I have been using the SPI manager to share the same SPI bus between several devices. (high speed ADC and NAND flash) The ADC sample rate is 260 samples per second. When a sample is ready, a GPIO line is toggled which generates an interrupt. The IRQ handler then sets up a SPI manager transaction.
It appears that some samples may be dropped so I would like to use PPI to trigger the SPI transfer in hardware. Is it possible to continue using the SPI manager with the other peripherals? The other peripherals require variable size transfers. How do I share the SPI bus while using PPI to implement high priority transfers?
Thanks
