i downloaded the ncsV2.3.0 by Toolchain manager!
and then i try to build the path("E:\ncs\v2.3.0\nrf\samples\matter\light_bulb")
this is about build configuration.
this error occurred during the build.
could you please tell me what wrong during the build process.
i will show you the log all about the build process in the end.
nRF Connect: Build: my_light_bulb/my_light_bulb/build/multiprotocol_rpmsg (active)
Building multiprotocol_rpmsg
west build --build-dir e:\myApps\my_light_bulb\build\multiprotocol_rpmsg e:\ncs\v2.3.0\nrf\samples\nrf5340\multiprotocol_rpmsg
[0/304] Generating signing key
[5/304] No configure step for 'b0n_subimage'
[6/304] Performing build step for 'b0n_subimage'
[1/161] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (E:/ncs/v2.3.0/zephyr), build: v3.2.99-ncs2
[2/161] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/161] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/161] Generating include/generated/driver-validation.h
[5/161] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[6/161] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/161] Generating include/generated/offsets.h
[8/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[9/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[10/161] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[11/161] Generating linker_zephyr_pre0.cmd
FAILED: zephyr/linker_zephyr_pre0.cmd
cmd.exe /C "cd /D E:\Myapps\my_light_bulb\build\multiprotocol_rpmsg\b0n\zephyr && E:\ncs\toolchains\v2.3.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -x assembler-with-cpp -undef -MD -MF linker_zephyr_pre0.cmd.dep -MT linker_zephyr_pre0.cmd -D_LINKER -D_ASMLANGUAGE -imacros E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n/zephyr/include/generated/autoconf.h -IE:/ncs/v2.3.0/zephyr/include -IE:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n/zephyr/include/generated -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53 -IE:/ncs/v2.3.0/zephyr/lib/libc/minimal/include -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/common/. -IE:/ncs/v2.3.0/nrf/include -IE:/ncs/v2.3.0/nrf/subsys/bootloader/include -IE:/ncs/v2.3.0/nrf/tests/include -IE:/ncs/v2.3.0/modules/hal/cmsis/CMSIS/Core/Include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/mdk -IE:/ncs/v2.3.0/zephyr/modules/hal_nordic/nrfx/. -D__GCC_LINKER_CMD__ -DUSE_PARTITION_MANAGER=1 -DLINKER_DEVICE_HANDLES_PASS1 -E E:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53/linker.ld -P -o linker_zephyr_pre0.cmd && E:\ncs\toolchains\v2.3.0\opt\bin\cmake.exe -E cmake_transform_depfile Ninja gccdepfile E:/ncs/v2.3.0/nrf/samples/nrf5340/netboot E:/ncs/v2.3.0/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n/zephyr/linker_zephyr_pre0.cmd.dep E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/b0n/CMakeFiles/d/7134b2a2c98112d0602c5d7310305b4ee9d01af7e6fde9a6b39830796797eb7a.d"
In file included from E:\ncs\v2.3.0\zephyr\soc\arm\nordic_nrf\nrf53\linker.ld:9:
E:\ncs\v2.3.0\zephyr\include\zephyr\arch\arm\aarch32\cortex_m\scripts\linker.ld:31:10: fatal error: pm_config.h: No such file or directory
31 | #include <pm_config.h>
compilation terminated.
[12/161] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[13/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[14/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[15/161] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[16/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[17/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[18/161] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[19/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[20/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[21/161] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[22/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[23/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[24/161] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[7/304] Generating include/generated/version.h
[15/304] Building C object zephyr/CMakeFiles/zephyr.dir/E_/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/E_/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
E:\ncs\toolchains\v2.3.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DNRF5340_XXAA_NETWORK -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ECB_PRIORITY=-1 -DNRF_802154_ENCRYPTION_ENABLED=1 -DNRF_802154_IE_WRITER_ENABLED=1 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_WRITER_ENABLED=1 -DNRF_802154_SWI_PRIORITY=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,79106 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,79106 -D__PROGRAM_START -D__ZEPHYR__=1 -IE:/ncs/v2.3.0/zephyr/kernel/include -IE:/ncs/v2.3.0/zephyr/arch/arm/include -IE:/ncs/v2.3.0/nrf/drivers/mpsl/clock_control -IE:/ncs/v2.3.0/zephyr/include -Izephyr/include/generated -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53 -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/common/. -IE:/ncs/v2.3.0/zephyr/subsys/bluetooth -IE:/ncs/v2.3.0/nrf/include -IE:/ncs/v2.3.0/nrf/lib/multithreading_lock/. -IE:/ncs/v2.3.0/nrf/subsys/bluetooth/controller/. -IE:/ncs/v2.3.0/nrf/tests/include -IE:/ncs/v2.3.0/modules/hal/cmsis/CMSIS/Core/Include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/mdk -IE:/ncs/v2.3.0/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IE:/ncs/v2.3.0/modules/lib/open-amp/open-amp/lib/include -IE:/ncs/v2.3.0/modules/crypto/tinycrypt/lib/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include/protocol -IE:/ncs/v2.3.0/nrfxlib/softdevice_controller/include -IE:/ncs/v2.3.0/nrfxlib/nrf_802154/driver/include -IE:/ncs/v2.3.0/nrfxlib/nrf_802154/sl/include -IE:/ncs/v2.3.0/nrfxlib/nrf_802154/serialization/include -IE:/ncs/v2.3.0/nrfxlib/nrf_802154/serialization/include/platform -IE:/ncs/v2.3.0/nrfxlib/nrf_802154/serialization/include/serialization -isystem E:/ncs/v2.3.0/zephyr/lib/libc/minimal/include -isystem e:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem e:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -fno-strict-aliasing -Os -imacros E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=E:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros E:/ncs/v2.3.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=E:/ncs/v2.3.0/nrf/samples/nrf5340/multiprotocol_rpmsg=CMAKE_SOURCE_DIR -fmacro-prefix-map=E:/ncs/v2.3.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=E:/ncs/v2.3.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir/E_/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj -MF zephyr\CMakeFiles\zephyr.dir\E_\ncs\v2.3.0\nrf\subsys\partition_manager\flash_map_partition_manager.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/E_/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj -c E:/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c
In file included from E:\ncs\v2.3.0\zephyr\include\zephyr\storage\flash_map.h:261,
from E:\ncs\v2.3.0\nrf\subsys\partition_manager\flash_map_partition_manager.c:6:
E:\ncs\v2.3.0\nrf\include\flash_map_pm.h:10:10: fatal error: pm_config.h: No such file or directory
10 | #include <pm_config.h>
[22/304] Generating linker_zephyr_pre0.cmd
cmd.exe /C "cd /D E:\Myapps\my_light_bulb\build\multiprotocol_rpmsg\zephyr && E:\ncs\toolchains\v2.3.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -x assembler-with-cpp -undef -MD -MF linker_zephyr_pre0.cmd.dep -MT linker_zephyr_pre0.cmd -D_LINKER -D_ASMLANGUAGE -imacros E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/include/generated/autoconf.h -IE:/ncs/v2.3.0/nrf/drivers/mpsl/clock_control -IE:/ncs/v2.3.0/zephyr/include -IE:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/include/generated -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53 -IE:/ncs/v2.3.0/zephyr/lib/libc/minimal/include -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/common/. -IE:/ncs/v2.3.0/zephyr/subsys/bluetooth -IE:/ncs/v2.3.0/nrf/include -IE:/ncs/v2.3.0/nrf/lib/multithreading_lock/. -IE:/ncs/v2.3.0/nrf/subsys/bluetooth/controller/. -IE:/ncs/v2.3.0/nrf/tests/include -IE:/ncs/v2.3.0/modules/hal/cmsis/CMSIS/Core/Include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/mdk -IE:/ncs/v2.3.0/zephyr/modules/hal_nordic/nrfx/. -IE:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/modules/libmetal/libmetal/lib/include -IE:/ncs/v2.3.0/modules/lib/open-amp/open-amp/lib/include -IE:/ncs/v2.3.0/modules/crypto/tinycrypt/lib/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include/protocol -D__GCC_LINKER_CMD__ -DUSE_PARTITION_MANAGER=1 -DLINKER_DEVICE_HANDLES_PASS1 -E E:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53/linker.ld -P -o linker_zephyr_pre0.cmd && E:\ncs\toolchains\v2.3.0\opt\bin\cmake.exe -E cmake_transform_depfile Ninja gccdepfile E:/ncs/v2.3.0/nrf/samples/nrf5340/multiprotocol_rpmsg E:/ncs/v2.3.0/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/linker_zephyr_pre0.cmd.dep E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/CMakeFiles/d/c90b92cc8c1fa1ed0d9e9a842faa318520f6969da9a611d29abc5716a3db3910.d"
[23/304] Generating linker_zephyr_pre1.cmd
FAILED: zephyr/linker_zephyr_pre1.cmd
cmd.exe /C "cd /D E:\Myapps\my_light_bulb\build\multiprotocol_rpmsg\zephyr && E:\ncs\toolchains\v2.3.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -x assembler-with-cpp -undef -MD -MF linker_zephyr_pre1.cmd.dep -MT linker_zephyr_pre1.cmd -D_LINKER -D_ASMLANGUAGE -imacros E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/include/generated/autoconf.h -IE:/ncs/v2.3.0/nrf/drivers/mpsl/clock_control -IE:/ncs/v2.3.0/zephyr/include -IE:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/include/generated -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53 -IE:/ncs/v2.3.0/zephyr/lib/libc/minimal/include -IE:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/common/. -IE:/ncs/v2.3.0/zephyr/subsys/bluetooth -IE:/ncs/v2.3.0/nrf/include -IE:/ncs/v2.3.0/nrf/lib/multithreading_lock/. -IE:/ncs/v2.3.0/nrf/subsys/bluetooth/controller/. -IE:/ncs/v2.3.0/nrf/tests/include -IE:/ncs/v2.3.0/modules/hal/cmsis/CMSIS/Core/Include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/include -IE:/ncs/v2.3.0/modules/hal/nordic/nrfx/mdk -IE:/ncs/v2.3.0/zephyr/modules/hal_nordic/nrfx/. -IE:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/modules/libmetal/libmetal/lib/include -IE:/ncs/v2.3.0/modules/lib/open-amp/open-amp/lib/include -IE:/ncs/v2.3.0/modules/crypto/tinycrypt/lib/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include -IE:/ncs/v2.3.0/nrfxlib/mpsl/include/protocol -D__GCC_LINKER_CMD__ -DUSE_PARTITION_MANAGER=1 -DLINKER_ZEPHYR_PREBUILT -E E:/ncs/v2.3.0/zephyr/soc/arm/nordic_nrf/nrf53/linker.ld -P -o linker_zephyr_pre1.cmd && E:\ncs\toolchains\v2.3.0\opt\bin\cmake.exe -E cmake_transform_depfile Ninja gccdepfile E:/ncs/v2.3.0/nrf/samples/nrf5340/multiprotocol_rpmsg E:/ncs/v2.3.0/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/zephyr/linker_zephyr_pre1.cmd.dep E:/Myapps/my_light_bulb/build/multiprotocol_rpmsg/CMakeFiles/d/700bd9bee77a77735f7734786cdc20edd8f65018cc2a6abbeaea3ed455f517d6.d"
[27/304] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
FAILED: modules/nrf/samples/b0n_subimage-prefix/src/b0n_subimage-stamp/b0n_subimage-build b0n/zephyr/zephyr.hex b0n/zephyr/zephyr.elf
cmd.exe /C "cd /D E:\Myapps\my_light_bulb\build\multiprotocol_rpmsg\b0n && E:\ncs\toolchains\v2.3.0\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'e:\ncs\toolchains\v2.3.0\opt\bin\cmake.EXE' --build 'e:\myApps\my_light_bulb\build\multiprotocol_rpmsg'
