init(void)
    NRF_LOG_DEBUG("CAN Initialization...");
    mcp_spi_init();
    NRF_LOG_INFO("MCP2515 SPI Initialized");
    START_INIT:
    if(mcp_can_begin(CAN_500KBPS, MCP_16MHz) == CAN_OK)
	NRF_LOG_INFO("CAN BUS Initialization ok");
	NRF_LOG_DEBUG("CAN BUS Initialization failed");
        NRF_LOG_DEBUG("Init CAN BUS again");
        nrf_delay_ms(1000);
        goto START_INIT;
    NRF_LOG_DEBUG("CAN Initialization COMPLETED.");
I reach success messages for both, so they seem okay. I now try to read data and nothing is received ever. I have attached it to a working CANBUS line sending messages with extended ID's of 0xFFa1,0xFFa2,0xFFA3,0xFFA4.
 // Enter main loop.
    for (;;)
            uint8_t buf[8] = {0x02, 0x01, 0x00, 0, 0, 0, 0, 0};
	    uint32_t can_id;
	    uint8_t len = 0;
            int count=0;
		while(count<4000)
			if(CAN_MSGAVAIL == mcp_can_check_receive())
				mcp_can_read_msg(&can_id, &len, buf);
				SEGGER_RTT_printf(0, "Can id is: %x\t Can data length is: %u", can_id, len);
			++count;
       // app_sched_execute(); // pop any tasks/processess off the scheduler que
        //idle_state_handle(); // NOTE: this will never get hit because scheduler is always looping our app State machine
I will attach my mcp files as well. I am at a stand still and have tried just about everything to get this up working to send and receive. Any help in the meantime would be great. This app uses BLE as well FYI.
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "app_error.h"
#include "nrf_drv_spi.h"
#include "bsp.h"
#include "app_timer.h"
#include "nordic_common.h"
#include "mcp_can.h"
#include "mem_manager.h"
#include "nrf_sdh.h"
#include "nrf_drv_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
static volatile bool spi_xfer_done = true;
mcp_can_t m_mcp_can;
#define SPI_CAN_INSTANCE  0                                                   /**< SPI instance index. */
static const nrf_drv_spi_t can_spi = NRF_DRV_SPI_INSTANCE(SPI_CAN_INSTANCE);  /**< SPI instance. */
/**@brief Function for handling MCP2515 INT Pin events.
 * @param[in]
void mcp2515_int_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    if (nrf_gpio_pin_read(pin))
        nrf_gpio_pin_set(BSP_LED_3);
            NRF_LOG_INFO("mcp2515_int_pin_handler State: LO To HI");
        nrf_gpio_pin_clear(BSP_LED_3);
            NRF_LOG_INFO("mcp2515_int_pin_handler State: HI To LO");
void spi_can_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
    switch(p_event->type)
	case NRF_DRV_SPI_EVENT_DONE:
               NRF_LOG_INFO("SPI transfer complete");
            nrf_delay_ms(50);
void mcp_spi_init()
void mcp2515_select()
    nrf_gpio_pin_clear(SPI_SS_PIN);
void mcp2515_unselect()
    nrf_gpio_pin_set(SPI_SS_PIN);
void mcp2515_reset()
    mcp2515_select();
    uint8_t m_tx_buf[1] = {MCP_RESET};
    uint8_t m_length = sizeof(m_tx_buf);
    spi_xfer_done = false;
     ret_code_t err_code;
    err_code = nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_length, NULL, 0);
    while (!spi_xfer_done)
        if (nrf_sdh_is_enabled())
            sd_app_evt_wait();
            __WFE();
    mcp2515_unselect();
uint8_t mcp2515_readRegister(const uint8_t address)
    mcp2515_select();
    uint8_t m_tx_buf[] = {MCP_READ, address};
    uint8_t m_tx_length = sizeof(m_tx_buf);
    uint8_t m_rx_buf[3];
    uint8_t m_rx_length = sizeof(m_rx_buf);
    memset(m_rx_buf, 0, m_rx_length);
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_tx_length, m_rx_buf, m_rx_length));
            sd_app_evt_wait();
            __WFE();
    mcp2515_unselect();
    return m_rx_buf[2];
void  mcp2515_readRegisterS(const uint8_t address, uint8_t values[], const uint8_t n)
    uint8_t i;
    mcp2515_select();
    uint8_t m_rx_buf[n+2];
            sd_app_evt_wait();
            __WFE();
    for (i=0; i<n && i<CAN_MAX_CHAR_IN_MESSAGE-2; i++)
        values[i] = m_rx_buf[i+2];
    mcp2515_unselect();
    return;
void  mcp2515_setRegister(const uint8_t address, const uint8_t value)
    mcp2515_select();
    uint8_t m_tx_buf[3] = {MCP_WRITE, address, value};
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_length, NULL, 0));
            sd_app_evt_wait();
            __WFE();
    mcp2515_unselect();
void mcp2515_setRegisterS(const uint8_t address, const uint8_t values[], const uint8_t n)
    mcp2515_select();
    uint8_t tx_buf[2] = {MCP_WRITE, address};
    uint8_t m_tx_length = 2+n * sizeof(uint8_t);
    uint8_t* m_tx_buf = nrf_malloc(2+n * sizeof(uint8_t));
    memcpy(m_tx_buf, tx_buf, 2 * sizeof(uint8_t));                  //copy 2 uint8_t from tx_buf to m_tx_buf
    memcpy(m_tx_buf + 2, values, n * sizeof(uint8_t));              //copy n uint8_t from values to m_tx_buf
    err_code = (nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_tx_length, NULL, 0));
            sd_app_evt_wait();
            __WFE();
    nrf_free(m_tx_buf);
    mcp2515_unselect();
void  mcp2515_modifyRegister(const uint8_t address, const uint8_t mask, const uint8_t data)
    mcp2515_select();
    uint8_t m_tx_buf[4] = {MCP_BITMOD, address, mask, data};
            sd_app_evt_wait();
            __WFE();
    mcp2515_unselect();
uint8_t  mcp2515_readStatus(void)
    mcp2515_select();
    uint8_t m_tx_buf[2] = {MCP_READ_STATUS, 0x00};
    uint8_t m_rx_buf[2];
    memset(m_rx_buf, 0, m_length);
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_length, m_rx_buf, m_length));
            sd_app_evt_wait();
            __WFE();
    mcp2515_unselect();
    return m_rx_buf[1];
uint8_t  mcp2515_setCANCTRL_Mode(const uint8_t newmode)
    uint8_t i;
        NRF_LOG_INFO("Modifying MCP_CANCTRL");
    mcp2515_modifyRegister(MCP_CANCTRL, MODE_MASK, newmode);
    nrf_delay_ms(10);
        NRF_LOG_INFO("Done Modifying MCP_CANCTRL");
        NRF_LOG_INFO("Reading MCP_CANCTRL");
    i = mcp2515_readRegister(MCP_CANCTRL);
    nrf_delay_ms(10);
        NRF_LOG_INFO("Done reading MCP_CANCTRL");
    i &= MODE_MASK;
    if ( i == newmode )
        return MCP2515_OK;
    return MCP2515_FAIL;
uint8_t  mcp2515_configRate(const uint8_t canSpeed, const uint8_t clock)
    uint8_t set, cfg1, cfg2, cfg3;
    set = 1;
    switch (clock)
        case (MCP_16MHz):
            switch (canSpeed)
                case (CAN_5KBPS):
                    cfg1 = MCP_16MHz_5kBPS_CFG1;
                    cfg2 = MCP_16MHz_5kBPS_CFG2;
                    cfg3 = MCP_16MHz_5kBPS_CFG3;
                case (CAN_10KBPS):
                    cfg1 = MCP_16MHz_10kBPS_CFG1;
                    cfg2 = MCP_16MHz_10kBPS_CFG2;
                    cfg3 = MCP_16MHz_10kBPS_CFG3;
                case (CAN_20KBPS):
                    cfg1 = MCP_16MHz_20kBPS_CFG1;
                    cfg2 = MCP_16MHz_20kBPS_CFG2;
                    cfg3 = MCP_16MHz_20kBPS_CFG3;
                case (CAN_31K25BPS):
                    cfg1 = MCP_16MHz_31k25BPS_CFG1;
                    cfg2 = MCP_16MHz_31k25BPS_CFG2;
                    cfg3 = MCP_16MHz_31k25BPS_CFG3;
                case (CAN_40KBPS):
                    cfg1 = MCP_16MHz_40kBPS_CFG1;
                    cfg2 = MCP_16MHz_40kBPS_CFG2;
                    cfg3 = MCP_16MHz_40kBPS_CFG3;
                case (CAN_50KBPS):
                    cfg1 = MCP_16MHz_50kBPS_CFG1;
                    cfg2 = MCP_16MHz_50kBPS_CFG2;
                    cfg3 = MCP_16MHz_50kBPS_CFG3;
                case (CAN_80KBPS):
                    cfg1 = MCP_16MHz_80kBPS_CFG1;
                    cfg2 = MCP_16MHz_80kBPS_CFG2;
                    cfg3 = MCP_16MHz_80kBPS_CFG3;
                case (CAN_100KBPS):                                             /* 100KBPS                  */
                    cfg1 = MCP_16MHz_100kBPS_CFG1;
                    cfg2 = MCP_16MHz_100kBPS_CFG2;
                    cfg3 = MCP_16MHz_100kBPS_CFG3;
                case (CAN_125KBPS):
                    cfg1 = MCP_16MHz_125kBPS_CFG1;
                    cfg2 = MCP_16MHz_125kBPS_CFG2;
                    cfg3 = MCP_16MHz_125kBPS_CFG3;
                case (CAN_200KBPS):
                    cfg1 = MCP_16MHz_200kBPS_CFG1;
                    cfg2 = MCP_16MHz_200kBPS_CFG2;
                    cfg3 = MCP_16MHz_200kBPS_CFG3;
                case (CAN_250KBPS):
                    cfg1 = MCP_16MHz_250kBPS_CFG1;
                    cfg2 = MCP_16MHz_250kBPS_CFG2;
                    cfg3 = MCP_16MHz_250kBPS_CFG3;
                case (CAN_500KBPS):
                    cfg1 = MCP_16MHz_500kBPS_CFG1;
                    cfg2 = MCP_16MHz_500kBPS_CFG2;
                    cfg3 = MCP_16MHz_500kBPS_CFG3;
                case (CAN_1000KBPS):
                    cfg1 = MCP_16MHz_1000kBPS_CFG1;
                    cfg2 = MCP_16MHz_1000kBPS_CFG2;
                    cfg3 = MCP_16MHz_1000kBPS_CFG3;
                    set = 0;
        case (MCP_8MHz):
            switch (canSpeed)
                case (CAN_5KBPS):
                    cfg1 = MCP_8MHz_5kBPS_CFG1;
                    cfg2 = MCP_8MHz_5kBPS_CFG2;
                    cfg3 = MCP_8MHz_5kBPS_CFG3;
                case (CAN_10KBPS):
                    cfg1 = MCP_8MHz_10kBPS_CFG1;
                    cfg2 = MCP_8MHz_10kBPS_CFG2;
                    cfg3 = MCP_8MHz_10kBPS_CFG3;
                case (CAN_20KBPS):
                    cfg1 = MCP_8MHz_20kBPS_CFG1;
                    cfg2 = MCP_8MHz_20kBPS_CFG2;
                    cfg3 = MCP_8MHz_20kBPS_CFG3;
                    cfg1 = MCP_8MHz_31k25BPS_CFG1;
                    cfg2 = MCP_8MHz_31k25BPS_CFG2;
                    cfg3 = MCP_8MHz_31k25BPS_CFG3;
                case (CAN_40KBPS):
                    cfg1 = MCP_8MHz_40kBPS_CFG1;
                    cfg2 = MCP_8MHz_40kBPS_CFG2;
                    cfg3 = MCP_8MHz_40kBPS_CFG3;
                case (CAN_50KBPS):
                    cfg1 = MCP_8MHz_50kBPS_CFG1;
                    cfg2 = MCP_8MHz_50kBPS_CFG2;
                    cfg3 = MCP_8MHz_50kBPS_CFG3;
                case (CAN_80KBPS):
                    cfg1 = MCP_8MHz_80kBPS_CFG1;
                    cfg2 = MCP_8MHz_80kBPS_CFG2;
                    cfg3 = MCP_8MHz_80kBPS_CFG3;
                    cfg1 = MCP_8MHz_100kBPS_CFG1;
                    cfg2 = MCP_8MHz_100kBPS_CFG2;
                    cfg3 = MCP_8MHz_100kBPS_CFG3;
                case (CAN_125KBPS):
                    cfg1 = MCP_8MHz_125kBPS_CFG1;
                    cfg2 = MCP_8MHz_125kBPS_CFG2;
                    cfg3 = MCP_8MHz_125kBPS_CFG3;
                case (CAN_200KBPS):
                    cfg1 = MCP_8MHz_200kBPS_CFG1;
                    cfg2 = MCP_8MHz_200kBPS_CFG2;
                    cfg3 = MCP_8MHz_200kBPS_CFG3;
                case (CAN_250KBPS):
                    cfg1 = MCP_8MHz_250kBPS_CFG1;
                    cfg2 = MCP_8MHz_250kBPS_CFG2;
                    cfg3 = MCP_8MHz_250kBPS_CFG3;
                case (CAN_500KBPS):
                    cfg1 = MCP_8MHz_500kBPS_CFG1;
                    cfg2 = MCP_8MHz_500kBPS_CFG2;
                    cfg3 = MCP_8MHz_500kBPS_CFG3;
                    cfg1 = MCP_8MHz_1000kBPS_CFG1;
                    cfg2 = MCP_8MHz_1000kBPS_CFG2;
                    cfg3 = MCP_8MHz_1000kBPS_CFG3;
                    set = 0;
            set = 0;
    if (set)
        mcp2515_setRegister(MCP_CNF1, cfg1);
        mcp2515_setRegister(MCP_CNF2, cfg2);
        mcp2515_setRegister(MCP_CNF3, cfg3);
        return MCP2515_OK;
void  mcp2515_initCANBuffers(void)
    uint8_t i, a1, a2, a3;
    a1 = MCP_TXB0CTRL;
    a2 = MCP_TXB1CTRL;
    a3 = MCP_TXB2CTRL;
    for (i = 0; i < 14; i++)                                              /* in-buffer loop               */
        mcp2515_setRegister(a1, 0);
        mcp2515_setRegister(a2, 0);
        mcp2515_setRegister(a3, 0);
        a1++;
        a2++;
        a3++;
    mcp2515_setRegister(MCP_RXB0CTRL, 0);
    mcp2515_setRegister(MCP_RXB1CTRL, 0);
uint8_t  mcp2515_init(const uint8_t canSpeed, const uint8_t clock)                       /* mcp2515init                  */
        NRF_LOG_INFO("Entering mcp2515_ini");
    uint8_t res;
    mcp2515_reset();
    nrf_delay_ms(10);
        NRF_LOG_INFO("Entering CANCTRL Mode");
    //res = mcp2515_setCANCTRL_Mode(MODE_CONFIG);
    if(res > 0)
            NRF_LOG_DEBUG("Enter Setting Mode Fail!!!");
        #else
            nrf_delay_ms(10);
        return res;
        NRF_LOG_INFO("Enter Setting Mode Success");
    #else
        nrf_delay_ms(10);
    /* set baudrate                 */
    if(mcp2515_configRate(canSpeed, clock))
            NRF_LOG_INFO("Set Rate Fail!!!");
        #else
            nrf_delay_ms(10);
        return res;
        NRF_LOG_INFO("Set Rate Success");
    #else
        nrf_delay_ms(10);
    if ( res == MCP2515_OK )
        mcp2515_initCANBuffers();                                       /* init canbuffers              */
        mcp2515_setRegister(MCP_CANINTE, MCP_RX0IF | MCP_RX1IF);        /* interrupt mode               */
        uint8_t result =mcp2515_readRegister(MCP_CANINTE);
        #if (INFO_RXANY == 1)
            mcp2515_modifyRegister(MCP_RXB0CTRL, MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK, MCP_RXB_RX_ANY | MCP_RXB_BUKT_MASK);      /* enable both receive-buffers to receive any message and enable rollover */
            mcp2515_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK, MCP_RXB_RX_ANY);
        #else
            mcp2515_modifyRegister(MCP_RXB0CTRL, MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK, MCP_RXB_RX_STDEXT | MCP_RXB_BUKT_MASK );  /* enable both receive-buffers to receive messages with std. and ext. identifiers and enable rollover */
            mcp2515_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK, MCP_RXB_RX_STDEXT);
        res = mcp2515_setCANCTRL_Mode(MODE_NORMAL);                     /* enter normal mode            */
        if(res)
                NRF_LOG_INFO("Enter Normal Mode Fail!!!");
            #else
                nrf_delay_ms(10);
            return res;
            NRF_LOG_INFO("Enter Normal Mode Success");
        #else
            nrf_delay_ms(10);
    return res;
void  mcp2515_write_id( const uint8_t mcp_addr, const uint8_t ext, const uint32_t id )
    uint16_t canid;
    uint8_t tbufdata[4];
    canid = (uint16_t)(id & 0x0FFFF);
    if ( ext == 1)
        tbufdata[MCP_EID0] = (uint8_t) (canid & 0xFF);
        tbufdata[MCP_EID8] = (uint8_t) (canid >> 8);
        canid = (uint16_t)(id >> 16);
        tbufdata[MCP_SIDL] = (uint8_t) (canid & 0x03);
        tbufdata[MCP_SIDL] += (uint8_t) ((canid & 0x1C) << 3);
        tbufdata[MCP_SIDL] |= MCP_TXB_EXIDE_M;
        tbufdata[MCP_SIDH] = (uint8_t) (canid >> 5 );
        tbufdata[MCP_SIDH] = (uint8_t) (canid >> 3 );
        tbufdata[MCP_SIDL] = (uint8_t) ((canid & 0x07 ) << 5);
        tbufdata[MCP_EID0] = 0;
        tbufdata[MCP_EID8] = 0;
    mcp2515_setRegisterS( mcp_addr, tbufdata, 4 );
void  mcp2515_read_id( const uint8_t mcp_addr, uint8_t* ext, uint32_t* id )
    *ext = 0;
    *id = 0;
    mcp2515_readRegisterS( mcp_addr, tbufdata, 4 );
    *id = (tbufdata[MCP_SIDH]<<3) + (tbufdata[MCP_SIDL]>>5);
    if ( (tbufdata[MCP_SIDL] & MCP_TXB_EXIDE_M) ==  MCP_TXB_EXIDE_M )       /* extended id                  */
        *id = (*id<<2) + (tbufdata[MCP_SIDL] & 0x03);
        *id = (*id<<8) + tbufdata[MCP_EID8];
        *id = (*id<<8) + tbufdata[MCP_EID0];
        *ext = 1;
void  mcp2515_write_canMsg( const uint8_t buffer_sidh_addr )
    uint8_t mcp_addr;
    mcp_addr = buffer_sidh_addr;
    mcp2515_setRegisterS((mcp_addr+5), m_mcp_can.m_data, m_mcp_can.m_len );     /* write data bytes             */
    mcp2515_setRegister((mcp_addr+4), m_mcp_can.m_len );                        /* write the RTR and DLC        */
    mcp2515_write_id(mcp_addr, m_mcp_can.m_ext_flag, m_mcp_can.m_id );          /* write CAN id                 */
void  mcp2515_read_canMsg( const uint8_t buffer_sidh_addr )                     /* read can msg                 */
    uint8_t mcp_addr, ctrl;
    mcp2515_read_id( mcp_addr, &m_mcp_can.m_ext_flag, &m_mcp_can.m_id );
    ctrl = mcp2515_readRegister( mcp_addr-1 );
    m_mcp_can.m_len = mcp2515_readRegister( mcp_addr+4 );
    m_mcp_can.m_len &= MCP_DLC_MASK;
    mcp2515_readRegisterS( mcp_addr+5, &(m_mcp_can.m_data[0]), m_mcp_can.m_len );
void  mcp2515_start_transmit( const uint8_t mcp_addr )                          /* start transmit               */
    mcp2515_modifyRegister( mcp_addr-1 , MCP_TXB_TXREQ_M, MCP_TXB_TXREQ_M );
uint8_t  mcp2515_getNextFreeTXBuf( uint8_t *txbuf_n )                           /* get Next free txbuf          */
    uint8_t res, i, ctrlval;
    uint8_t ctrlregs[MCP_N_TXBUFFERS] = { MCP_TXB0CTRL, MCP_TXB1CTRL, MCP_TXB2CTRL };
    res = MCP_ALLTXBUSY;
    *txbuf_n = 0x00;
    for (i=0; i<MCP_N_TXBUFFERS; i++)                                           /* check all 3 TX-Buffers       */
        ctrlval = mcp2515_readRegister( ctrlregs[i] );
        if ( (ctrlval & MCP_TXB_TXREQ_M) == 0 )
            *txbuf_n = ctrlregs[i]+1;                                           /* return SIDH-address of Buffer */
            res = MCP2515_OK;
            return res;                                                         /* ! function exit              */
    return res;
uint8_t  setMsg( uint32_t id, uint8_t ext, uint8_t len, uint8_t *pData )
    int i = 0;
    m_mcp_can.m_ext_flag = ext;
    m_mcp_can.m_id = id;
    m_mcp_can.m_len = len;
    for(i = 0; i<MAX_CHAR_IN_MESSAGE; i++)
        m_mcp_can.m_data[i] = *(pData+i);
    return MCP2515_OK;
uint8_t  clearMsg()
    for(int i = 0; i<m_mcp_can.m_len; i++)
        m_mcp_can.m_data[i] = 0x00;
    m_mcp_can.m_id = 0;
    m_mcp_can.m_len = 0;
    m_mcp_can.m_ext_flag = 0;
    return MCP2515_OK;
uint8_t  sendMsg()
    uint8_t res, res1, txbuf_n;
    uint16_t uiTimeOut = 0;
    do
        res = mcp2515_getNextFreeTXBuf(&txbuf_n);                       /* info = addr. */
        uiTimeOut++;
    } while (res == MCP_ALLTXBUSY && (uiTimeOut < TIMEOUTVALUE));
    if(uiTimeOut == TIMEOUTVALUE)
        return CAN_GETTXBFTIMEOUT;                                      /* get tx buff time out */
    uiTimeOut = 0;
    mcp2515_write_canMsg( txbuf_n);
    mcp2515_start_transmit( txbuf_n );
    do
        uiTimeOut++;
        res1= mcp2515_readRegister(txbuf_n-1);                           /* the ctrl reg is located at txbuf_n-1 read send buff ctrl reg */
        res1 = res1 & 0x08;
    } while(res1 && (uiTimeOut < TIMEOUTVALUE));
    if(uiTimeOut == TIMEOUTVALUE)                                        /* send msg timeout */
        return CAN_SENDMSGTIMEOUT;
    return CAN_OK;
uint8_t  readMsg()
    uint8_t stat, res;
    stat = mcp2515_readStatus();
    if ( stat & MCP_STAT_RX0IF )                                        /* Msg in Buffer 0 */
        mcp2515_read_canMsg( MCP_RXBUF_0);
        mcp2515_modifyRegister(MCP_CANINTF, MCP_RX0IF, 0);
        res = CAN_OK;
    else if ( stat & MCP_STAT_RX1IF )                                   /* Msg in Buffer 1 */
        mcp2515_read_canMsg( MCP_RXBUF_1);
        mcp2515_modifyRegister(MCP_CANINTF, MCP_RX1IF, 0);
        res = CAN_OK;
        res = CAN_NOMSG;
    return res;
void  mcp_can_setcs( uint8_t cs )
    nrf_gpio_cfg_output(SPI_SS_PIN);
    mcp2515_unselect();
uint8_t  mcp_can_begin( uint8_t speedset, const uint8_t clockset )
    uint8_t res;
    res = mcp2515_init(speedset, clockset);
        NRF_LOG_INFO("MCP2515 Speed init done");
    if (res == MCP2515_OK)
        mcp2515_setRegister(MCP_RXB0CTRL, 0x60);
        mcp2515_setRegister(MCP_RXB1CTRL, 0x60);
        return CAN_OK;
        return CAN_FAILINIT;
uint8_t  mcp_can_send_msg( uint32_t id, uint8_t ext, uint8_t len, uint8_t *buf )
    uint8_t res = 1;
    res = setMsg(id, ext, len, buf);
    return sendMsg();
uint8_t  mcp_can_read_msg( uint32_t *ID, uint8_t *len, uint8_t buf[] )
    uint8_t rc;
    rc = readMsg();
    if (rc == CAN_OK)
        *len = m_mcp_can.m_len;
        *ID = m_mcp_can.m_id;
        for(int i = 0; i<m_mcp_can.m_len && i < MAX_CHAR_IN_MESSAGE; i++)
            buf[i] = m_mcp_can.m_data[i];
       *len = 0;
    return rc;
uint8_t  mcp_can_check_receive(void)
    uint8_t res;
    res = mcp2515_readStatus();                                         /* RXnIF in Bit 1 and 0 */
    if ( res & MCP_STAT_RXIF_MASK )
        return CAN_MSGAVAIL;
        return CAN_NOMSG;
uint8_t  mcp_can_check_error(void)
    uint8_t eflg = mcp2515_readRegister(MCP_EFLG);
    if ( eflg & MCP_EFLG_ERRORMASK )
        return CAN_CTRLERROR;
        return CAN_OK;
0815.mcp_can.h
